Bike Cleaning
Discussion in 'UK Motorcycles' started by David Thomas, Aug 29, 2004.
  1. David Thomas
    David Thomas Guest
    Does anyone know of a good bike cleaning fluid, you know the type that
    sprays on and disolves all the crud then you hose it off.
    Last time I took the car in to be cleaned they said do you want "wheel acid"
    yes said I, they come up like new.
    Tried lots of wheel sprays and stuff but I'm sure there is a better product
    around that the valet people use.
    Your thoughts?
    D
  2. David Thomas
    David Thomas Guest
    only asked... git !
    D
  3. David Thomas
    Gavsta Guest
    In
    Being serious.
    Its great.
    Gavsta, Aug 29, 2004
  4. David Thomas
    prawn Guest
    Gavsta wrote:
    Wot he says. My F650 looks *clean*. <Shuffles off embarrassed, like>
    prawn, Aug 29, 2004
  5. Paul Corfield, Aug 29, 2004
  6. David Thomas
    David Thomas Guest
    Think I've seen it in the local motorcycle shop.... will go and get some,
    give it a go
    D
  7. David Thomas
    Catman Guest
    Very much wot he says. If I had used some recently, my Triple would look
    clean as well........
    Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 75 2.0 TS (two off)
    www.cuore-sportivo.co.uk
    Catman, Aug 29, 2004
  8. David Thomas
    Catman Guest
    Isn't it called 'Dirt Attack' thes days?
  9. David Thomas
    David Thomas Guest
  10. David Thomas
    Mikey Guest
    Muc Off is sold in the push bike section at Halfords.
    Mikey
    Mikey, Aug 29, 2004
  11. David Thomas
    Ben Guest
    Your local pedal bike shop will have it. That's what it was
    originally designed for and marketed to.
    Ben, Aug 29, 2004
  12. David Thomas
    David Thomas Guest
    Ta, got some from Halfords, will give it a go in the morning
    D
  13. David Thomas
    Eatmorepies Guest
    Good stuff. I spray the bike with water first because Muc Off can be
    diluted. Brush it on rather than spray it on. It's more work but you can
    wipe it over most bits and rub it in where the dirt is concentrated.
    Buying it - Halfords about £30 for 5 litre. Nelsons Cycles near Abergavenny
    £15.5 for 5 litre. So shop around.
    John
    Eatmorepies, Aug 29, 2004
  14. David Thomas wrote
    A combination of elbow grease and warm soapy water.
    And a toothbrush for those hard to reach places. And one of those
    brushes for painting behind radiators are good for getting deep inside
    things where a toothbrush is not long enough.
    steve auvache, Aug 29, 2004
  15. David Thomas
    Gyp Guest
    Auto Glym motorcycle cleaner. Also available in Halfords but expect to
    find it under motorbike rather than in the push bike department.
    Gyp, Aug 30, 2004
  16. HSS Hire shops.
    Adie
    Triumph 955iSS / GSF600 bandit
    MRO#11 BOTAFOF#7 BOTAFOT#130 DIAABTCOD#17 MIB#24 YTC#16 BOB#15 ex-UKRMMA#22
    Adrienne M Jenn, Aug 30, 2004
  17. I use Heine Gericke gel cleaner (order ref 28000317 on their website) -
    seems to work OK. Get the 5L since it's significantly cheaper (13.99
    GBP, as opposed to 4.99 GBP for 1L). Spray it on, scrub the tough bits,
    rinse off.
    And for the grease, roadfilm and really tough stuff, there is (was?)
    some stuff called Desolv-It. One of the best degreasants I've used -
    could use it on almost anything. Trouble is, I've run out and can't find
    it any more :-( So if anyone knows where I can get some more.....
    Chris
    Middleaged Mutant Ninja Rider, Aug 30, 2004
