Bike charging system
Discussion in 'Motorbike Technical Discussion' started by SpiderG, Jun 7, 2005.
  1. SpiderG
    SpiderG Guest
    At the end of last year, my Honda Shadow VT1100C stranded me on the return
    trip from NY to FL, requiring me to truck it home & place it in storage for
    the winter.
    I dragged it out and am trying to troubleshoot teh electrical problem, and
    remember all the details of the failure.
    Original problem - would spin over, but not start until battery died (in teh
    rain of course). I found a loose wire on the neg post of the battery, but
    buy then the battery was dead. Bike would start with a jump, but only ran a
    few miles before it quit (headlight dimmed and no more ignition), and I had
    to coast into a driveway (did I mention the rain - it was the end of the
    hurricane season).
    So I bought a new battery and had it charged at a local (where I was) bike
    shop who did some troubleshooting. I was told the bikes charging system was
    not charging the battery. They did some measurements, tried a used voltage
    regulator (no change), and told me I needed a new stator ($350+), plus a
    weekend wait in the middle of nowhere. We opted to rent a truck & drive home
    as the $$ were daunting.
    So I am here with the bike apart - I trickled the new battery all winter &
    it appears good. I got the bike started & it runs fine. I have the
    maintenance manual for the bike & performed the resistance checks on the
    stator per its recommendations - all 3 leads measure within the 0.3-0.5 ohms
    with no shorts to ground.
    So I am stumped. What voltage should I be measuring at the battery when the
    bike is running?
    When off and at rest the battery is now reading about 12.5VDC.
    When running (idle) it reads about 12.25V.
    Maybe I should drive it & measure the batt voltage a few times?
    Any suggestions?
    Thanks for the help!
    SpiderG
  2. SpiderG
    PQ Guest
  3. SpiderG
    Bob H Guest
    Put test leads on battery and run engine at 4000 rpm's The meter should read
    14.5 volts if it is not, it's time for a stator.
    Bob H.
    Bob H, Jun 8, 2005
  4. SpiderG
    Matt Guest
    The loose wire may be enough to explain the original problem, although I
    find it hard to believe that that shop would try to convince an
    out-of-towner that he needed an expensive repair when he didn't.
    My bike has to go at least 2200 RPM in order for the battery to get any
    charge. Slower than that, the lights eat up the power produced by the
    generator. Your voltage should be higher at 4K than it is when the
    engine is off.
    Okay, hopefully it has stopped raining by now. Get some good rain gear
    if you don't have any. Then do the following:
    Make sure you have money in your wallet, and that your cell phone is
    charged, and that you are well fed and watered and rested. Gather up
    your best biker friends. Then start the bike and drive it into the
    street and then back into the driveway. Shut it down, get off, and talk
    it over with your friends. You may want to measure the voltage. If you
    are still feeling fine, repeat the operation, this time driving a
    hundred yards before returning. Then take it around the block, then
    twice around the block, then four times. Then drive it a mile away,
    then two miles, then four miles. If at any point you notice a
    deterioration in performance or battery condition, have the motorycycle
    checked by one or more experts. Otherwise continue increasing the
    lengths of your excursions until you have made a round trip to a distant
    point such as New York or California.
    Matt, Jun 8, 2005
  5. SpiderG
    Matt Guest
    Matt, Jun 8, 2005
  6. SpiderG
    PQ Guest
    PQ, Jun 9, 2005
  7. SpiderG
    PQ Guest
    read
    Bob H.
    Not necessarily.
    Low voltage is not always just a stator problem.
    In bikes with a rectifier/regulator unit as one, if the regulator circuit
    goes, you get low voltage charging to the battery and the stator tests out
    fine. I have such a beast in my driveway now - charged new battery reads
    12.50v, with bike running reads 12.55 and starts dropping. Stator tests over
    60VAC at 4K rpm on all 3 leads and the resistance is within spec.
    Rectifier circuit is good (diode and resistance test) but the regulator is
    shot, (resistance test with a meter and shop manual).
    PQ
    PQ, Jun 9, 2005
  8. SpiderG
    Matt Guest
    It works for me now. Earlier I got messages saying the connection was
    refused.
    Matt, Jun 9, 2005
  9. SpiderG
    Ben Kaufman Guest
    Ben Kaufman, Jun 9, 2005
  10. SpiderG
    SpiderG Guest
    SpiderG, Jun 14, 2005
  11. SpiderG
    SpiderG Guest
    I have found this connector & pulled it apart & together a few times now.
    The bike maintenance manual said to measure between 0.3 & 0.5 Ohms between
    windings (measured OK), and open between each winding & ground. Now I used a
    pretty good DMM, and set it to read relative change in resistance, after
    compensating for the meter lead resistance, so I am pretty confident in my
    readings.
    Thanks for taking the time to reply!
    -SpiderG
