Bike breaking question.
Discussion in 'UK Motorcycles' started by Salad Dodger, Mar 31, 2005.
  1. Salad Dodger
    Salad Dodger Guest
    Assume for a moment, that it had been decided to get rid of a
    motorbike by breaking it , and flogging the bits to unsuspecting souls
    on Ebay.
    How far do you break it?
    Down the engine, or further?
    Unbolt everything from the frame and sell separately?
    Tank, sidepanels and tail as a set, or discretely?
    Scrap the frame or sell it on with V5?
    All advice welcome.
    | ___ Salad Dodger
    |_\_____/_| ..73850../..18203.../..3184./.19406
    \|^|/ ANORAK#17 IbB#4
    '^' RBR Landmarks: 5 Pts: 90 Miles: 455
  2. Salad Dodger wrote
    Clutch gone on the Wing again has it?
    Depends how anal you want to get about realising the money in it I
    suppose.
    steve auvache, Mar 31, 2005
  3. Salad Dodger
    AndrewR Guest
    Is it the KH? In which case can you give us time to rummage through our box
    of bits and find out what's missing.
    AndrewR, D.Bot (Celeritas)
    Kawasaki ZX-6R J1, Fiat Coupe 20v Turbo
    The speccy Geordie twat.
    AndrewR, Mar 31, 2005
  4. Salad Dodger
    Dr Zoidberg Guest
    Assuming that the engine still works then sell it as a complete unit.
    Sell sets of lights/indicators , significant electrical components , levers
    & switchgear all in their own lots.
    Same for wheels as a pair , forks , suspension etc.
    Tank separate , sidepanels and tail as a pair.
    I suspect the advice could change depending on what the bike actually is
    Alex
    www.drzoidberg.co.uk
    www.sffh.co.uk
    www.ebayfaq.co.uk
    Dr Zoidberg, Mar 31, 2005
  5. Salad Dodger
    Salad Dodger Guest
    Cheeky monkey. Anyway, it could be "both" relics.
    I have a cunning plan.
    I have a wide selection of deep-water docks nearby should the need
    arise.
    | ___ Salad Dodger
  6. Salad Dodger
    Salad Dodger Guest
    The clutch went 45,000 miles back. We've been through all this before.
    I've even had the plates, spring gasket, and locking plate in my shiny
    red tool box for about 18 months.
    I'm just too scared to start on it, and I didn't have the stomach[1]
    for the fight during the winter.
    Maybe at the end of the summer.
    [1] Yes, I know, there's no need to comment.
    | ___ Salad Dodger
  7. Salad Dodger
    Salad Dodger Guest
    Well, I always *wanted* a purple metalflake H2C.
    With K&Ns, and Denco pipes.
    But I don't know what I'll end up *getting*.
    | ___ Salad Dodger
  8. Salad Dodger
    Dr Zoidberg says...
    Right down as far as you can sensibly go.
    Yes, regardless of running or not. Be sure to tell them it hasn't been
    run for a while and you cannot guarantee it will even start when lobbed
    in a frame.
    Yes, everything is worth money. Even things like the battery carrier and
    tool tray have some value to someone. I got 15 quid for a good tool tray
    for an RD when I broke my blue one.
    Wheels seperately, forks as a pair, yokes as a pair, switch gear
    seperately, indicators as a set of 4, lights seperately, all electrical
    components seperately.
    Wrong. Sell everything bodywork related seperately, you get more money
    that way.
    Sell the frame with V5 on its own and swingarm seperately.
    Lozzo, Mar 31, 2005
  9. Salad Dodger
    Split as many things as you can, and sell matching parts in different
    lots. For example, cams / bearing caps in one lot, head / buckets in
    another lot, so people have to buy more lots to get a matching set.
    Frame with V5 sounds good.
    Muck, Mar 31, 2005
  10. Salad Dodger
    Muck says...
    Individual engine parts fetch bugger all, especially on an older 2-
    stroke like the TS. He'd be better off selling the engine unit complete.
    Lozzo, Mar 31, 2005
  11. You take each little component and sell it separately. You get it into
    as many components as possible. Out there, somebbody wants that little
    widget.
    You will get good money for an engine if you can prove it runs. just
    saying it does isn't good enough. As, therefore, proving it is not
    always possible (perhaps because you already flogged the coils or the
    carbs), then break it down, Pistons as a set, head complete (or a pair
    or trio if we're talking two strokes), crankshaft, rods as a set,
    pistons as a set.
    Yes, absolutely. Sidestand, centre stand, airbox, battery box, fusebox,
    wiring loom, reg/rec, even the tank rubbers.
    Separately, again, but remember to put a pointer from each item to the
    others. "This is a tank from an XXX (H1?)..... see my other auction
    no.xxx for left panel, right panel and tailpiece.
    Sell it with V5. And remember to state "Buyer collects".
    See above. I have broken and flogged a few bikes - most recently a 400
    Four, and a few years ago an H1 (is there a pattern here?) aand in both
    cases earned about twice as much as I'd have got selling the bikes
    complete. And the H1 was a lovely taxed and tested original runner.
    In every case, all I've been left with is a handful of nuts and bolts
    and they've gone into my Bumper Tins Of ShiteOldFasteners. Oh, I've got
    a pair of forks from a CD175 somewhere.
    The Older Gentleman, Mar 31, 2005
  12. Salad Dodger
    Salad Dodger Guest
    I'm not anticipating getting much for the cams, to be frank.
    I'm inclined to think (and I don't know why) that the opposite is
    likely to be true for the blue motorcycle.
    | ___ Salad Dodger
  13. Like I said, only if he can prove it runs.
  14. Salad Dodger
    Salad Dodger Guest
    Thanks, everyone.
    Well, the Tax and MOT run out in July: I'd best try to get some use
    out of it until then.
    I can start on the shit heap right away.
    | ___ Salad Dodger
  15. Salad Dodger
    Ahh.. the TS, yes. You're right.
    Muck, Mar 31, 2005
  16. Salad Dodger
    Christofire Guest
    When I was monitoring for daytona bits I saw a tatty black 955 go up
    for sale on ebay. A week or so after it was sold it appeared back on
    ebay in kit form. Every last panel, light, fob, grommet, screw and
    washer was on there.
    So, I'd say "the entire lot, as seperate bolt-on units, and the frame +
    v5". I bought my bits as they were what I needed - a nice big bit I
    could just bolt straight on. Don't break it down too far.
    Christofire, Mar 31, 2005
  17. Salad Dodger
    Douglas Simmonds: weapon of choice.
    http://www.70slivekidvid.com/double/tdoughnut.jpg
    Pip, Apr 1, 2005
  18. Salad Dodger
    I was going to use the habitual Mr Pot reply, but as there's probably
    some **** round here who has that as his RL name, I can't.
    Anyway, I see no weirdness - the fat kid is the obvious Double Decker
    to use as a projectile weapon. Right?
    Pip, Apr 1, 2005
  19. Salad Dodger
    Don't patronise me, Mr Pudgy.
    <awaits angry email from The Real Mr Pudgy>
    Pip, Apr 1, 2005
  20. Salad Dodger
    I'd suggest selling the frame without the V5. If anyone needs a
    replacement frame (crash damage etc.) they can readily transfer a new
    frame number onto their existing V5. That's my understanding anyway.
    Whereas with the V5 they can transfer someone else's engine etc. to the
    V5. Problem is that someone may not be too happy about it.
    sweller, Apr 1, 2005
