Bike brakes require more maintenance than car brakes?
Discussion in 'Motorbike Technical Discussion' started by Phil, Squid-in-Training, Mar 10, 2006.
  1. It seems that bike brakes require drain and bleed cycles far more often than
    cars. Why?
  2. Phil, Squid-in-Training
    FB Guest
    If you are basing this question upon the recommended maintenance
    intervals you find in your owner's manual, that's because the
    manufacturer doesn't know how much you actually ride your machine and
    may believe that you ride it over bad roads in some mosquito-infested
    wilderness and that you park the machine outdoors in a monsoon near a
    beach that has frequent hurricanes or tsunamis.
    Opps! That describes Florida, doesn't it?
    So the brake fluid and lubrication intervals are shortened, compared to
    the intervals actually needed in the kinder, gentler part of the world,
    like around here, where the dairy cattle describe the sudden motions of
    the ground under their feet as "Here comes the foot massage again!"
    And you thought that commercial was made in Wisconsin...
    Seriously, though, the manufacturer knows that motorcycles tend to be
    neglected, and system reliability is imperative for rider survival, so
    they recommend about four times as much maintenance as they really
    need, and if the owner follows the recommended maintenance schedule
    half as often as recommended, the machine is usually getting twice as
    much maintenance as it really needs.
    FB, Mar 10, 2006
