Bike bits
Discussion in 'UK Motorcycles' started by Linger, May 10, 2004.
  1. Linger
    Linger Guest
    The ongoing saga that is my bike. Rad is split (really small). Can it be
    welded, or liquid metalled up? A new one is £200!!!!!
    I also need the rad protectors as they were so brittle that the broke when I
    took them out!
    My gawd, this is costing a fortune!!
  2. Linger
    Martian Guest
    A quick google popped up:
    Dixon Radiator Repairs - Classic car radiators
    UK,
    Tel: 01734 415252
    or
    http://www.radiators.fsbusiness.co.uk/
    Are they first places I would try.
    There are usually chaps who can recondition these sort of things in the
    local motor rags.
    Martian, May 10, 2004
  3. Linger
    Linger Guest
    Ok, I'll have another look.
  4. Linger
    Linger Guest
    Nice, I looked on yell.com and got a couple of local boys.
  5. Linger
    Linger was seen penning the following ode to ... whatever:
    Soldered, not welded. I assume that the tanks are metal and not
    plastic?
    <thinks hard>
    Did you check the names of the previous owners when you bought it?
    Timo Geusch, May 10, 2004
  6. Linger
    Linger Guest
    Is that right? Do you not weld aluminium?
    No log book on a crosser. Have you ever owned a CR250
  7. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember "Linger"
    You can weld ally quite the thing, if you're a good enough welder.
    Iow, take it to someone. The local rad makers/repairers will probably be
    able to do it anyway.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, May 11, 2004
  8. Linger
    Robbo Guest
    Dartford Vehicle Radiators, off lower road along from council tip near
    Thames Rd. Bloody god at repairing and fixing rads they are, used 'em fer
    years.
    IIRC ask for Dave........
    DVR
    Unit 14, Victoria Industrial Park Victoria Rd
    Dartford Kent
    DA1 5AJ
    Tel: 01322 291177
    Robbo
    BMW K100 RS 1984
    BotaFOF #19. E.O.S.M 2001/2002/2003.
    B.O.S.M 2003/4.FURSWB#1 KotL..YTC449
    PM#7
    Robbo, May 11, 2004
  9. Linger
    Linger Guest
    Cheers, I'd rather have a reccomendation. I took it to a local enjineering
    firm who welded it for a tenner.
    However, it still leaks!!!!
    I shall be returning tomorrow.
    Linger, May 11, 2004
