Bike audio??
Discussion in 'Australian Motorcycles' started by Bummers, Aug 31, 2003.
  1. Bummers
    Bummers Guest
    Can anybody give me advise on setting up music on a bike?
    I'm thinking of a MP3 player or minidisk player through helmet speakers for
    the ride to Philip Isl from Brisbane. - I'd imagine the the speakers are the
    critical bit.
    I tried earbuds & they were uncomfortable & I couldn't really hear the
    music/radio at over 60kph.
    Any advise or leads greatfully accepted.
    Bummers
    GSX1100 - The ultimate tourer, racer, wobbler
  2. In aus.motorcycles on Sun, 31 Aug 2003 22:42:07 GMT
    I've had reasonable success with a set of small speakers from jaycar,
    which I then attached to a volume control from a cheapish set of
    headphones designed to use with a TV. (from Dick Smith - I paid about
    20 bucks on special). The volume control is useful if you need to slow
    down and don't want to be deafened....
    Soldered wire to the speakers, soldered other end to a 3.5mm stereo jack,
    added velcro hook to the speakers, that assembly then sits in the helmet
    with the jack tucked up in the padding.
    I cut off the speakers from the TV headset leaving the wire to the
    volume control, and soldered a 3.5mm stereo plug to that. The other
    end of the volume control has the original 3.5mm plug that goes into
    the TV, that now plugs into the sound source.
    Works fairly well, although I do need a fair amount of power from the
    sound source to hear it at highway speeds.
    I have a set of earplugs - Alpine brand, bought from a mob at the Bike
    Expo, probably available in Oz somewhere, try safety shops - which
    pass on speech type noise fairly well, while blocking the wind rush.
    Using these I can hear the music much better.
    The speakers I bought were fairly cheap, better speakers may need less
    oomph from the sound source.
    My ideal would be to use the innards of noise cancelling headphones as a
    permanent helmet installation, but I'm not willing to spend the $80-90
    to buy a set to play with, as I bet fitting the mikes properly would be
    tricky.
    Zebee
    Zebee Johnstone, Sep 1, 2003
  3. Bummers
    Mike Doyle Guest
    Zebee
    what happens if you come off the bike and hit your head? (This is just a
    general question). I was thinking that having something hard in your
    ear (ear phones) or next to your ear (speakers) may have real bad
    consequences even if you just fall off the bike while standing still.
    The thought of the full impact of any fall being taken by my ear (or
    even worse...inside my ear, or the bone around my ear) fills me with fear.
    Any thoughts? Or am I being paranoid?
    Mike
    Mike Doyle, Sep 1, 2003
  4. In aus.motorcycles on Mon, 01 Sep 2003 12:01:00 +1000
    I don't know. doesn't fill me with fear, as I figure if I hit my head
    hard enough for that to matter, I've got worse things to worry about.
    If it scares you, then clearly music while you ride is not as important
    to you as that fear is. You get to make the choice.
    Up to you to decide
    - how likely you are to hit your head in the spot where the speakers
    are
    - how hard you have to hit before the speakers contact your head hard
    enough to do damage
    - what sort of damage will be done.
    My thoughts on that are:
    - not very, based on many getoffs and how often the head has been hit
    and where. (twice, both times above ear level, in a hell of a lot of
    getoffs at various speeds)
    - Would have to be bloody hard, considering that my helmet fits
    properly, and the speakers aren't touching any part of my head
    - I might get a bruised ear, the head is a very tough thing and there's
    not too much damageable by a bang right there that won't heal quickly
    enough.
    My philosophy is that if I am going to let something influence how I
    act, I should think about it, not just kneejerk. If after thinking
    about it I am still scared of it, I won't do it. If the advantages of
    doing it are greater than the fear, I will do it, minimising the risks
    I see till the balance is right. Whether that's music on long trips,
    or riding in a t-shirt.
    Up to you to decide where *your* balance is.
    Zebee
  5. Bummers
    Nathan Smith Guest
    Ok I have a car stereo in my box on the back.
    1. Can you ride with sound running in ya helmet? It's something that can be
    quite off putting to start off with.
    2. Don't use a CD player. They jump all the time and it's just shithouse.
    What I did was mount the car cd player somewhere where it can't be taken and
    won't get wet, ie in the top box for the trip to PI. then I ran (or will
    cause I'm lazy) run a wire from the taillight to use as the 'remote', that
    switches it on and off, ran a heavy wire from the battery for earth and
    positive terminals, and then a stereo wire from the front to the back of the
    bike. I bought a 'microphone' wire from dick smiths, it has a coil in it,
    the 2m one is perfect. Then soldered a couple of connectors for the
    handlebar connection. The 6.5 mm jacks work fantastic and are easier and
    more sturdy.
    The helmet connection is a lot harder. The headphones I bought ($6 at
    jaycar) have a fine wire that is found in most headphones and must be
    supported or else they continously break. The headphones I bought had the
    vol thing right near the ear piece in the perfect possie to mount them in my
    helmet. I took off the strap across the head of the headphones and ground
    down the back (opp the speaker) side to stop the earpieces giving me a head
    ache then velcroed them into place upside down to the way they normally go
    on ya head, as in my helmet there is a perfect gap to slide the long part of
    the head phones into place.
    If I was to do it again, and I might change mine before PI is to use a box
    on the handlebars with a trimpot inside to adjust the volume, it'd be easier
    to use. I also used only one outlet channel from the CD player, and this is
    enough to distort the sound and deafen me at 160kph. More than that I don't
    hear the music...
    Any more q's yell out
    Nath
    CX500, wired for sound...
    Nathan Smith, Sep 1, 2003
  6. Bummers
    Mike Doyle Guest
    fair 'nuff.
    I think my "vision" of the set up was slightly (very) wrong. I was
    thinking the earphones/speakers being resting (or almost resting) on the
    ear, being protruding from the helmet foam. If that was the case, any
    knock on the helmet (even a little one...), from almost any direction
    (no straight front on or back on) means that the full impact will be
    taken by the speaker hitting your ear, instead of being spread around
    the head. Even a friendly clip on the back of the helmet by a friend
    may cause enough pressure on the ear piece to do damage.
    Of course, if the speaker was embedded in the foam, then the foam would
    hit first, no probs.
    Mike
  7. Bummers
    Mike Doyle Guest
    ah ha! With the dropping of a penny, enlightenment is reached :)
    yep.
    Mike
  8. Bummers
    Tony tony Guest
    Why?
    You could have a home stereo in your box ....
    tony
    Tony tony, Sep 1, 2003
  9. Bummers
    Koss!
    Knobdoodle, Sep 1, 2003
  10. Bummers
    sharkey Guest
    I'm sorry, I have a cold.
    -----sharks
    sharkey, Sep 1, 2003
  11. Bummers
    Mark Hammond Guest
    hehe - i've often thought that is exactly why all the servo's out in the
    middle of nowhere sell such absolute shit music. I figure it is for
    those poor people who forgot to bring tapes on the trip - and they are
    so desperate they will buy *anything*
    Mark
    Malvern-Star :)
    Mark Hammond, Sep 2, 2003
  12. Bummers
    Nathan Smith Guest
    240 Volt Power my friend. I'm currently prepping the sub for the sound off
    competition!
    Nathan
    Nathan Smith, Sep 2, 2003
  13. Bummers
    Steve Guest
    I have the Sony MZ-N10 and Sony MDREX71SL, they are both superb.
    If you have extra dough, you can get the Etymotic ER-6 Isolator
    earbuds, which is very impressive and used by musician.
    http://www.etymotic.com/images/PDF/er6info.pdf
    Steve, Sep 3, 2003
  14. Bummers
    sharkey Guest
    Ick! I hope they cleaned them, some of those musicians are
    pretty gooey.
    -----sharks
    sharkey, Sep 3, 2003
  15. Bummers
    Bummers Guest
    Autocom product is available in Australia - they have 10mm thick speakers
    that can be velcroed in place - but ain't cheap,
    I checked them out at Olbis in Brisbane & the whole Autocom setup looks like
    the bees knees! - but ain't cheap!
    See - http://www.bluerim.com.au/index.htm for details & dealers.
    Bummers
    Bummers, Sep 10, 2003
