Bike Anti-Theft Kit.
Discussion in 'UK Motorcycles' started by danny_deever2000, Oct 25, 2005.
  1. I'm tempted to beef up the security on the garage my bike/tools/sailing
    kit is in. By which I mean adding a stonking big lock bolted to the
    ground holding the door closed.
    What worries me is that it may merely be blatently advertising there's
    something nickable in there.
    What's the best most discrete way to protect my garage???
    Is it better to have a chain in the garage bolting the bike to the
    ground?
    Discuss.
  2. danny_deever2000
    scribbled on the back of a napkin:
    Pissed-off rottweiler with a Mac-10.
    Timo Geusch, Oct 25, 2005
  3. danny_deever2000
    emerged from their own little world to say
    If it is easy to get into the garage then a thief can work, unseen, to
    defeat any security within. The job is made easier if you leave your tools
    inside the garage.
    You need to ensure your house is secure too. As many bikes now have coded
    keys a determined thief will enter your house, grab the keys and be off
    with your pride & joy.
    wessie, Oct 25, 2005
  4. wrote
    No amount of security, whether visible or not, is going to keep out a
    thieving scrote who has predetermined they are after a specific item or
    items but it may slow them down enough to discourage some.
    Hi-vis security keeps out opportunist thieving scrotes in large numbers.
    There *is* every point in showing (some of) your defences.
    steve auvache, Oct 25, 2005
  5. danny_deever2000
    Zanziba Guest
    Keep your bike in your house? Wives the world over love having a large
    motorcycle in the kitchen.
    Zanziba, Oct 25, 2005
  6. danny_deever2000
    John Smith Guest
    Buy a rotweiller or two. Let them live in the garage. Dont over feed
    them so that they're always up for a bit of fresh human.
    John Smith, Oct 25, 2005
  7. Good points, thanks. Looking at what is available I suspect I will be
    able to deter oppotunists and *maybe* raise the minimum time to get
    into my garage to the point where a keen scrote thinks it's not worth
    the bother.
  8. danny_deever2000
    TOG Guest
    Good idea.
    Ye-es, but then loads of scrotes will break into garages anyway, just
    to see if there's something worth nicking.
    I'd opt for both, if you're being serious about things. Also, one of
    the neatest ideas I've ever heard of (assuming you have power in your
    garage) is to stash a baby alarm in there and keep the other end in the
    house. That way, you'll hear immediately if any cnut breaks in,
    especially at night. They're amazingly sensitive and loud, baby alarms
    (as you'd expect, I suppose).
    Actually, I suppose the techies could go further with a baby alarm. How
    easy would it be, for example, to connect the "slave" side to a
    telephone, or better still, a computer, rigged to send a message to
    your mobile, or to dial 999, or detonate landmines, or something of
    that ilk? Paging the techies!
    Actually, what you *really* want are those robo-sentry guns, as in The
    Director's Cut of Aliens.
    TOG, Oct 25, 2005
  9. danny_deever2000
    flash Guest
    Left hand threads.
    flash, Oct 25, 2005
  10. TOG@toil wrote
    Video, sent in one second bursts off-site somewhere and a tape telling
    them to, "look into the camera please."
  11. danny_deever2000
    MikeH Guest
    Very thick wooden garage door, metal handle wired to the mains via a switch.
    Switch on.
    Go to bed.
    Wake at the chip-shop noise, check black heap outside garage, get up ten
    minutes early the next day to clear up.
    MikeH, Oct 25, 2005
  12. I'm gonna. Next question. Good bolts to go into the
    ground/concrete/tarmac. What kind of bolts do you use, how do you stop
    the yobs just undoing them? (I've got a ground anchor already without
    bolts.)
  13. danny_deever2000
    TOG Guest
    I think you can buy pre-stressed ones that shear if somebody tries to
    undo them. I know you can buy "one-way headed" screws, large ones,
    because I've got them holding a security metal loop to the side of my
    house. A shackle lock goes through it, and round a chunk of my bike
    trailer.
    Trailers, any trailers, are a pikey-magnet. Some cnuts tried to nick it
    a couple of years ago, only to find that (at that time) it was shackled
    to a dead Honda CB500T, which made a helluva noise as it fell over.
    TOG, Oct 25, 2005
  14. danny_deever2000
    antonye Guest
    Just don't forget that it's in there when you start discussing stuff
    with your mates in the garage while the wife is in the house.
    Especially
    if it's stuff you didn't want her to hear...
    antonye, Oct 25, 2005
  15. Rawlbolts and weld the heads to the anchorplate.
    GS850 x2 XS650SE / SE 6a
    Grimly Curmudgeon, Oct 25, 2005
  16. "TOG@toil "
    I *liked* those!
    Mick Whittingham, Oct 25, 2005
  17. danny_deever2000
    deadmail Guest
    wrote in message
    I had a bolt in the middle of my garage door (motrax thing) and had
    beefed up the security inside with bits of 4x2 attached to the frame to
    brace it.
    Some cunts tried to break in but fortunately this stopped them. I'd
    'hidden' it from sight by placing an old cut-away car battery in front
    of the door but this didn't help.
    After the break in I added two heavy duty staple-hasp type things
    designed for secure shed locks etc., I buried half of these in concrete
    with the hinge just above the concrete and meeting the staple (U shaped
    bit). This plus 3 high security locks is my (current) solution.
    I'd like to electrify the garage but suspect I'd forget about it one
    morning.
    deadmail, Oct 25, 2005
  18. This is what would stop me doing something like that, as well.
    The Older Gentleman, Oct 25, 2005
  19. danny_deever2000
    Pedalbin Guest
    Presumably the fact that it was attached to a CB500T was enough to put them
    off...
    Pedalbin, Oct 25, 2005
  20. danny_deever2000
    Pedalbin says...
    I have a theory that they were trying to nick the marvellous CB500T and
    didn't realise that some twat had chained some shite old scrap trailer
    to it.
    Lozzo
    Track pixie
    GSX-R1000 K1
    I haven't lost my mind, it's
    backed up to a floppy disc
    that's around here somewhere.
    Lozzo, Oct 25, 2005
