Bike Alarm - Veto Plus internal Battery life
Discussion in 'UK Motorcycles' started by JohnH, Jul 29, 2004.
  1. JohnH
    JohnH Guest
    I'm off to switzerland for up to a month on tuesday, however the bike
    has recently acquired a new battery which i'd rather not see die in the
    meantime. I know it will be flat as a pancake when I get back as i've
    got one of datatool's finest battery killers.
    Anyway point is i was planning on disconnecting the alarms connection to
    the battery, however the alarm is going to start ringing when i do this.
    Does anyone have any ideas how long this will go on for? or know of any
    tricks to shut it up? Current thought process is to put a pillow over
    the alarm box, put the bike cover on top, then leave it for a few hours.
    I'd rather not bin the alarm or angle grinder it to pieces as someone
    may suggest.
    Thanks in advance for any ideas.
    JohnH, Jul 29, 2004
  2. JohnH
    Ginge Guest
    Get an optimate, and leave it on whilst you're away, thus keeping the
    battery in tip-top condition.
    Ginge, Jul 29, 2004
  3. Ginge wrote
    Or wire it up to a 15V low current solar panel and keep both planet and
    battery in tip top condition.
    steve auvache, Jul 29, 2004
  4. JohnH
    Eddie Guest
    JohnH wrote:
    Optimate
    Eddie, Jul 29, 2004
  5. JohnH
    Ben Guest
    Put the alarm into service mode. Then you can disconnect the battery
    without it screaming at you.
    I can't remember the exact combination of buttons now because it's
    been a while since I sold my Veto equipped bike.
    Ben, Jul 29, 2004
  6. JohnH
    Ben Guest
    On the Veto Evo it was turn on the disarm, turn on the ignition, hold
    down the O button until you hear a long beep, then turn the ignition
    off.
    Ben, Jul 29, 2004
  7. JohnH
    JohnH Guest
    Cheers for both idea's but if i had a garage thats what i'd do. As it
    happens the bike is parked outside and there are no outside sockets so
    an open window is necessary, not gonna leave a window open for a month
    in the area where i live!
    JohnH, Jul 29, 2004
  8. JohnH
    JohnH Guest
    Cheers Ben, ill give that a try later. Doesn't service mode mean it
    will beep every 30 seconds or something?
    JohnH, Jul 29, 2004
  9. JohnH
    gomez Guest
    Catflap?
    gomez, Jul 29, 2004
  10. JohnH
    dwb Guest
    It did on mine - very annoying.
    The later ones let you just disable the movement sensor - which is nice.
    dwb, Jul 29, 2004
  11. JohnH
    If you can get to the alarm box itself, open it up and remove the
    internal battery. It isn't going to like it when you're doing it, but
    it won't squawk for long.
    We found that it is possible to minimise the sound by wedging a pair
    of rolled-up socks over the sounder holes, if you just want to
    disconnect it and run it flat. For more permanent silencing, I'd tape
    some thick foam or material around the box, or fill the little
    fucker's air holes with expanding foam - just like you do to cats.
    Pip, Jul 29, 2004
  12. JohnH
    JohnH Guest
    On the ball Pip! Thats exactly what i needed to hear. I have easy open
    access to the box and its screws, so i reckon i'll take its battery out.
    JohnH, Jul 29, 2004
  13. JohnH
    It just sounds waaaay too easy, though ...
    Best of luck.
    Pip, Jul 29, 2004
  14. JohnH
    Oldbloke Guest
    You still in Wycombe, or is that a different JohnH?
    Dan L (Oldbloke)
    My NEW bike 1996 Kawasaki ZR1100 Zephyr
    My old Bike 2000 Honda CB500 (for sale)
    M'boy's Bike 1990 Suzuki TS50X (Heavily fortified)
    BOTAFOT #140, DIAABTCOD #26
    Oldbloke, Jul 30, 2004
  15. JohnH
    Stritchy Guest
    The moment he decided to open the box, his fate was sealed............
    Stritchy, Jul 30, 2004
  16. JohnH
    JohnH Guest
    Yep Dan, still in wycombe, Hows the 1100?
    JohnH, Jul 30, 2004
  17. JohnH
    Ben Guest
    Yeah, but he's not going to be there to hear it.
    But it'll still go off if you remove the battery.
    Personally I'd leave it connected, especially if it's being left
    outside for a month. New batteries are cheap, new bikes aren't.
    Ben, Jul 30, 2004
  18. JohnH
    dwb Guest
    INdeed - it does rather seem a false economy.
    Very pleased with the Optimate I got as it means the alarm is always working
    in 'active' mode - which means it actually does go off if the bike is moved.
    Seems totally random if it's in the power save mode - I believe by design it
    cycles the movement sensor on and off at random intervals - not exactly
    confidence inspiring :)
    dwb, Jul 30, 2004
  19. JohnH
    Eddie Guest
    If it's parked close to a window, you should be able to run the Optimate
    cable through and still get the window shut.
    But the general idea with solar panels is that they're used outside, so
    that wouldn't be a problem, would it?
    Eddie, Jul 30, 2004
  20. JohnH
    someone'll nick the solar panel.
    darsy, Jul 30, 2004
