Bigger, better, older?
Discussion in 'UK Motorcycles' started by TD, Jan 22, 2008.
  1. TD
    TD Guest
    Have the "opportunity" to swap my YZF-600R, 2001, 12000 miles, slight cosmetic
    damage, plus 750 quid, for a YZF-1000R, 1999, 32000 miles, no cosmetic damage.
    Shit, good, or somewhere in the middle?
    TD, Jan 22, 2008
  2. Depends on whether the gearbox is fucked or not.
    The Older Gentleman, Jan 22, 2008
  3. TD
    Domènec Guest
    Thundercat to Thunderace?
    At that mileage the 'ace is about to start drinking oil on a regular basis.
    But is a great bike of its time.
    Domènec, Jan 22, 2008
  4. TD
    TD Guest
    If it's not fucked, it's a decent deal? Any way I can easily check for
    fuckedness on a test ride?
    TD, Jan 22, 2008
  5. TD
    TD Guest
    You'll have to excuse me knowing not a lot. Drinking oil due to gasket leaks,
    valve stem seals, piston rings, or something else? I thought they were
    reliable as ****.
    TD, Jan 22, 2008
  6. TD
    Domènec Guest
    They drink oil (as many Yamahas) and are reliable. Mine is getting close to
    100.000kms with no problems except that 1litre/1000kms that Yamaha reckons
    as within tolerances. At the end you just add oil every X miles and even
    like that feeling of "running on fresh oil" :)
    I never heard of problems with this bike but heard horror tales with Hondas
    CBR1100XX, for instance.
    Domènec, Jan 29, 2008
  7. TD
    Really? The bike has issues[0] but holds the reputation of being
    mechanically robust[1]. A mate who does 20+ thousand miles a year as an
    escorted tour guide rates them. He has had several over the years and tends
    to sell them on when they are 3 years old with 60-70000 miles on the
    odometer. 1 main service a year with an oil change every 4-6000 miles. He
    might have to replace a clutch and some brake/suspension components in that
    time but these would be normal wear & tear items over that sort of mileage.
    [0] ponderous handling, dull, a huge appetitie for fuel and a propensity to
    go ditch surfing
    [1] apart from Honda's signature faults across the range: a rattly camchain
    adjuster and melted voltage regulator
    wessie, Jan 29, 2008
  8. TD
    Domènec Guest
    Yes, exactly that. May be "horror" was exagerated, sut several issues
    divided by no issues (except oil) gives a very large number ;-)
