big bang
Discussion in 'Australian Motorcycles' started by vifer, Mar 8, 2005.
  1. vifer
    smack Guest
    nobody picked up that you can in fact get brass chisels. Common trick at the
    steelworks is to send the apprentice off to the store for all the usual
    silly things, then once they wake up, send em for a brass chisel.
    smack, Mar 10, 2005
  2. vifer
    sharkey Guest
    I wasn't sure about that one :)
    I was got good the other day by our workshop guy ... I'd just lined
    up everything perfectly on the sheet metal bender and was just locking
    the jaws into place when Maurice wanders past and says "Did you
    remember to turn that on?", waving in the direction of the other
    end of the bender. Being an idiot, I let go of the clamp for a second
    while reaching towards the imaginary power switch ...
    I can't wait to turn the power on the magnetic bender off on him ...
    -----sharks
    sharkey, Mar 10, 2005
  3. vifer
    FruitLoop Guest
    I need a box of emery sparks
    FruitLoop, Mar 10, 2005
  4. vifer
    FruitLoop Guest
    Unless you have a clitoris , then the vibration would be a bonus
    ............thats why girls ride bb engines
  5. vifer
    Conehead Guest
    The number of cylinders?
    The size of the cylinders?
    Conehead, Mar 10, 2005
  6. vifer
    Theo Bekkers Guest
    Lots. Two smaller combustion chambers, better spark propagation, better
    filling and scavenging.
    Theo
    Theo Bekkers, Mar 11, 2005
  7. vifer
    Moike Guest
    Among other things, smaller reciprocating mass. Two litle pistons are
    much smaller than one big one.
    In addition, the ones firing together dont. they are separated bi a
    smidgin to spread the power pulse out a bit.
    Moike
    Moike, Mar 13, 2005
  8. vifer
    Boxer Guest
    The main difference is the size and weight of the valve train, smaller and
    lighter valves can rev higher than larger heaver ones.
    Boxer
    Boxer, Mar 13, 2005
  9. vifer
    Centurion Guest
    Piston engine *theory* states that power output is:
    PLANK
    ----- = HP
    k
    where:
    P = mean effective pressure (combustion pressure)
    L = length of stroke
    A = cross-section area of the cylinder
    N = number of cylinders
    K = RPM
    k = a constant to get all the units to spit out HP instead of something
    obscure like "Pascal-millimetres-cubed-degrees-per-second". So "k"
    will vary depending on what units you choose for each measurement in
    PLANK
    Note this theory is "ideal" and makes no allowance for other improvements
    and losses in power (such as scavenging/volumetric efficiency etc). In
    short, for a given engine size, increasing the number of cylinders will
    usually increase power output. (Unless it's a Hard^Hley in which case it
    had no power to start with so "zero x anything" will still be zero).
    James
    ZZR250==>ZX9R
    Centurion, Mar 13, 2005
  10. It's all just torque then!
    Pisshead Pete, Mar 14, 2005
  11. *PLANK*
    Postman Pat
    Pat Heslewood, Mar 14, 2005
