Best way to travel 5 miles to a train station?
Discussion in 'UK Motorcycles' started by David, Aug 11, 2004.
  1. Because they have been told that the roads are much too dangerous,and
    that it is everybody else's job to keep out of the way of the cars.
    Speed limits were intoduced in response to motorists' consistent
    failure to keep to reasonable speeds. Introduction of the 30 limit
    round towns is credited with one of the largest reductions in road
    deaths on record.
    And better road sense - you don't learn much about defensive driving
    when you are surrounded by airbags and safety cages.
    19??: There seem to be a lot of people getting killed by drivers
    failing to choose apropriate speeds. And that's the problem: a snmall
    section of society has never accepted that law should have been
    passed. Just as a (somewhat smaller) section thinks the drink-drive
    laws should not have been passed, and behaves accordingly.
    Guy
    Just zis Guy, you know?, Aug 19, 2004
  2. David
    Gawnsoft Guest
    Gawnsoft, Aug 19, 2004
  3. There are 3,000 fatalities on the roads every year and over 30,000
    serious injuries. If each one were investigated as a murder or
    serious assault is investigated (typically several hundred man-hours,
    according to a quick Google) the plod would never do anything else.
    Even if it wer only 100 man hours that would still be a the equivalent
    of thousand coppers assigned permanently to crash investigations.
    Endless references (see the Motorcarnage website for examples). And
    in what way is killing someone through negligence not as serious as
    doing something which makes it somewhat more likely that you mightkill
    someone through reduced control?
    It is for deterrence. And it works very well: most drivers do not
    risk it.
    See above.
    Guy
  4. David
    Gawnsoft Guest
  5. David
    David Martin Guest
    And your evidence for that is? Oh wait, it's pure supposition.
    Any form of transport smaller than a sherman tank is dangerous if some
    homicidal maniac in a 4x4 decides he is going to run you over.
    ...d
    David Martin, Aug 19, 2004
  6. Actually I know of at least two instances where the road was not
    closed at all after the ambulances had left the scene. That accounts
    for 100% of the fatal crashes of which I have seen the immediate
    aftermath.
    Yes, plod on the scene form a snap judgement. And then when they
    investigate in detail they find that speed is actually the cause in
    may more cases. Your point was?
    Guy
  7. David
    Gawnsoft Guest
  8. If you are cutting towards yourself, it is stupidity.
    Guy
  9. David
    Gawnsoft Guest
    Which shows that some road deaths are investigated.
    Not that all such are investigated as much as or more than any other
    sudden, accidental or suspicious death.
    (It's a 'black swan' problem)
    Cheers,
    Euan
    Gawnsoft: http://www.gawnsoft.co.sr
    Symbian/Epoc wiki: http://html.dnsalias.net:1122
    Smalltalk links (harvested from comp.lang.smalltalk) http://html.dnsalias.net/gawnsoft/smalltalk
  10. And the consensus is that the changes become, over time, more enlightened.
    So, homosexuality was legalised, speeding was banned. Society chose to stop
    protecting itself from an imagined danger and protect itself instead from a
    real one.
    The reason for 30 not 20 is, as previously stated, balance of risk versus
    benefit. Society having decided on a speed which embodies that acceptable
    balance, for drivers to decide, based on their known unreliable judgement,
    that society is wrong, does nobody any favours.
    Think for a moment: who gets the benefits of greater speed? The driver.
    Who gets the risk? The road user community in general, pedestrians and
    cyclists far more so than the driver. The driver has an in built incentive
    to make the wrong judgement.
    Guy
    May contain traces of irony. Contents liable to settle after posting.
    http://www.chapmancentral.co.uk
    88% of helmet statistics are made up, 65% of them at Washington
    University
    Just zis Guy, you know?, Aug 20, 2004
  11. Before you argue the toss about this, I suggest you read up on it. Really.
    It is quite an eye-opener.
    Guy
    University
  12. When I get my copy of the relevant book back form the bloke I lent it to :)
    Many documented on the motorcarnage website. A study in Oxford, one of the
    cities with the most indisciplined cyclists, showed that 75% of car-0bike
    crashes were the car driver's fault. Certinaly 100% of my crashes have been
    the driver's fault, two of them the classic "failing to yield to circulating
    traffic on a roundabout" case which accounts for 50% of fatal crashes on
    roundabouts.
    ITYM "Probably to do with the prevailing political climate or recent tabloid
    stories when it was in parliament."
    Guy
    University
  13. David
    Matt B Guest
    Oh. Do you also think _all_ cyclists should be blamed for the actions of
    the recent one of their number who slashed the car tyres?
    Why, when making the use of cars safer would achieve the same result?
    Judging each case on its circumstances?
    Do you think "collective responsibility" for the acts of criminals is the
    way of the future?
    So you would support those who campaign for genuinly, safer roads and better
    trained and better educated drivers? And you would attack ill-conceived
    policies which purported to contribute to road safety, whilst complying with
    a "hidden agenda", and relied upon overt spin, misrepresentation of
    statistics and research data, and general hoodwinking of the general public?
    Matt B, Aug 20, 2004
  14. David
    Matt B Guest
    Can you provide some which show that _any_ aren't?
    Up to the point of establishing the cause?
    Enlighten me :)
  15. David
    Matt B Guest
    Do we? Do either stop short of establishing, as far as possible, the cause,
    blame etc, and charging, where possible, those with a criminal case to
    answer?
  16. No. But if there was suddenly an outbreak of thousands of instances,
    then we'd be talking about a suitably parallel example.
    Perhaps - but we can all see the moving goalposts where that's concerned.
    Because it wouldn't. Making it harder to qualify to be able to use a car
    would increase the driver standard and, almost certainly, decrease the
    number of cars on the road. Cars have been getting safer for years,
    doesn't actually seem to be the having the effect you're claiming.
    If, by that, you mean allowing magistrates and judges the ability for
    (much) longer bans and enhanced re-education, then yes.
    I've not called for collective responsibility, I've suggested that
    enough drivers demonstrate enough irresponsibility and lack of ability
    that questions need to be asked about whether the current standards of
    qualification are high enough.
    That's exactly what I've just called for.
    Yes.
    chris harrison, Aug 20, 2004
  17. David
    Matt B Guest
    But, surely, they only need to investigate them as assaults or murder if
    their initial appraisal suggests that they are those type of crimes. Same
    as for other causes of injury or death. If it is obvious that the victim
    was solely resposible for his own demise or predicament, what other action
    should the police take?
    I thought it was the chances of getting caught that was the deterrent.
    What?
  18. David
    Matt B Guest
    Based on what assumption or even what facts? You are implying some sort of
    police complicity or incompetence or what?
  19. David
    Gawnsoft Guest
    Gawnsoft, Aug 20, 2004
  20. David
    Gawnsoft Guest
    Yes, we do. Compare the number of manhours / incident put into
    investigation and inquiry for air, rail and road.
    Cheers,
    Euan
