Best way to travel 5 miles to a train station?
Discussion in 'UK Motorcycles' started by David, Aug 11, 2004.
  1. David
    njf>badger Guest
    No they're not, they're the means those in power, not just the elected
    few, can excuse disarming the general populace to stop them interfering
    with their plans.
    njf>badger, Aug 18, 2004
  2. David
    Gawnsoft Guest
    Germany is not uniformly faster than France.
    Cheers,
    Euan
    Gawnsoft: http://www.gawnsoft.co.sr
    Symbian/Epoc wiki: http://html.dnsalias.net:1122
    Smalltalk links (harvested from comp.lang.smalltalk) http://html.dnsalias.net/gawnsoft/smalltalk
    Gawnsoft, Aug 18, 2004
  3. David
    Gawnsoft Guest
    Far too few.
    They've both been discussed at length on Newsnet. While I could
    google for them, I'm sure you could too.
    Cheers,
    Euan
  4. David
    Gawnsoft Guest
    Where do I go anywhere towards saying that?
    I have on several occasions pointed out that you can cause a death
    criminally without it being so. It's still criminal behaviour, and
    its still a death.
    (Btw, neither are all gun deaths deliberate pre-meditated acts of
    violence)
    Cheers,
    Euan
  5. | Just zis Guy, you know? () gurgled happily,
    | sounding much like they were saying :
    | >> I'm not sure the difference between 34.5 and 35.499
    | >> makes a massive difference to anything much, though. I'm also
    | >> pointing out that it was in no way a "dangerous" offence.
    | > It was more dangerous than had you been doing 30.
    | There were less hazards and far more road space (as well as far wider
    | pavements) than many 40, 50 or even NSL limits.
    Isn't it also about the ability of other people to predict where
    you'll be in n seconds, which is why 35 in a 30 is dangerous.
    Patrick Herring, Aug 18, 2004
  6. David
    Gawnsoft Guest
    Like the poor punter who, with (a legal amount of) alcohol in his
    blodstream, who had just hung up from a call on his mobile, who was
    doing 35% over the limit on the wrong side of the road, and who killed
    a family of four.
    Of course, he didn't cause the deaths with deliberate pre-meditation,
    so I suppose in your view it's not violently criminal behaviour, and
    so in no way comparable to causing death by any other means.
    Cheers,
    Euan
  7. David
    Paul Weaver Guest
    Germany is faster then france in almost all circumstances, there are very
    few kms that are 110 limits.
    But good to know that you realise that blanket speed limits are bad, that
    the M5 Taunton - Exeter should be a different limit then the M4
    Reading-M25.
    Paul Weaver, Aug 18, 2004
  8. David
    Paul Weaver Guest
    No we should go to a system where traffic police regularly patrol and pull
    people up for inapropiate speed, tailgating, lane discipline, etc.
  9. David
    Paul Weaver Guest
    Bit like Murder Vs Manslaughter. Isn't murder premeditated, where as
    manslaughter is killing through negligence, accident, or heat of moment.
    In this case the "punter" should have been done for dangerous driving and
    possibly manslaughter. If a drunk throws a brick off the top of a building
    are they done for murder?
    Compare to that case you mentioned a while back about the driver
    deliberatly reversing a couple hundered yards up the road and into the 2
    cyclists (although why they didn't get out of the way interests me). That
    was murder, pre meditated and all. A much worse situation than the
    "punter" one.
  10. David
    gomez Guest
    How does this follow? The eye/brain predicts future position based on
    perceived *actual* speed [1]
    [1] Except for those of the current batch of West Indian bastmen
    obviously.
    gomez, Aug 18, 2004
  11. David
    Adrian Guest
    Patrick Herring () gurgled happily, sounding much like they
    were saying :
    Besides the fact that 35 is hardly light speed, and thus not exactly
    difficult to predict the future path; and besides the fact that 35 in a 30
    is not exactly completely unknown... What other people? There were none. No
    peds, no other cars.
    Adrian, Aug 18, 2004
  12. David
    DavidR Guest
    to it doing the same speed.
    Of course it will. Bu thow much faster can the Focus go before losing that
    advantage? Answer - not very much.
    DavidR, Aug 18, 2004
  13. David
    DavidR Guest
    Hmm. You didn't notice a big yellow box on a stick so how can we believe
    this?
  14. David
    Gawnsoft Guest
    Where do I say that? I do say that blanket destricted roads are
    unheard of.
    In Germany it's normally varying speed limits on a single given
    autobahn. Often the limit is implemented or lowered due to the
    presence of junctions.
    Cheers,
    Euan
  15. David
    Gawnsoft Guest
    He was much faster, in a large engined 4x4, and willing to change
    direction dramatically to ensure he got them.
    How would they avoid him?
    Cheers,
    Euan
  16. David
    Paul Weaver Guest
    You seem to be a fan of the lower limits arround cities in Germany
    Yes, although not all junctions IIRC. The limit is then removed after the
    hazzard has passed.
    They also have limits on steep downhill stretchs
  17. David
    DavidR Guest
    You think that 35 means 34.5 to 35.5? I don't. I think it means you were
    doing over 35.
  18. David
    Adrian Guest
    DavidR (david.nospam.r_a@t_cwcom.net) gurgled happily, sounding much
    Who says I didn't notice it?
    I just didn't think it'd be set that low.
    Besides, I've already said what the speedo reading was - I didn't realise
    it was reading slightly low after a recent change of tyres, as I'd not
    cross-checked it to the GPS since.
  19. David
    Adrian Guest
    And *I* get accused of splitting hairs...
  20. David
    Matt B Guest
    It sounds like criminal negligence or manslaughter or whatever a similar
    non-motoring wreckless incident would be classed as.
    Can you provide a link for it?
    Do you think that because certain nutters do stupid things with cars that
    all car drivers should somehow be penalised or blamed?
    Matt B, Aug 18, 2004
