Best excuse ever?
Discussion in 'UK Motorcycles' started by Beav, Jun 16, 2010.
  1. Beav
    Beav Guest
    I've just called in at the bike shop for some ear plugs and the owner
    pointed me to a beautifully restored Norton Dommie and asked me what I
    thought could've caused the damage on display.
    No cylinder heads on this bike and no barrels either, but the pistons were
    there for all to see, still attached to their con-rods. Not a pretty sight.
    Both pistons and all rings scored to **** on the back side (f'narr), no
    damage to the front or any other parts. About an inch wide, the score marks
    cover 2/3rds of the total length of each piston. Apart from the scoring, the
    pistons look almost good enough to wank over (shiny, brand spanking new, you
    get my drift)
    The barrels were sat alongside and both were fucked. Badly fucked.
    This engine has only just been rebuilt at a cost of 1200 quid and had new
    oil and none had leaked out (wow:)
    The engine has covered 6 fucking miles since the restoration and there's no
    indication that it's been ragged and overheated.
    The engine builder is (apparently) refusing to accept any responsibility and
    says the cause of the problem is "You got the timing wrong when you fitted
    the electronic ignition" I believe the owner of the bike has chalked it up
    to experience and left it with my pal to sort out, not bothering to force
    the issue with the original builder.
    So... a question.
    How the **** can having the timing "off" cause absolutely zero damage to the
    top of the pistons or the cylinder heads, but completely trash both piston
    skirts and all within 6 miles?
    Btw, the engine was sand blasted prior to building.
    Beav, Jun 16, 2010
  2. Beav
    JB Guest
    I've got a piston in front of me with that exact wear pattern. It came from
    a Yam 450 4-strike 5valve MX motor. The piston has <1 lap use and it has no
    sign of any damage at all except for 2 strips of ~10mm wide on the rear face
    which are well grooved.
    Apparently the cause of this one was lubrication failure.
    It would be good to accurately measure the bores and pistons at various
    points too. The rebore could be wrong.
    JB
    JB, Jun 16, 2010
  3. Beav
    Adrian Guest
    What are the chances of that happening to an engine that's done <6 miles
    since a rebuild which included having the casings sandblasted, eh?
    Adrian, Jun 16, 2010
  4. Beav
    Tim Downie Guest
    Perhaps they should have blown the sand out of the inlets after sand
    blasting?
    Tim
    Tim Downie, Jun 16, 2010
  5. Beav
    Paul - xxx Guest
    Itth a mythtery, as Toyah Wilcox oneth lithped.
    Heh, less of a mythtery methinks, lack of cleanliness more likely.
    Paul - xxx, Jun 16, 2010
  6. Beav
    Beav Guest
    When I was told about the sand blasting, I said "Lets have a look at the oil
    then". Within a few minutes, the oil was in a drain can and it felt like
    liquid sandpaper between my fingers.
    Then I stuck a finger inside the case just below the piston and gave the
    case a wipe. Same thing, gritty as ****. Obviously the original builder did
    a great job of the rebuild, but failed epically in the cleaning before re
    assembly department.
    I've arranged for the engine (once it's been stripped again) to go to
    another pal's place where he's got an industrial sized "dishwasher" designed
    specifically for washing vehicle parts (engines, gearboxes, etc) so there's
    absolutely no chance of the same thing happening again.
    It's a shame too, coz this bike looks truly magnificent. The owner has
    spared no expense.
    I'll go back tomorrow and see if I can get a few pictures of it.
    Beav, Jun 16, 2010
  7. Beav
    Beav Guest
    That's a possibility:)
    Beav, Jun 16, 2010
  8. Beav
    So why wouldn't he have him in court
    Hog, Jun 16, 2010
  9. Ah!
    The Older Gentleman, Jun 16, 2010
  10. Beav
    Beav Guest
    Coz it'd probably take too long and he trusts Rob with the new rebuild, even
    though it's going to cost him. The end result will be an engine that works
    and a bike he can use. If he went down the court route, it'd probably cost
    him anyway, if only in the short term, so he's just decided that getting the
    bike fixed is more important than arseing about with lawyers and the like.
    Beav, Jun 16, 2010
  11. Beav
    Beav Guest
    I know this will sound odd, but I'd have fucked that woman into oblivion
    while she said that :)
    Indeed.
    Beav, Jun 16, 2010
  12. Beav
    Beav Guest
    Indeed.
    Beav, Jun 16, 2010
  13. Beav
    Beav Guest
    Indeed.
    Beav, Jun 16, 2010
  14. Beav
    Beav Guest
    Indeed.
    Beav, Jun 16, 2010
  15. Beav
    Beav Guest
    Indeed.
    Beav, Jun 16, 2010
  16. Beav
    Beav Guest
    Yeah, "Ahh".
    The original builder must be pretty desperate to use the "Your timing was
    set incorrectly" argument.
    Mind ewe, new pistons, rings, and possibly barrels (I can't remember if
    they're liners or just bored barrels) plus labour isn't going to help his
    profits very much.
    Beav, Jun 16, 2010
  17. Beav
    Paul - xxx Guest
    Heh, not odd at all .. ;)
    Paul - xxx, Jun 17, 2010
  18. Beav
    Malc Guest
    Twice eh? The stamina!
    Malc, Jun 17, 2010
  19. Beav
    SIRPip Guest
    It's the tablets, I reckon.
    That, and the use of the vegetarian's solution: celery. You don't eat
    it, of course - you use it as splints.
    SIRPip, Jun 17, 2010
  20. Beav
    celery, along with asparagus is one of the few foods that, eaten in
    sufficient quantity can affect the taste of semen.
    darsy, Jun 17, 2010
