Best Christmas presents received
Discussion in 'UK Motorcycles' started by The Older Gentleman, Dec 25, 2007.
  1. Nothing at all here, nothing, nada, zero. Boo.
    (except for a hangover & continuing manflu).
    Brownz \(Mobile\), Dec 25, 2007
  2. The Older Gentleman
    Des Guest
    No, a far bigger surprise is that uninformed idiots like you still spout
    revisionist claptrap like the above, aimed at the Middle East's only
    democracy that has been fighting for its survival for the past sixty years,
    surrounded (and outnumbered) by hundreds of millions of Arabs who've sworn
    to bring about its destruction and the death of every one of its
    inhabitants.
    I try, I try and I try, but I can see no other reason for this obscene
    biais than simple anti-Semitism.
    D.
    des
    French Biking Vocabulary: http://minilien.fr/a0kg0p
    'Kaiser: "Can you prove to me the existence of G-d?"
    Bismarck: "The Jews, your Majesty. The Jews"'
    Des, Dec 25, 2007
  3. The Older Gentleman
    SD Guest
    AOL. Finally. 'ray!
    | ___ Salad Dodger
    |_\_____/_| ..93550../..25068.../..31928.
    SD, Dec 25, 2007
  4. The Older Gentleman
    SD says...
    Same here, happy happy.
    Lozzo
    Triumph Daytona 955i SE (Niged-out)
    Suzuki SV650 K3 (For sale - email for details)
    Honda CBR600 F-W trackbike
    Yamaha SR250 SpazzTrakka
    Suzuki GSX-R750L
    Suzkui TS50X x2
    Lozzo, Dec 25, 2007
  5. The Older Gentleman
    Spete Guest
    Are you now telling me that there are only kike^H^Hjews in Israel?
    Spete, Dec 25, 2007
  6. The Older Gentleman
    Des Guest
    Israel is =~80% Jewish.
    D.
    des
    Des, Dec 25, 2007
  7. The Older Gentleman
    Do you know what the 'error' I'm referring to was?
    Bwahaha. This isn't about anti-semitism, it's about condemning a
    country carrying out an attack on a neutral vessel and then denying it
    and then the victim in the attack assisting in the cover up.
    Andy Bonwick, Dec 25, 2007
  8. The Older Gentleman
    Des Guest
    No. What difference would it make if I did?
    Which is why you refer to Jews as 'Kikes', presumably.
    If the United States decided that it didn't want to press the matter,
    what's a spotty-faced Brit doing getting worked up about it?
    D.
    des
    Des, Dec 25, 2007
  9. Wotcha.
    My lavatory brush is named Mohammed - and has been for quite a while now.
    May I also point out, that my naming of the aforesaid shithouse brush has
    nowt to do with Mohammed being a prophet - or anything to do with religion
    come to think of it.
    ^..^ Lone Wolf, Dec 25, 2007
  10. The Older Gentleman
    Paul - xxx Guest
    The Older Gentleman wibbled
    Cool.
    Best present I got was sex in the morning and a promise for later ... ;)
    Paul - xxx
    '96/'97 Landrover Discovery 300 Tdi 'Big and Butch'
    '98 Suzuki DR 200 Djebel 'Small but perfectly formed'
    Dyna Tech Cro-Mo comp "When I feel fit enough'
    Paul - xxx, Dec 25, 2007
  11. The Older Gentleman
    Eiron Guest
    It's sad when you have to give yourself a Christmas gift.
    Eiron, Dec 25, 2007
  12. The Older Gentleman
    Cab Guest
    Heheheheh. You ****. :)
    Cab, Dec 25, 2007
  13. The Older Gentleman
    M.Badger Guest
    Cheat it!
    Tap it on the b string. Fix the first finger of the left hand on the third
    fret. Tap the 7th, pull off to the 5th then pull off back to the 3rd then
    tap the 10th.
    Its a bit of a bitch with the timing at first.
    7--5--3--5--10--5--3--5--7--5--3--5--9--7--5--3--5---
    All on b string. A bit of reverb and a not too swampy chorus helps fatten it
    out. Resist too much gain. It hides the timing a little, but sounds shyte.
    The 'Tom Sawyer' bit is a good place to pull a 'rock face'
    e-----------------------|----------------------------
    B-----------------------|----------------------------
    G-----------------------|----------------------------
    D--4--2--0-----0--------|--------------------------2-
    A-----------3-----3--2--|--------------0--2--3--4----
    E-----------------------|--0--2--3--4----------------
    If you are playing along, you can mackle it mostly with power chords and
    deft picking. Most of the work is in the picking hand.
    I can't do the solo.
    M.Badger, Dec 25, 2007
  14. The Older Gentleman
    Spete Guest
    That leaves 20% non-cunts though. This makes the anti-semitism part null and
    void
    Spete, Dec 25, 2007
  15. The Older Gentleman
    Paul - xxx Guest
    Eiron wibbled
    I used a different hand, and one of my other presents was a pair of
    gloves.
    Paul - xxx
  16. *Snigger*
  17. The Older Gentleman
    Snowleopard Guest
    He probably needs de-coking.
    I seem to have a collection of Tommy Lee Jones back catalogue (some of
    which I didn't even know was still available), assorted thrillers,
    heart skewered on a stick, a couple of Jeremy Clarkson's books,
    Kahlua, Jack Daniels, an enormous Toblerone. Oh, and a sugar-induced
    migraine that's somewhat spoilt my drunking plans.
    Snowleopard, Dec 25, 2007
  18. The Older Gentleman
    Ferger Guest
    Des secured a place in history by writing:
    You really, really are tiresomely dull Des. And thick too. I don't often
    exercise the killfile thing, but you've just about worn me out now. *PLONK*
    Ferger, Dec 25, 2007
  19. What kept you?
  20. The Older Gentleman
    Des Guest
    Exactly why do you people feel the need to tell me that you're killfiling
    me? I mean, 'Ferger' ? Who the **** are you, anyway? Have you ever
    posted anything of worth?
    I don't _give_ a flying **** _who_ 'plonks' me. Grow up, you twat.
    D.
    des
    Des, Dec 25, 2007
