[QUOTE="jellybean"] Hi all sorry if the terminology is wrong, I've just bought my first bike and rebuilding it. (A '81 KE125) anyways, I got my new cylinder in the mail yesterday and even though im not really ready to assemble the top end, I wanted to slide it onto the studs just to see what she'd look like. and lo and behold one of the studs is bent. Is there a way I can bend that stud back straight or should I just replace it?[/QUOTE] [URL="http://www.partsfish.com"]www.partsfish.com[/URL] '81 KE125 crankcase fiche shows four 8mm X 70mm studs... It's kind of *hard* to bend an 8 millimeter stud that's less than three inches long. It's about 5/16th diameter. Maybe somebody *dropped* the engine and it landed on that stud? You could try double-nutting the stud and turning the lower nut carefully to see if the stud will unthread. But, for all you know, Kawasaki used Loctite on the stud. It might help to heat the stud with a propane torch. And, maybe you might try welding a nut onto the end of the stud so you can turn it that way. You can get into a world of problems trying to remove that stud if it's corroded into place. Like, you could mess up the crankcase half. Is it really bent *that* far? Can you slide the cylinder over the studs with a little effort? The other three studs that aren't bent should locate the cylinder adequately...
