Battery
Discussion in 'Classic Motorbikes' started by peter, Jan 20, 2005.
  1. peter
    peter Guest
    I have a 12v motorbike battery and need it to power something via
    crocodile clips, my problem is that 12volts is too much! how do I
    reduce the voltage? I was told I can buy something that goes on top of
    the battery,covers the pos and neg and reduces the voltage then I just
    put the clips onto that. But I can't find anything thats meant to
    reduce the voltage.
    Can anyone help:?
    peter, Jan 20, 2005
  2. peter
    Loz H Guest
    How many volts and amps do you expect to be drawing?
    Cheap n dirty way of doing it, unscrew the caps on the battery and tap a
    nail into one of the cells. I forget which terminal to "count" from, but
    that`ll give you 2/4/6/8/10v respectively.
    P.S. You were great in Bedazzled.
    Loz H, Jan 20, 2005
  3. peter
    Shep© Guest
    It depends on what you want to drive off the battery.If the device
    doesn't draw a lot of current you can by a load resistor cheap.If it
    needs more current and a regulated supply then you will need a
    converter of some type and they cost more.More info please :)
    Free Windows/PC help,
    http://www.geocities.com/sheppola/trouble.html
    remove obvious to reply
    email
    Free original songs to download and,"BURN" :O)
    http://www.soundclick.com/bands/8/nomessiahsmusic.htm
    Shep©, Jan 21, 2005
