Battery Woe
Discussion in 'UK Motorcycles' started by oldbloke at work, Oct 13, 2004.
  1. Cage is in for MOT today, so I decide to take the Zephyr to work.
    All togged up and ready to go, will it start? will it buggery.
    All I got was a buzz from the solenoid.
    So, out with the battery charger. Still no joy, the engine would only turn
    over with the enthusiasm of a turgid slug.
    So, off to work I merrily go on the bloody TS50, in the rush hour.
    Do batteries just die a sudden death, or is there likely to be a more
    sinister problem?
  2. oldbloke at work
    Christofire Guest
    What cold weather?
    Christofire, Oct 13, 2004
  3. oldbloke at work
    dwb Guest
    As DNC said, I think the Optimate types tend to put in a low amount of
    charge - I wouldn't completely write off the battery until you've left it
    charging for a few hours.
    Bet you still enjoyed it...
    Before I got an Optimate the battery on the GSX-R would flatten in about 3-4
    weeks, but the battery itself seemed fine. I just left it plugged in when
    not in use.
    Is it still the original battery in the Zephyr?
    dwb, Oct 13, 2004
  4. oldbloke at work
    First thing to do is make sure the terminals are absolutely spotlessly
    clean.
    platypus, Oct 13, 2004
  5. oldbloke at work
    Bump start it, you poof.
    Champ, Oct 13, 2004
  6. Well, I boost charged it for about 30 mins this morning, then gave up and
    left it on trickle charge.
    Just been home for another go, and it still doesn't want to play.
    I am going to get a new battery I think. The one that's on there is prolly
    original.
    Hmm, it's been in the shed though, so shouldn't be that cold. Also, there's
    no alarm or anything draining the battery.
  7. Just been and tried it again after leaving it all morning on charge. No
    joy.
    I think so.
  8. They are.
  9. I did sort of try, but it was too heavy for ickle me.
  10. oldbloke at work
    <sigh>
    Your posting name is completely wrong, you know.
    Champ, Oct 13, 2004
  11. I have been told.
    In my defence though, where I live is very flat, and the Zephyr is very
    heavy.
    Also, I think the battery is so dead it isn't even making any spark at the
    plugs, as I got it to turn over slowly at lunchtime but no sign of starting.
  12. oldbloke at work
    dwb Guest
    Just how fast does one need to be going to bump?
    I tried it awhile back and all I did was cause myself to overheat somewhat.
    dwb, Oct 13, 2004
  13. oldbloke at work
    Chris Soanes Guest
    I managed to get the ZZR going at work the other day, having left it on
    parking light all day. The first bump gave me enough juice to get the
    alarm turned off. The second started it. The trick is to jump on the
    seat as you let out the clutch, or the back wheel just skids.
    Mind you, it has to be said that I *am* 6'5", 17st, and I swim 6km a
    week, on average, plus badminston and windsurfing.
    Tiff
    Chris Soanes, Oct 13, 2004
  14. <salad dodger not to read the rest of this post>
    I so know that feeling. I went to use the trumpet today and it didnt
    have enough charge to even unset the alarm.
    Last week I'd tried to use it but it was flat but with enough to unset
    the alarm but not more than a flicker to the headlight filament.
    I suspect in my case its a sinister problem as it was fullt charged
    and used for two days last week, for a six month old bike it shouldnt
    drop that much in six days.
    Ive phoned truimph rider assist (RAC) [1] who insist that they need to
    send someone out before they can recover it to a dealer so that'll be
    two times I have to sit in and wait.
    [1] free when buying a new trumpet.
    Adie
    Triumph 955iSS / GSF1200 bandit (pending) / GSF600 bandit (for sale) / CG125
    Adrienne M Jenn, Oct 13, 2004
  15. I took the car and a different route to work having heard on the radio
    that the M1 was borked J13-6. If I needed to take a bike there's
    always the 9R (and a CG).
    The way I'm feeling I'm better having taken the car cos some sod has
    given me their germs.
    Adie
  16. Doesnotcompute wrote
    I suppose you get quite a bit of that these days?
    steve auvache, Oct 13, 2004
  17. They are after those days?
    Phil
    Phil Launchbury, Oct 13, 2004
  18. oldbloke at work
    Zymurgy Guest
    Winter, innit.
    They all do that sir. Optimate [1] it periodically if you're laying it
    up.
    Paul.
    [1] Or pull a blinder and get a Yuasa 12v Lead Acid bulk & trickle
    charger in the Maplin sale for £8 ;-)
    Zymurgy, Oct 13, 2004
  19. oldbloke at work
    Ben Blaney Guest
    3am.
    Ben Blaney, Oct 13, 2004
  20. oldbloke at work
    er Guest
    Poof. Tow it with a car would be more like it.
    er, Oct 13, 2004
