Battery Water.
Discussion in 'Motorbike Technical Discussion' started by mike, Jul 20, 2010.
  1. Wot ?? No comment form Krusty ?
    Rob Kleinschmidt, Aug 2, 2010
  2. mike
    ` Guest
    Since you have invoked the spirit of krusty kritter (Krusty never
    posts to rmt),
    the following comments are in order:
    The OP *never* wrote what voltage and RPM his regulator cycled at, and
    still hasn't done so.
    Furthermore, battery *electrolyte* and battery *acid* are two
    different things.
    There are four times when the motorcycle rider adds *electrolyte* to a
    battery:
    1. When first filling up a new battery to the upper level line;
    2. After it has sat for half an hour, fibrous separator plates and the
    spongy lead plates may absorb some of the *electrolyte* so it has to
    be topped up again, with *electrolyte.
    3. When the new battery is almost fully charged, it may be necessary
    to add electrolyte again, bringing the level back up to the full level
    line.
    4. When a battery is being "rescued" from a long period of field
    service without being charged on the bench, the *electrolyte* level is
    brought up to the full line by adding *distilled water*, but when the
    battery is as fully charged as possible, considering its condition, it
    should be topped up with *electrolyte* to the upper level line.
    Going through the procedure of bench charging a used battery and then
    topping it up with *distilled water* after charging is simply
    ignorant.
    `, Aug 2, 2010
  3. Oddly enough though, his description made it clear
    to a number of people that he had an overcharging
    problem. Only one of those who responded seemed to
    not grasp this.
    Agreed. Anybody but a total ignoramus would
    add the distilled water first.
  4. mike
    S'mee Guest
    good number of this learned to add the distilled water FIRST before we
    could legally drive/ride. Besides it's just common sense to do that.
    Doesn't do much good charging a battery if it isn't topped off.
    S'mee, Aug 2, 2010
  5. mike
    ` Guest
    "What we have heah is failuah to commun'cate." ---Strother Martin,
    "Cool Hand Luke."
    `, Aug 2, 2010
  6. mike
    ` Guest
    Your experience with batteries is rather *limited*, isn't it?
    `, Aug 2, 2010
  7. What you have here is a failure to get it, compounded
    by an unwillingness to admit you don't get it.
    Very unsurprising.
    you don't get it.
  8. Yet he's able to grasp that which eludes you.
  9. mike
    S'mee Guest
    yeah, I've only been dealing with them 35 years. No experience at all.
    S'mee, Aug 2, 2010
  10. mike
    ` Guest
    Arguing with you is like arguing with religious fundamentalists.
    It's an article of faith (in spite the obvious facts) with you people
    that NO acid is ever pushed out the vent tube.
    It's also an article of faith that *only* oxygen and hydrogen exit the
    vent tube.
    If that's the case, *why* does the vent tube ALWAYS point DOWN,
    instead of UP?
    When I worked on general aviation aircraft, I had occasion to install
    a battery vent system with a draft tube on the bottom of the vent
    hose.
    A draft tube provides positive venting of the battery box. The tube is
    cut
    on an angle so that turbulence behind the draft tube sucks gasses (and
    liquids) out of the battery box.
    The vent tube pointed DOWN, not up.
    `, Aug 3, 2010
  11. mike
    S'mee Guest
    Oh shut up you moron. You were dead wrong and now in your impotent
    attempts to redirect people from your incompetance you yet again draw
    up lies and strawman arguments. Go **** yourself you uneducated
    incompetant moron...you don't even OWN or ride motorcycles much less
    ever worked on one.
    S'mee, Aug 3, 2010
  12. Not a matter of faith at all. I ran an off-grid house for 10
    years off a lead/acid battery bank and observed over the
    course of 10 years that an annual topping off with distilled
    water and charging restored the electrolyte density just fine.
    I already provided several links on battery maintenance.
    Here's another good one from a lead/acid battery manufacturer.
    http://www.trojanbattery.com/Tech-Support/BatteryMaintenance.aspx
    Lessee now. Who should I believe ? Krusty or the manufacturer ?
    That one's a real puzzler alright.
    So what ? What mechanism(s) do you believe cause
    loss of H2SO4 ? Only ones I'm aware of are spills and
    overfilling, both of which are caused only by stupidity.
    None of the above changes the fact that you misdiagnosed
    the OPs problem and offered stupid and inappropriate advice.
    I only point it out because you may not be aware that
    you do this sometimes and then compound it by getting
    emotionally invested in your incorrect answer.
    Rob Kleinschmidt, Aug 3, 2010
  13. mike
    ` Guest
    When a battery gasses, electrolyte is *lifted* to the top of the cell
    by the bubbles,
    just like crude oil is lifted to the surface by the escape of methane
    gas under pressure, or aquarium water is circulated by a bubble lift
    pump.
    When the bubbles in your battery burst, electrolyte is splattered all
    over any available surface.
    Just look at the top of a car battery that has filler caps.
    There will be a film of electrolyte on top of the battery.
    Just look at the battery cables on cars whose owners don't clean them
    regularly.
    They'll be covered with acid crystals.
    Motorcycle batteries also have a problem with vibration in the battery
    area.
    Vibration causes the electrolyte to spritz at the surface, helping the
    escaping gasses to carry electrolyte out of the battery.
    Furthermore, consider the fact that motorcycle batteries do not always
    remain level, they are being tilted from side to side, sloshing the
    electrolyte at the surface.
    Some electrolyte must surely be lost from a flooded cell lead acid
    battery.
    `, Aug 3, 2010
  14. mike
    S'mee Guest
    bullshit. It's been explained ad nauseum at both a professional level
    and a bubba level and still you continue to deny reality. Damn you are
    one STUPID inDUHvidual.
    you life failure.
    S'mee, Aug 3, 2010
  15. Not enough to significantly affect the electrolyte
    density. As I've said, don't take my word for it.
    Consult any manufacturer's maintenance instructions.
    How hard is that ?
  16. mike
    ian field Guest
    by the bubbles,
    pump.
    ian field, Aug 3, 2010
  17. mike
    ` Guest
    There are lots of questionable urban myths, like only adding distilled
    water to a battery that's low on electrolyte.
    The battery manufacturers just don't want the ordinary customer to get
    involved in mixing electrolyte because of product liability.
    There is also the fact that if there were more knowledgeable battery
    owners keeping their batteries alive for 9 or 10 years the sales of
    new batteries would be reduced.
    `, Aug 3, 2010
  18. I'm in an internet cafe in the Atacama and have just chuckled out loud.
    The Older Gentleman, Aug 3, 2010
  19. I sort of figured we were going to get to a conspiracy
    of evil battery manufacturers to suppress this stuff
    that you're asserting.
  20. <Drain Man mode>
    Bush did it!
    </dmm>
