Battery Water.
Discussion in 'Motorbike Technical Discussion' started by mike, Jul 20, 2010.
  1. Good for you and your shop manual.
    Here's a nice reference on adjusting specific gravity.
    http://www.tpub.com/content/batteries/TM-10-6140-200-14/TM-10-6140-200-140027.htm
    Note the following paragraph.
    "Normally it should never be
    necessary to adjust the gravity, but upsets, jar breakage,
    additions of too much water and careless use of hydrometer
    can result in electrolyte loss and possible reductions of
    battery capacity.Lost electrolyte must be replaced but
    only after it has been determined that charging will not
    restore the gravity to normal when at the recommended
    level."
    So what kind of mistakes were you making which caused
    you to have to add acid to the battery ? Or did this all take
    place only in your head ?
    Perhaps you'd now like to cite your job history again to
    bolster this pretense of expertise.
    Rob Kleinschmidt, Jul 25, 2010
    #81
  2. mike
    S'mee Guest
    You are full of shit. Wether it is idling or not doesn't have an
    effect on if it over or undercharges, in this situation it is
    overcharging. You obviously don't have a clue about these things and
    it would be better for all if you stfu and lett your better discuss
    it. Who know, you might learn something...then again you are a stupid
    uneducable shit sucking racist bastard that never knew his mothers
    face so it's likely that the only thing you are capable is being the
    groups target.
    S'mee, Jul 25, 2010
    #82
  3. mike
    S'mee Guest
    He's an idiot. Been trying to run that troll off of reeky for
    years...about ready to just kill him and be done with it.
    S'mee, Jul 25, 2010
    #83
  4. mike
    S'mee Guest
    and here Krusty the kiddie loving Klown shows his lying skills...I've
    ridden in ALL of those (more than once) the LOACH is the only one that
    was built to a quality and standard of engineering that I would
    consider safe at any speed or altitude. Oh and Krusty once agin you
    lie like a congressman caught with a gigilo's cock in his ass.
    ROTFLMAO you need killing, just as a mercy because you've become
    delusional, deranged and you've got a NASTY case of dementia.
    S'mee, Jul 25, 2010
    #84
  5. mike
    S'mee Guest
    iirc didn't they finally wear out the spar AND the wiring harness?
    I'm pretty sure the lying bastard doesn't even live in califorina.
    S'mee, Jul 25, 2010
    #85
  6. mike
    ian field Guest
    There are just a few simple rules to remember:
    If the electrolyte is getting hot enough to boil away, the battery is almost
    certainly fucked by now.
    If the electrolyte is gassing away on only 500 miles running, its almost
    guaranteed to be overcharging.
    Only top up with distilled water - *NEVER* add acid, except to replace
    spillage.
    ian field, Jul 25, 2010
    #86
  7. mike
    S'mee Guest
    yOU ARE A LYING PEDARAST! Not only that you spend all day shitting
    yoru self in your depends...which is funny because I've family old
    enough to be your parents and they don't need those or walkers or any
    of the stuff that helps your sorry geriatric drug addled self around.
    That's despite a stroke or two, custom harvesting during the
    depression (rice wheat barley etc owned their own gleaners) a couple
    wars, working in the boeing plants. You know patriotic american stuff,
    unlike your sorry drug addled, welfare sucking self.
    S'mee, Jul 25, 2010
    #87
  8. mike
    S'mee Guest
    iirc there was a test aircraft...but unlike krusty and others I can
    say that from memory and I'm pretty sure it's acurate. As to wether it
    was a single motor or more I would have to say just one and it was NOT
    mounted on the wing. But yes, yet again Krusty the Kiddie loving Klown
    is dead (as in get people killed) wrong.
    S'mee, Jul 25, 2010
    #88
  9. mike
    S'mee Guest
    Let's see...this is what boeing has to say about the B-50.
    http://www.boeing.com/history/boeing/b50.html
    I say trust the guys that built it over some schmuck that claims
    california as home and likley doesn't live there AND who also claims
    to know anything about aircraft or motorcycles exept enough info for
    him to say
    "rinngggggdinnngggdinnngggdingrinnnnnnnnnnnngggggggggggggdinnnnnnnnnnggggggggggggggdingdingding"
    "rowwwwwrrrr i'm a bomber" sounds.
    S'mee, Jul 25, 2010
    #89
  10. mike
    S'mee Guest
    Wiki? **** that inaccurate sight. No actually I NEVER trust wiki and
    back check them with at least 2 if not MORE sources.
    S'mee, Jul 25, 2010
    #90
  11. mike
    S'mee Guest
    To clarify the situation and shut that stupid pig fucking dirt farmer
    up...
    and I qoute
    "KB-50J - The Air Force tentatively endorsed the KB-50J program in mid
    1956, because it believed the KB-50s of TAC's aerial tanker fleet no
    longer had both the speed and altitude to refuel modern jet aircraft
    effectively 39 The KB-50J, first flown in April 1957, was still
    powered by 4 Pratt & Whitney R-4360-35 piston radial engines, but
    featured in addition two 5,200-pound thrust General Electric J47-23
    turbojet engines that were installed in pods, suspended from pylons at
    the former locations of the KB 50's auxiliary wing tanks."
    39 aircraft out of thousands...it's like saying that vincent made
    superchaged go karts in 1947(when in fact two of the lads to a dud
    motor gussied it up on a frame then sold it to a chap from blackpool
    and it still said vincent on the fuel tank)
    A KB-50 is NOT a B-50...period.
    S'mee, Jul 25, 2010
    #91
  12. mike
    S'mee Guest
    less than 40 aircraft oooooo... That's like a sheen replica.
    S'mee, Jul 25, 2010
    #92
  13. mike
    S'mee Guest
    less than a dozen...keep digging liar.
    S'mee, Jul 25, 2010
    #93
  14. mike
    S'mee Guest
    Actually it's a CLASSIC proof of cause..but what would an uneducated
    idiot like you know about the basics.
    S'mee, Jul 25, 2010
    #94
  15. mike
    ` Guest
    Thank you so much for proving my point.
    `, Jul 25, 2010
    #95
  16. mike
    ` Guest
    I worked for Hughes Tool Company twice, once in 1969, and again in
    1979.
    The Hughes 500 (OH-6) helicopters were built by crack-smoking cocaine-
    sniffing
    niggers in Culver City who only worked there to get a paycheck so they
    could
    buy drugs and sell them on the street.
    By 1979, HTC had totally lost control of all manufacturing processes
    except for rotor head assembly.
    If I wanted to buy cocaine, the department supervisor was a handy
    source.
    `, Jul 25, 2010
    #96
  17. mike
    ` Guest
    As long as you keep thinking that way, you're going to continue to add
    too much water to your flooded cell lead acid batteries and you're
    going to have to keep replacing them due to sulfation.
    Who ever said anything about adding *acid* to a battery that has a low
    electrolyte level?
    I've been talking consistently about adding *electrolyte* to fully
    charged batteries that have low electrolyte levels.
    Why don't you gays get it?
    `, Jul 25, 2010
    #97
  18. mike
    ian field Guest
    electrolyte level?
    #98
  19. mike
    ` Guest
    Do you like fish sticks?
    `, Jul 25, 2010
    #99
  20. mike
    ian field Guest
