Battery Warning Light ON...
Discussion in 'Motorbike Technical Discussion' started by Queenmfn, Jun 19, 2008.
  1. Queenmfn
    Queenmfn Guest
    1982 Yamaha Seca... yep, it's me... Still trying to figure this thing
    out!
    The battery warning light stays on, but yet the battery is staying at
    12 volts...
    Anyone know why that would be??
  2. Queenmfn
    Mike Corey Guest
    A properly charged battery should read around 13 to 13.2 volts. Clean
    every connection, everywhere, if that doesn't help, look at the charging
    system.
    "War is an ugly thing, but not the ugliest of things; the decayed and
    degraded state of moral and patriotic feeling which thinks nothing is
    worth a war, is worse." --- John Stuart Mill:
    Mike Corey, Jun 19, 2008
  3. Queenmfn
    Who Me? Guest
    So, where, pray tell, did you get that little piece of mis-information ??
    A wet-cell, lead acid battery has 2.1 volts per cell. String 6 of them
    together and you get.......12.6 Volts.
    A properly operating charging system, however, might well read 13-13.2 V. at
    the battery while it's charging but it won't stay at that voltage very long
    after the charge is removed.
    Of course, none of that helps the OP, since, so far, nobody knows what the
    battery light is actually monitoring. Some bikes had a probe to alert when
    the electrolyte was low.
    Who Me?, Jun 19, 2008
  4. Queenmfn
    . Guest
    Yamaha : XJ750J (1982 Motorcycle) had an electrolyte level sensor in
    the original equipment battery. If the electrolyte is low (or the
    sensor is disconnected) the battery light will stay on when the engine
    is running.
    ., Jun 19, 2008
  5. So going back to the original posting, it'd be a good
    idea to check the fluid levels, fill as needed with
    distilled water, place the battery on a charger
    overnight, then check the voltage with the engine
    both stopped and running. Should be about 12.5
    stopped and 13.5 or better while running fast.
    If it won't charge and hold to about 12.5, it's
    time for a new battery. If it'll charge to 12.5
    volts but the charging system can't bring
    it to 13.5, the charging system probably needs
    some attention. If it goes much over 14 volts
    while running fast, there could be a regulation
    problem causing the battery to boil away water.
    Rob Kleinschmidt, Jun 19, 2008
  6. Queenmfn
    MadDogR75 Guest
    Didn't those old Yama's use brush type alternators?
    Check to see they're not too short.
    MadDogR75, Jun 21, 2008
  7. Queenmfn
    zoot Guest
    just replaced a brush in mine. do you have a sensor? the warning is
    about the sensor or the level it's sensing , nothing else. kind of
    pointless with the lines on the side of the battery and all.
    zoot, Jun 25, 2008
  8. Queenmfn
    . Guest
    Yabbot, my 1982 Suzuki GS1100 came with a sensor battery before
    maintenance free batteries were available, and the battery is buried
    underneath the airbox.
    To add water to the battery, the seat, aftermarket horns, side covers,
    gas tank, and air box must be removed.
    The level lines cannot be seen because of the battery box design...
    ., Jun 26, 2008
