Battery problems, troubleshooting help needed
Discussion in 'Motorbike Technical Discussion' started by chris, Oct 7, 2006.
  1. chris
    chris Guest
    Hello:
    I have been trying to troubleshoot an electrical problem on my tractor
    (John Deere 300 with 16 hp Kohler single cylinder) and so far I am
    totally stumped. The problem is this: The battery seemed to be out of
    juice so I had to jump the tractor from my car. The tractor started
    right up and ran.... but as soon as I disconnected the jumper cables
    from the car, the tractor stalled immediately.
    I am assuming the tractor should continue to run on its own power, so I
    started testing the charging system on it. The stator voltage was
    fine, around 30 volts AC. However when I went to check the voltage
    coming out of the rectifier, my multimeter went crazy and I could not
    get any consistent reading when connecting the negative of the
    multimeter to the engine block. It was as if something was interfering
    with the multimeter. But when I used the frame of the tractor for the
    negative, I finally got a consistent reading of around 0.3-0.7 volts
    DC. The negative battery terminal runs directly to the engine block and
    that connection was good. So immediately I assumed the rectifier was
    bad. After connecting a new rectifier still the same problem.
    So next I hooked up the jumper cables again and shut off the car,
    keeping the cables attached.. and the tractor continued to run just
    fine. I checked the voltage across the tractor's battery and it was
    around 14.5 volts. I shut off the tractor with the key and the voltage
    dropped to around 13.5 volts. When I saw this I assumed the charging
    system was working and that my earlier assumption of a bad rectifier
    was incorrect. Then I removed the jumper cables and the voltage then
    showed 10.5 volts. Is it possible that the tractor's battery is bad or
    shorted, causing these issues???
    Thanks in advance for any feedback...
    chris, Oct 7, 2006
  2. chris
    Ken Weitzel Guest
    Hi Chris...
    I suspect that you have one shorted (perhaps intermittently) cell
    in the battery.
    A surefire quick and dirty test would be to switch the battery
    with another if one's available - but NOT with the one from your
    car, unless you have a car available that's older than the current
    computer ones.
    Take care.
    Ken
    Ken Weitzel, Oct 7, 2006
  3. chris
    SAMMM Guest
    a characteristic of the kohler charging regulators is that on a totally dead
    battery, they won't do anything.
    when the battery voltage gets to about 8 volts if i recall correctly,
    they perform well.
    try charging the battery with a battery charger and check the voltage
    for proper charging.
    remember, there may be a current draw on the battery which is
    running it down over time.
    incidentally, which type regulator is in your tractor?
    they come as a small heatsinked unit about the size of a deck of
    playing cards and also a larger unit about twice or 3 times that size.
    the 16 hp magnum twins on up use a smaller unit mounted in the fan shroud
    with 3 push-on connectors.
    i use that type in an industrial app with a transformer to keep batteries
    charged.
    good luck, sam
    SAMMM, Oct 7, 2006
  4. chris
    ehsjr Guest
    You have a 12 volt lead acid battery that reads 10.5
    volts with no load on it. That battery is bad - no
    doubt about it. Replace it.
    Ed
    ehsjr, Oct 8, 2006
  5. chris
    Venus² Guest
    Yes folks if the battery is low in power, you can't expect a sudden
    recovery, it will take at least 1.5 day to charge it. I am periodically
    charging my battery for my unused car in a garage.
    Especially in winter, you need to keep the charge going or your battery
    could
    go dead, it happened to me before. Battery is like a human, it wants food,
    food, food. You can't leave it for 4-5 months without foods then give him
    foods again, it won't work.
    -Cam
    Venus², Oct 8, 2006
  6. I think you lost the ground connection between the engine and
    frame. There ought to be a strap that connects them electrically.
    I had this happen on a diesel, such that the only path to ground
    was back through the glow plugs. Put on the headlights and
    the engine overheats. Cute huh ?
    Rob Kleinschmidt, Oct 8, 2006
  7. chris
    hob Guest
    That says bad alternator/alternator path or bad terminal/connection... but
    since this is the third time I have heard this exact same problem in
    vehicles in two months, and each was fixed by replacing the battery...
    Shorted battery/bad post comes to mind. But onward into the post
    That can
    1) be a multimeter impedance problem. It can't read accurately if it's
    too low an impedance relative to the circuit being measured, or
    2) be a directional problem in reading the rectifier (normal is it reads
    ok one way, doesn't read when the leads are reversed), or
    3) the probe is inable to penetrate the corrosion, etc., on the contact
    point. (Scrape block before touching tip firmly to metal)
    or a combination of the three
    or you were measuring the reference (negative) side of the alternator- which
    means no voltage.
    or you were trying to read AC on DC.
    That level of voltage sounds like the voltage drop across poor cables/from
    high output from an alternator to a battery. It is also close to the voltage
    drop across an alternator diode.
    You were not reading the battery, you were reading the alternator voltage
    output into the tractor circuit.
    Alternators output around 14 volts, fully charged auto-type batteries around
    11.5, give or take a few tenths
    Should have dropped to 11.7 if the battery had been accepting charge and no
    current was flowing in or out.
    First, remember that it's the rectifier path, not just the rectifier, and
    second, voltage does not mean an appreciable amount of charge is going
    into/being accepted by the battery. It could be 14.5 volts and milliamps
    going through the battery
    So before disconnecting, charge was still flowing from the car battery to
    the tractor battery, giving you an extra 3 volts until you disconnected the
    jumper cables.
    Yes. It should read around 11.5/11.7 (memory here) when charged if the
    battery is ok.
    But it also has to deliver amps as well - so just reading 11.5 is not
    enough - if it's outputting the amps of a watch battery it's not ok, but
    reading 11.5 and delivering rated amps does.
    hob, Oct 9, 2006
  8. chris
    chris Guest
    Thank you for the quick response.
    The regulator (rectifier) that I have is smaller one about the size of
    a small deck of cards (engine is a 16 HP Kohler K341AQS). It is
    mounted on the fan shroud, with 3 connectors, as you mentioned.
    I have thoroughly tested everything I can think of as suggested in the
    other posts (checking ground, voltage, etc) ... so I will be taking the
    battery in to be tested and will post the results of what happens.
    Thanks again!!
    chris, Oct 9, 2006
  9. chris
    chris Guest
    I seemed to have found the solution to the problem I posted: a dead
    battery. After replacing the battery (load test failed at the store),
    everything is working fine. And, the output from the rectifier now
    shows about 14-14.5 volts DC, as it should. So it seems that the
    problem all along was that the dead battery was causing the charging
    system to not fuction at all, and made it seem that the rectifier was
    bad.
    Thank you again for all of the feedback. I hope this helps others that
    may find this same problem. Now I have a brand new rectifier that i
    don't need... sounds like Ebay material!
    chris, Oct 10, 2006
  10. chris
    Venus³² Guest
    Well, sounded like I thought it might have been. You left it without
    charging for a while, this might have killed the battery and there will be
    no way to bring it back. I test this theory on a brand new batter with full
    power; it did die one day for not charging it periodically.
    Venus³², Oct 11, 2006
  11. chris
    MadDogR75 Guest
    You were probably right about the rectifier.
    The tractor battery will, if still good, take more than a few minutes
    to recharge.
    10.5 volts could indicate either a bad cell, (from the abuse delt by
    the bad rectifier)
    or a seriously undercharged battery, (from the inoperative charging
    system).
    Try leaving the battery on a trickle-charger overnight before trashing
    it.
    MadDog
    MadDogR75, Oct 17, 2006
