Battery not charging
Discussion in 'UK Motorcycles' started by Kevin Stone, Dec 5, 2010.
  1. Kevin Stone
    Kevin Stone Guest
    Hi,
    Son's CG125, new battery (we think), but it's not holding charge (on mains
    charger), so something broken it...
    Likely cause?
    TIA
  2. Kevin Stone
    Steve Guest
    Is there any acid in it?
    Steve, Dec 5, 2010
  3. Reg/rec. If it's an old 6v one, they are very cheap. Even the later 12v
    ones aren't too bad. But check the connections to the unit first - if
    he's been riding it in this weather it could just be a corroded
    connector block.
    Shove a multimeter on it first. A 6v system should show about 6.8v on
    full charge. A 12v one should show 13.5v. If you're getting that across
    the battery terminals, then it's charging Ok and it's a stuffed battery.
    The Older Gentleman, Dec 5, 2010
  4. Kevin Stone
    Kevin Stone Guest
    Sealed dry unit.
  5. Kevin Stone
    Kevin Stone Guest
    Will check this and voltage - it's a 12v battery.
    Thanks.
  6. Kevin Stone
    Ian Field Guest
    Could be dry now if its been overcharging.
    They have vent valves so excessive gas pressure can escape, but you have to
    pry out the glued in covers and the rubber vent caps to replenish dried out
    cells.
    Might not work on glass-mat gel types.
    Ian Field, Dec 5, 2010
  7. Kevin Stone
    what type of charger? Some sealed types of battery, especially AGM, won't
    recover with older types of charger, including Optimate 1,2 or 3, if they
    have been totally discharged.
    wessie, Dec 5, 2010
  8. Kevin Stone
    Kevin Stone Guest
    A cheaper end one from Argos...
  9. Kevin Stone
    which says "suitable fior use with wet Pb/acid" batteries
    get a CTEK XS800 for about £27 (assuming it is a 12V bike)
    wessie, Dec 5, 2010
  10. Kevin Stone
    crn Guest
    Jumplead the suspect battery to a good one to get enough voltage to
    let the charger take over.
    crn, Dec 5, 2010
