Battery management sustems ?
Discussion in 'Australian Motorcycles' started by Diogenes, Mar 25, 2011.
  1. Diogenes
    alx Guest
    Some sealed batteries are ..really really sealed. ie ultrasonic/etc
    welded shut once charged with gel/liquid.
    Best not pry them apart.
    The " do not open" is a good indicator that it can and should be
    opened up to check no plates are uncovered.
    alx, Apr 2, 2011
    #81
  2. Feeling pretty good now overall. How did I tangle with the armco?
    Easy, the road turned right and I didn't because I was having a
    nap(microsleep) at the time. I woke just as I was about to hit the
    fence. Basically the result of two nights without much sleep. Was on
    the way home from a night camping at Yerranderie. Only doing about
    70kmh at the time. I was intending to take a break but was riding with
    a mate and he was busting a gut to get home, my fault.
    We were there(BMFF) from Fri night through to Sunday, bloody wet.
    Al
    Alan Pennykid, Apr 2, 2011
    #82
  3. Diogenes
    Diogenes Guest
    Know what you mean. I tried doing Syd-Cairns in three days back in
    '83. Nearly died three times doing microsleeps. Woke up on the wrong
    side of the road on each occasion. Very Scary. But I was
    unbelievably lucky each time. Otherwise I wouldn't be here writing
    this.
    Yeah, the mud. I wore boots. Good thing I did. But I had a good
    time.
    Onya bike
    Gerry
    Diogenes, Apr 2, 2011
    #83
  4. Diogenes
    alx Guest
    Can't say I've ever experienced a microsleep whilst riding...driving
    cars..yes but not riding. The thought of a microsleep whilst riding
    scares me even more than in a car.
    Staying on-topic, attach wires from battery (via appropriate trigger
    device and ramped up volts) to testicles. Fear of fried bits may
    banish microsleeps.
    alx, Apr 2, 2011
    #84
  5. In aus.motorcycles on Sat, 2 Apr 2011 04:58:38 -0700 (PDT)
    I have realised I was riding along with my eyes closed thinking how
    nice it was to relax that way.
    I don't think that's a microsleep as such, but it certainly isn't
    recommended!
    Zebee
    Zebee Johnstone, Apr 3, 2011
    #85
  6. Diogenes
    Diogenes Guest
    Linked, no doubt, to an eye monitor inside the helmet which detects
    drowsiness..
    Onya bike
    Gerry
    Diogenes, Apr 3, 2011
    #86
  7. Diogenes
    Theo Bekkers Guest
    No, but it's far less likely. When electrical stuff burns, the stuff that
    burns becomes conductive quite rapidly, thus adding to the burning. This
    extra conductivity is also very highly likely to create an electrical path
    to Earth. The best way to stop an electrical fire is to turn off the power.
    The 30ma RCD is more likely to shut down the power than the 16a circuit
    breaker.
    So yes, you can still have an electrical fire. But at least 95% of
    electrical fires happen in places that don't have RCDs.
    Have you pressed the 'test' button lately?
    Theo
    Theo Bekkers, Apr 3, 2011
    #87
  8. Diogenes
    Nigel Allen Guest
    Only happened to me once when I was (considerably) younger. Riding the
    T150V Trident home from my honeymoon camping in Cornwall. Had a massive
    dental abscess, no sleep for a few days and full of codeine. Fell asleep
    on the motorway at around 70mph in the middle of the night. Woke up by
    the new bride punching me in my kidneys (sets the scene for the next 13
    years :)
    Best part was the dick-head security guard telling me we couldn't sleep
    in the services area car park because it "wasn't allowed" and that I
    should keep riding and get off the motorway. I declined his suggestion
    and fell (literally) asleep at the side of the bike.
    N/
    Nigel Allen, Apr 3, 2011
    #88
  9. Diogenes
    alx Guest
    Don't do that unless you know how to set the clock on the VCR. You
    still have one of those don't you?
    alx, Apr 4, 2011
    #89
  10. Diogenes
    Diogenes Guest
    So, Theo was being a bit of a devil, was he? ;-)
    Onya bike
    Gerry
    Diogenes, Apr 4, 2011
    #90
  11. Diogenes
    Theo Bekkers Guest
    Yes. Mine says "Test Monthly" on it, as I think they all do, but I probably
    only do it four times a year, when I think of it. The test button acts as a
    xx ma leakage path, so it's a real life test. They fail in two ways. If it
    doesn't trip, replace it. If it trips and you can't reset it, same thing.
    I've had one fail in the shed in the latter fashion. Yes, the shed sub-board
    has to have one too.
    The alternative test method is to stick a knife in the toaster, spill water
    on the cordless kettle base, vacuum up that spilt glass of water, cut the
    cord on your power tool with the saw/cutting disc/drill, etc.
    Theo
    Theo Bekkers, Apr 4, 2011
    #91
  12. Diogenes
    Theo Bekkers Guest
    No, I assumed you would understand that the power would go off when you
    pressed the teat button and could deal with that. I know my wife can't set
    the clock on the wall oven.
    If you are afraid to leave a battery charger on overnight you wont be able
    to sleep until you press that test button. And you should.
    Theo
    #92
  13. Diogenes
    Theo Bekkers Guest
    Test, test, test button.
    #93
  14. Diogenes
    F Murtz Guest
    You forgot, stick your finger in the power source.
    F Murtz, Apr 4, 2011
    #94
  15. Diogenes
    Theo Bekkers Guest
    Yes, sorry. I tried to restrict my scenarios only to the most common.
    There's been a furore here in the West for a while because an indigenous
    child died after crawling into a hole in the wall of the family home (???)
    and touching a live wire. The Opposition had a field day castigating the
    Gov't over the affair as they had a retrofit program for RCDs in Public
    Housing. After some investigation and a few weeks it turns out that an
    electrical contractor had signed off on fitting one to this house, and
    presumably billed the Dept. No device was fitted. Nobody appears willing to
    explain how or why there was a hole through the wall.
    Result, one dead child and somebody going to be sued for million$.
    <sigh>
    Theo
    #95
  16. Diogenes
    Diogenes Guest
    I've found that there's usually a power surge when the teat button is
    properly pressed...
    Onya bike
    Gerry
    Diogenes, Apr 5, 2011
    #96
  17. Diogenes
    Diogenes Guest
    Ok, you've convinced me.
    What a novel concept.
    Onya bike
    Gerry
    #97
  18. Diogenes
    Nigel Allen Guest
    7/10 for finding it.
    8/10 for know how to /properly/ press it.
    N/
    Nigel Allen, Apr 7, 2011
    #98
  19. Diogenes
    Diogenes Guest
    Look, I had to say "pressed" to stay within the parameters of the
    story, OK?
    Nipped, nibbled, licked, sucked... whatever... I'm almost too old to
    remember... As it was I had to ask the chick behind the counter at
    the supermarket to refresh my memory...
    Onya bike
    Gerry
    Diogenes, Apr 8, 2011
    #99
  20. Diogenes
    Bill_h Guest
    Been that long since I had sex I can't remember who gets tied up...
    Bill_h, Apr 8, 2011
