Battery Help Needed
Discussion in 'UK Motorcycles' started by Oldbloke, Jun 17, 2004.
  1. Oldbloke
    Oldbloke Guest
    Today I got a call from my lad whilst I was at work. Seemed he was riding
    into town, went around a corner and the bike died.
    Attempts to start it were futile, and the alarm was making a pathetic
    parping noise.
    He managed to push it to my office, and my immediate thought was the alarm
    had become fucked. However, the lights were very dim, and the horn made an
    even more pathetic parp than the alarm.
    This led me to suspect the battery which we removed and inspected. 2 of the
    cells were dry (odd). As the battery was new in November I was pretty sure
    it had some life left in it so we high tailed it to Halfords, bought a
    battery cahrger and deionised water.
    Back at the office we topped up the battery and charged for abot 45 mins.
    When we reconnected the wee beastie immediately greeted us with a cheerful
    ring a dingg dinggg.
    Anyway, it now seems okay, but I am concerned that the battery is not
    charging. Could anyone vaguely mechanically sound advise me on checking the
    charging circuit, and if the battery is not charging what the possible cause
    could be.
    Having challeneged my mechanical skills, the TS now seems to want to test
    any electrical skills I may have.
    BTW, it passed its MOT this week too.
    Dan L (Oldbloke)
    My Bike 2000 Honda CB500
    M'boy's Bike 1990 Suzuki TS50X (Heavily fortified)
    BOTAFOT #140, DIAABTCOD #26
  2. Oldbloke wrote
    The simple check is: do the lights get a little brighter when you rev
    the engine from tickover to a few thousand revs.
    The slightly more complicated version is to check the voltage at the
    battery terminals which should be above 14 ands a bit volts when
    charging.
    From there you get really silly and put a meter in series with the
    battery and see the current the flowing backwards through the circuit is
    moderate number of amps.
    steve auvache, Jun 17, 2004
  3. Checking if it's charging is dead easy.
    Get a multimeter and puit the positive lead on the positive terminal of
    the battery, the negative on the negative, set the meter to "volts" (the
    scale that reads, say, 2-20V rather than 200-1000, or 0.10-3).
    It should read about 13v. As yours is ill, say 12.5v.
    Start and rev the engine. It should read about 13.5-14v when you rev it.
    Anything like 20v and the regulator/rectifier is fecked.
    No increase at all - either the reg/reg or the alternator, or both, are
    fucked.
    The Older Gentleman, Jun 17, 2004
  4. Oldbloke
    We have an endless supply of distilled water from the condensing tumble
    drier in the garage. I'll bottle a couple of pints for you, and you can
    pick them up next time you're passing.
    platypus, Jun 17, 2004
  5. Oldbloke
    Owen Guest
    snip
    FWIW I aalways use taaap water... works fine... :)
    O
    1 Black, shortly to undergo extensive surgery.
    1 Red, undergoing lightweight surgery. -----
    1 Blue, for Power-Ranger baiting. | o |
    Numbers ... | o |
    Stuff ... | ooo |
    Life ... -----
    Owen, Jun 17, 2004
  6. Oldbloke
    Don't do that. If Owen was to drink pure, distilled water ...
    Pip, Jun 18, 2004
  7. Oldbloke
    Eek! "Critters" flashback!
    platypus, Jun 18, 2004
  8. Oldbloke
    Mark Olson Guest
    Oldbloke wrote:
    [snip tale of flat battery]
    Cells going dry indicates overcharging rather than not enough charge.
    I'd be checking the charging voltage at various RPMs. Most likely
    cause of overcharging is a duff regulator. http://www.electrexusa.com
    (click on 'Tech Support') has a good troubleshooting chart for
    charging systems.
    Mark Olson, Jun 18, 2004
  9. Oldbloke
    "Gremlins" perhaps?
    Ace, Jun 18, 2004
  10. Oldbloke
    Martian Guest
    Highly purified water (WFI etc) is very corrosive due to the lack of
    ions and should not be drunk.
    Martian, Jun 18, 2004
  11. Oldbloke
    Martian Guest
    Oldbloke wrote:
    [snip]
    [snip]
    I can recommend the battery power pills the have revived very old
    batteries as well EthylDiaminoTetraAcetic Acid (EDTA) y'see. Swellers
    sig has a link in it which explains it slightly better.
  12. Oldbloke
    Yeah, one of them movies.
  13. Oldbloke
    Sorry, in what way exactly could "lack of ions" cause something to be
    corrosive?
    Ace, Jun 18, 2004
  14. Oldbloke
    it drops the pH level to 5.5 (IIRC) making purified water an acid.
    darsy, Jun 18, 2004
  15. Oldbloke
    Never used power pills but EDTA does have quite a remarkable effect on
    sulphated batteries.
    http://www.mztech.fsnet.co.uk/electrics/elc_edta.html
    sweller, Jun 18, 2004
  16. Oldbloke
    Right, I can see that, as it's had lots of alkiline salts removed, but
    it's not the fact that there are 'no ions' in it that cause this.
    Ace, Jun 18, 2004
  17. Oldbloke
    ordinary water is a solution of lots of things, including a wide range
    of metal ions (water is a great solvent), and fairly obviously at a
    neutral saturation density. If you take all the ions out, not only
    does water become acidic, but the saturation density for a given metal
    ion is obviously zero. So, if you immerse metal in de-ionized water,
    it'll dissolve any free ions on the metals surface i.e. is corrosive.
    That's my understanding of it anyway - a real chemist will be along in
    a minute to point out I'm talking shite.
    darsy, Jun 18, 2004
  18. Oldbloke
    Bill Darden Guest
    Hi Dan,
    Dry cells are an indication that the battery is not being properly
    maintained, overcharged or both. You should load test it, so that
    your dad does not get stuck out somewhere. For more information of
    maintaining motorcycle batteries, please se Section 3 in the Car and
    Deep Cycle Battery FAQ in www.batteryfaq.org. For more information on
    testing batteries, please see Section 4 and for charging, please see
    Section 9. If you need a replacement battery, there are some buying
    tips in Section 7.
    Kindest regards,
    BiLL.......
    Bill Darden, Jun 18, 2004
  19. It was somewhere around Barstow, on the edge of the desert, when the
    Only if your tap is giving out soft water. Hard water spells doom to a
    bettery fairly quickly.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Jun 18, 2004
  20. It was somewhere around Barstow, on the edge of the desert, when the
    You can buy several lifetimes' supply of EDTA from a chemical wholesaler
    for a couple of quid - makes the cost of the packaged version look
    steep.
    GS 850 x2 / SE 6a
