Hi, A newbie to the group, but not a newbie on bikes. Almost all manuals I ever had (except my vintage beamers) told me to unmount the battery before charging it. The manuals tell me that charging the battery while mounted could blow out the rectifier diodes. ############################################ In my opinion, that warning in the manuals only is there because a cheap charger will put out (say) 50 Volts whenever the battery itself is totally defective. (A good battery acts as a zener, limiting the max voltage.) ############################################ Am I correct? BTW: I can set my charger to any max voltage I want plus any max current I want, so I figure that unmounting the battery is not needed because I set the max voltage slightly below the voltage of a fully loaded battery and the max current to 10% of the batteries capacity, which makes the whole thing become a trickle charger in the end, because the current gets lower when I reach the max voltage. Note: I am not talking about spilling acid and such. Rob.
