Battery Chargers
Discussion in 'UK Motorcycles' started by Gavsta, Oct 31, 2004.
  1. Gavsta
    Gavsta Guest
    If you have a device that can be charged on a car battery through the ciggy
    lighter, would it be OK to attach it directly to a car battery charger?
  2. Gavsta
    Mark Olson Guest
    It depends... battery chargers don't [usually] have much filtering,
    and can have significant variation in voltage without a battery
    connected. If the device sucks up a significant amount of current,
    the voltage fluctuations will be less.
    What sort of device are you talking about?
    Mark Olson, Oct 31, 2004
  3. Gavsta
    Gavsta Guest
    A 7.2 volt battery pack for my aeroplane, I fucked up the mains charger and
    my ciggy lighter in the car is only live when the ignitions on.
    I was thiunking of just connectin it direct to my car charger.
  4. Gavsta
    Mark Olson Guest
    Personally, I'd hook a FOAD capacitor across the charger leads and run
    with it. You could also rewire the cigarette lighter so it would be
    always on.
    Along similar lines, I've used PC power supplies as an alternative
    to medium power battery eliminators. I've got a little Peltier effect
    'fridge' that came with an extremely noisy (electrically, as in it totally
    screws up the telly) switching power supply. Replaced it with a PSU out
    of an old PC, totally quiet. No worries about output ripple on a PC PSU!
  5. Gavsta wrote
    Probably, it rather depends on the device.
    steve auvache, Oct 31, 2004
  6. Gavsta wrote
    Nicads? Lead acid? Lion?
  7. Gavsta
    Eddie Guest
    .... and the charger.
    Eddie, Oct 31, 2004
  8. Gavsta
    Greybeard Guest
    Prolly not.
    ITYWF that the current drawn by the battyer charger (1) exceeds that of the
    battery charger (2)'s output. ;-/
    Also, there may well be current/voltage limiters in (1) that may not work
    correctly with a charger (2) being of higher voltage when not connected to a
    hefty battery to smooth it's output.
    (1) nicad {aeroplane}
    (2) wet cell {car chjarger}
    Make sense? doubt it, to maby broadsides this afternoon. ;o)
    Greybeard, Oct 31, 2004
  9. Gavsta
    Abso Guest
    ... and what kind of day the electrons have had.
    Abso, Oct 31, 2004
  10. If you are only charging one set of 7.2 cells, put a pair of crocodile
    clips on the charger lead instead of the ciggy lighter connector &
    connect directly to your car battery.
    If you are going to be charging several sets, then get a leisure
    (caravan type) battery. When I used to race 1:10th off-road buggies we
    mainly used 100 - 150 ah batteries for this (charging 2 sets of cells at
    once at around 5amps).
    Not a cheap hobby.
    Carolyn Preston, Oct 31, 2004
  11. Gavsta
    I got a cheap car battery from my local car parts shop, I use that for
    rapid charging.
    Muck, Nov 1, 2004
