Battery advice please...
Discussion in 'UK Motorcycles' started by stephen.packer, Jan 9, 2011.
  1. So, I'm off to do foolish things in cold weather on the XT.
    I want to give it the best chance to start and so I want a decent
    battery to replace the (probably) 2-3 year old one that's in the bike.
    The stock is a GT9-B4 and I can't see anything else fitting in the tray.
    (150 x 70 x 105mm).
    I'm thinking that the Varta battery is probably a 'better name' than
    Yuasa? (plus it seems to be offering 9 rather than 8Ah).
    Anything else I should look at?
  2. stephen.packer
    wrote in
    this
    http://www.tayna.co.uk/YT9B-4-Westco-Motorcycle-Battery-P3375.html
    click the other makes and compare the cold cranking amps - AGM batteries
    are much more efficient than most other types. Also, they won't leak
    when you do a platypus drift.
    wessie, Jan 9, 2011
  3. stephen.packer
    mark Guest
    I got one of these:
    http://www.westcobattery.com/battery_page.php?bid=44&vid=1&mid=857
    From here:
    http://www.tayna.co.uk/YT9B-BS-Westco-Motorcycle-Battery-P3376.html
    I decided to go on cold cranking for some reason....
    The corresponding Yuasa and Westco both have 115 amp cold cranking.
    The Varta is only 80 I think.
    mark, Jan 9, 2011
  4. stephen.packer
    Have a look to see if it will take a slightly taller battery, in which
    case a GT12-B4 may fit. I've checked the dimensions in my books and
    there's only a height difference of 30mm. It may be worth looking at
    the charging system to see if it will be up to charging a 12A/h battery
    at the same time.
    It's a common upgrade on a Bandit 600, which has an identical battery
    box to the 1200 but with the addition of a rubber pad in the bottom to
    compensate for the lower height GTX9-BS battery instead of the 1200s
    GTX12-BS. They share the same generator and a virtually identical
    wiring system so the charging system is well up to it on them.
    Lozzo
    they churn out)
    Lozzo, Jan 9, 2011
  5. Thanks.
    Hmm... The Yuasa YT9B-BS seems to be the same spec.
    But if I can manage to get another 26mm height in... then I could go
    with the YT12B-BS or similar with a CCA of 190...
  6. stephen.packer
    I suggest giving The Battery Shop in Swindon a call with the
    dimensions. They really seem to know their stuff, & make battery packs
    from scratch if they can't get something to do the job.
    http://www.thebatteryshop.co.uk/
    Krusty, Jan 9, 2011
  7. stephen.packer
    Height difference is 30mm between the 9 and 12. You could aways do what
    I did on my SV650 and cut a rectangular hole in the bottom of the seat
    pan to take the taller battery. The foam was thick enough so I never
    felt it.
    Lozzo
    they churn out)
    Lozzo, Jan 9, 2011
  8. stephen.packer
    Pete Fisher Guest
    The little Westco in the MX5 is certainly proving worth its price since
    I junked the alarm. Cranked it in to life instantly after sitting
    outside in the snow for a couple of weeks unused.
    | Pete Fisher at Home: |
    Pete Fisher, Jan 9, 2011
  9. stephen.packer
    Scraggy Guest
    Scraggy, Jan 10, 2011
  10. stephen.packer
    Is an Odyssey PC-310 the right size? If so I wouldn't look any further. You
    just can't beat them. I'm afraid it's around £100 but you can afford it!
    You might remember my R100RS sat in the airport car park on IoM for nearly 6
    months. I took my Clarks Jump Start pack with me but it might as well have
    been left connected to an aircraft starter pack. The PC-680 was healthy
    enough to power the lights and horn and it kicked off 2nd press of the
    button.
    Hog, Jan 10, 2011
  11. stephen.packer
    Stephen Guest
    Unfortunately the PC-310 won't fit.
    However based on measurements this morning... this should:
    http://www.tayna.co.uk/YT12B-4-Westco-Motorcycle-Battery-P3378.html
    So that's 200CCA and 12AH.
    I don't think the higher capacity (up from 8AH) being an issue for the
    charging circuit if I fit it fully charged, I'm just hoping it gives
    me a better chance of starting in the morning and more 'reserve power'
    should I need it.
    Bit of a pain really because I'm going to have to discard the battery
    restraining 'lid' thing and I've fitted the relay and 'power
    distribution system' (screw-connector block...) to this and have
    secured the cables with hot-melt glue.
    Oh well... it's only time.
    Stephen, Jan 10, 2011
  12. stephen.packer
    I can see it's a sealed unit. Is that an alternative technology solution
    with higher cranking amps like the Odyssey? It's a lot cheaper.
    Hog, Jan 10, 2011
  13. stephen.packer
    Pete Fisher Guest
    It's AGM. The only downside being that if it goes totally flat you have
    to get cunning to resuscitate it to the stage that one of the new style
    electronic chargers (well a pikey Aldi one ayway) will continue to
    revitalise it. Had to do it twice before I finally had the ancient
    Clifford alarm ripped out of the MX5. It seems to have survived the
    experience.
    I don't see higher capacity being an issue for the charging circuit.
    Just take a bit longer. I had a FOAD leisure battery on the camper van
    that always managed to re-chargee after a decent run.
    Cold cranking amps is were it's at for starting. Plus a few more AH
    might get the bike a bit further if the charging circuit goes tits up.
    There's something to be said for true CDI/Flyweel magneto ignition in
    those circumstances as long as there is some daylight left or other
    people to ride shotgun.
    Pete Fisher, Jan 10, 2011
  14. stephen.packer
    Re AGM and charging, throw your jump start box in parallel and bob's your
    auntie
    Hog, Jan 10, 2011
  15. stephen.packer
    Pete Fisher Guest
    Indeed. Or a less sophisticated old style needle on a dial ammeter
    charger for just long enough to jolt it back to a glimmer of life
    Frankenstein stylee. It does then take a fair old time (as in 2 days) to
    trickle charge it back to full capacity with something a bit more
    sophisticated as they warn you when buying one from MX5parts. But if
    fully charged before going in to service that's not an issue.
  16. stephen.packer
    @news.zen.co.uk:
    Same technology as the Odyssey and has a very good reputation at half to
    two thirds the price. US made like the Odyssey rather than cheap Chinese
    shit.
    wessie, Jan 10, 2011
  17. stephen.packer
    Salad Dodger Guest
    When, exactly?
    Well, not exactly to the minute, but to the day would be nice.
    Salad Dodger, Jan 11, 2011
  18. stephen.packer
    I think we depart from Harwich on the 4th Feb and get back on the 20th
    but I may be a day or so out either way.
    Are you going to come and wave us goodbye?
    Andy Bonwick, Jan 11, 2011
  19. stephen.packer
    Salad Dodger Guest
    Oh, I thought it was imminent.
    Don't bank on it.
  20. stephen.packer
    and carefully observe the colours
    wessie, Jan 12, 2011
