Batteries
Discussion in 'Texas Bikers' started by BiffB, Oct 12, 2008.
  1. BiffB
    BiffB Guest
    So I got a short break today and was gonna take the bike for a spin, but
    the battery was dead. Took it out, discovered it was WAY low on water. I
    figure this battery is toast, but it's on the charger and seems to be
    taking a charge.
    Only the second time it's been run down to nothing, but it's two years
    old, and two years seems to be about as good as it gets for batteries
    for me in any vehicle, so I'm leaning towards replacing it anyway. What
    say ye, oh learned ones?
    Also, just out of curiosity, has anyone ever used one of those jump
    starter things that plugs into a cigarette lighter on their bike?
    BiffB, Oct 12, 2008
  2. BiffB
    louie Guest
    The 2 year service you are getting for 'any' vehicle needs to be looked
    into. Of the vehicles I've dealt with only PWC's had a short 2 year battery
    life. Some Honda m/c owners I know have had 5 year battery life.
    Are you operating these vehicles often? Can you check you charging output?
    Do you buy a specific brand of battery? Is Jerry siphoning your juice?
    Corroded battery/ground connections sometime allow current out for starting,
    lights, etc. but will not allow proper charging. Clean'um.
    We can clear this problem up for you Biffy, if you stick with us here a bit.
    I suspect something within your charactistics. Remember constructive
    criticism is sometimes constructive.
    No, and I do not like that procedure at all. It is way too poor people.
    ....louie 12.7v
    louie, Oct 12, 2008
  3. BiffB
    BiffB Guest
    Well, the average HAS seemed to increase since I stopped buying
    batteries from Autozone. My batteries get a lot of "city" type driving
    on them. Frequent starts, short trips. Kids who leave the interior
    lights on. Stuff like that.
    No corrosion on the bike battery.
    Yes, I am sure this is due to a weakness in my constitution.
    It seems like a bad idea to me, I was just curious. Always looked like a
    good way to make a whole bunch of stuff under the dash to start smoking.
    BiffB, Oct 12, 2008
  4. BiffB
    redshad Guest
    Louies batterys last so long because he keeps his conditioned. That
    seems to provide long battery life. The way you achieve this is to
    turn your key on or to park and walk away. Go read the newsgroup or go
    visit Harbor Freight for a few hours. That should drain your battery
    enough that your bike wont start. Hook up a battery charger to bring
    battery back up to full charge and you have conditioned your battery
    for long lasting life.
    Redshad
    redshad, Oct 12, 2008
  5. BiffB
    louie Guest
    Redshad
    I do use the full range of my battery, at times.
    ....louie
    louie, Oct 12, 2008
  6. BiffB
    louie Guest
    Lucky for you, with that stripped down bike.
    ....louie
    louie, Oct 12, 2008
  7. BiffB
    redshad Guest
    Bring that motor to Louies and we will weld you one on. It will
    increase the value of your bike having 1 add on.
    Redshad
  8. BiffB
    BiffB Guest
    When's Louie's next maintenance day? I got the battery charged and the
    oil changed, next up is brakes and a valve adjustment. Those frighten me
    a little. I may need someone to hold my hand.
    BiffB, Oct 12, 2008
  9. BiffB
    Mr. JayT Guest
    BiffB816 wonders, and says this: ?-
    ''Also, just out of curiosity, has anyone ever used one of those jump
    ==yep. Up on Willamena mtn. They had one at the Lodge,it got mine
    started, I had left the key on. When I got home, I purchased one, and
    have used it numerous times, around the Farm.
    HTH MrJayT-
    Mr. JayT, Oct 13, 2008
