Batteries And Stuff
Discussion in 'UK Motorcycles' started by Steve P, May 7, 2004.
  1. Steve P
    curium Guest
    Wouldn't the optimate indicate whether the battery was holding a charge or
    not?
    curium, May 7, 2004
  2. Steve P
    Steve P Guest
    That's what I thought, unfortunately I was only out for about 40 minutes
    last night and 10 of those were pushing the bike back from the chippy :)
  3. Steve P
    Steve P Guest
    Good point and to be honest I should perhaps have RTFM. Thing is I found
    taking it off the Optimate leaving it for an hour or so and then
    plugging back in and the charging LED came on. However the brand new
    battery on my GPZ500 used to do that as well so I figured it was just
    'topping' up.
  4. Steve P wrote
    40 minutes. an hour, what is the difference? The magic word is 'about'.
    If your charging system is working, then even a fully flat but otherwise
    sound battery should start and run your bike after as little as 5
    minutes at normal road speeds, whatever they are. A whole hour just
    makes sure it is filled right up to the top.
    steve auvache, May 7, 2004
  5. Steve P
    Steve P Guest
    Unless the battery isn't holding the charge anyway which I think could
    be the problem. I'll see tomorrow anyway.
    I'm actually starting to suspect that it might be the charging system
    but my testing at lunchtime was inconclusive.
  6. Steve P wrote
    Don't forget that if you have a meter you can see how the charging
    system is working by putting it in series with the battery and watching
    the Amps flow through it. It should be enough to ruin the meter.
  7. Steve P
    Steve P Guest
    It's a kakky pikey meter anyway. The inconclusive bit is because it only
    measures up to 12v DC.
  8. Steve P wrote
    Which wouldn't be an issue if you had even half a clue about things
    basic and electrical and a couple of resistors of equal value.
  9. Steve P
    Mark Olson Guest
    I think old Bill Occam should be hitting redline about now...
    Of what possible value would such a scheme be? Surely it would be
    simpler and make more sense to avoid charging problems at low RPM
    by *not* artificially dumping the excess alternator output[1] until a
    certain RPM is reached.
    Especially considering that the Suzook alternator is a PM design, and
    dumping current into the battery is hardly any more stressful to the
    stator than dumping it to earth.
    I think Haynes are doing their best in this case to live up to the
    'BOL' moniker.
    [1] IIRC the typical PM alternator regulator uses thyristors to shunt
    one or more of the stator's phases to earth. E.g., here is the SV650
    charging system schematic, AFAIK the GSX-R[750|1000] are similar.
    http://www.visi.com/~olsonm/sv650_charging.pdf
    Mark Olson, May 7, 2004
  10. Steve P
    Bill Darden Guest
    It could be either the battery or the charging system, so you are
    smart checking the alternator voltage first because they both work
    together. For additional information on testing your battery, please
    see Section 4 in the Car (including Motorcycle) and Deep Cycle Battery
    FAQ on www.batteryfaq.org and Section 7.8 for buying tips for
    replacement a battery..
    Kindest regards,
    BiLL........
    Bill Darden, May 8, 2004
  11. Ah, well, here we run into a problem. You're arguing from
    a position of knowing things, and I'm arguing from a
    position of ignorace. So I shall just get my coat...
    William Grainger, May 10, 2004
  12. Steve P
    Mark Olson Guest
    When someone at work suggests a meeting to hammer out the details of
    a circuit design, etc. I usually respond with "Oh, so we can pool
    our ignorance? Good plan."
    Mark Olson, May 10, 2004
  13. heh. circuit design stuff here is generally left to one person,
    and generally works nicely because of it. When two people are
    designing bits that are meant to talk to each other...
