basic questions from a newcomer
Discussion in 'Classic Motorbikes' started by PePe, Oct 17, 2003.
  1. PePe
    PePe Guest
    As in the title, I'm a complete newcomer in oldie bikes and restration, though the itch has been there sometime, it needed a scratch.
    So, I bought what I call a 'project', fairly complete, and I sourced an owners manual, the parts catalogue and a Clymers manual too. So far so good.
    The question now arises: how to tackle the 'project' ie where to start? Engine? Frame? Wheels? What?
    Some things about the bike:
    It's a Kawasaki KDX175 enduro, I know, not very whaaw, but we have to start somewhere, and it was a deal I couldn't turn down (love dirtbikes, love twostrokes, allmost free).
    It was running when I bought it, but on the first 'test' I lost a great deal of oil and it stalled. The problem might be severe I guessed, but it still turns over, and I noticed the sparkplug to be loose, fixed that, fixed the leak too. But now I'm afraid to fire it up...
    Other problem: the rims are alloy anodised DID's, suffering from (very) minor pitting. I want them cleaned, is it possible to sand them to a satin sheen like anodised? What to use to protect them from powdering up? Clearcoating seems not a good option for a dirt bike...
    Another one: frame, powder or spray? Wheel hubs: same question.
    For the most of it, I know what I want, and basically got down how to do it (or get it done), so the 'plan' seems OK. But for some reason I can't think of a decent order to deal with every chore in a logic way. Isn't it silly to get the frame powdercoated, the wheels relaced etcetera, when you're in doubt about the engine? So, start with the engine then? Do I keep it in the frame (a complete bike would be easier to test) or do I take it out?
    Maybe it's just beginners scare, I don't know, but a hint (and some encouraging words) could get me on track.
    Many thanks allready!
    Peter
    PePe, Oct 17, 2003
  2. <snip>
    Try again.
    The Older Gentleman, Oct 17, 2003
  3. PePe
    PePe Guest
    how 'bout this?
    Peter
    PePe, Oct 18, 2003
  4. not got a W-reg with the letters MUD in the number, is it?
    nice little bike. more grin-factor than almost anything else I've met, when
    running right... ISTR the one mentioned above was reworked by removing the
    head gasket, lapping the head onto the barrel, and went very well.
    The only thing about it is that being designed as a competition bike, you
    tend to want to rebuild the engine fairly frequently. But it loved being
    thrashed.
    Austin Shackles, Oct 18, 2003
  5. text on my screen... mind, there was some sort of attachment, but I never
    look at those :)
  6. Ah! I can read this now!
    Excellent bike. Good price, too.
    I'd find where it's leaking from and fix that. A crankcase leak is bad,
    bad news if it's severe. A two-stroke leak potentially nasty, too - or
    does it run on pre-mix?
    You can have them vapour blasted, or simply get the wheels rebuilt with
    new rims. As you'd have to remove the rims for vapour blasting anyway
    you might as well simply go for new rims (and spokes). Wheel rebuilding
    costs about a hundred quid a wheel with new rims & spokes.
    Powder coating is cheap and easy. Durable, too.
    Well, I've just gone this route with the Honda ST70 in my sig. I left
    the engine until last, and didn't even polish the cases because I knew I
    could always get a stepthru engine to replace it if it was knackered,
    and smartening it up would be a waste of time if it was dead.
    The KDX is a 2-stroke single and there is no simpler kind of engine to
    pull apart and rebuild, so I wouldn't worry. Worst it's likely to need
    might be new crank bearings and a rebore. And it's quite rare, so your
    chances of finding another replacement engine are slim.
    The Older Gentleman, Oct 18, 2003
  7. PePe
    PePe Guest
    ---SNIP---
    It runs on premix, yes. I found that it was leaking from the kickstarter
    shaft in the right hand
    engine cover. It's cracked. I found another one, and hope this will solve
    the problem.
    ---SNIP---
    My guess is that a couple of hundreds is way too much for this kind of bike,
    no?
    My option was to have then blasted or sand the myself. I want to keep this
    project as cheap as
    possible, because it's my first one (so I might screw up halfway).
    ---SNIP---
    Until last you say, does that mean the very mast? My idea was to get it back
    in running order first (in the frame), then tackle frame and other things
    around the engine, than an engine-rebuild and touch-up.
    Rare? does that effect on the value of the bike? If it would be let's say a
    1.000 pound bike after restoring it, I wouldn't mind digging a little deeper
    in the wallet and spend that amount on it. Not if it was to be a sorry bad
    oerforming sh*te only worth a fiver. It's rare maybe, but my guess is that
    nobody wants it :)...
    Peter
    PePe, Oct 19, 2003
  8. Generally, with old air-cooled two-strokes, the engine is the cheapest
    thing to sort out. What costs is cosmetics - paint, chrome (not that
    there is much on a KDX), wheels, chassis components like forks and
    shocks. Look at it this way - just what the wheels will cost to rebuild
    will cover a crank rebuild, new main bearings, a rebore and new piston
    (and it's very unlikely to nee dmore engine attention than this).
    I have spent ukp800 on my Dax, and that was *all* on cosmetics and
    chassis parts (oh, and a new exhaust).
    Not in this instance. A KDX is a desirable competition machine that can
    be used on the road. It's just that fewer competition bikes than pure
    road bikes find their way to market.
    A really good condition restored KDX175 will fetch close to a grand,
    yes. They are sought-after quality bikes.
    The Older Gentleman, Oct 19, 2003
  9. PePe
    Triffid Guest
    IME, powder coating leaves you with a gorgeously shiny, new-looking frame,
    and a large pile of bitz that aren't fit to share its garage space. Frame
    then hangs on string from roof for some years, whilst the bitz get ignored
    in their boxes whilst waiting to be used as spares on that H2 that you got
    because 'it must share some common parts'.
    Triffid, Oct 19, 2003
  10. PePe
    PePe Guest
    here in Belgium; every new owner has to register the bike again, so there is
    no link between numberplate and ride here (tracing can be done however with
    the owners registry papers, that keeps the names of the former owners). But
    you gave me a hint, since I know the girl who hands out the license plates,
    I'll try to get my hands on a MUD-175, that would be a top-job. But first,
    let's get that screamer back to screaming.
    as a non-english person (and not that great in shorts, because of silly legs
    probably), what would ISTR mean?
    thrashing is my main goal, caonstantly rebuilding it will be a nice
    side-effect :)
    Thanks Austin!
    Pepe
    00 Ducati M900 bellanera- 76 Honda CB250 cappucinoracer - 82 Kawasaki KDX175
    greenscream
    PePe, Oct 21, 2003
  11. I Seem To Recall
    (in other words, I think, but I am not 100% certain)
    The Older Gentleman, Oct 21, 2003
  12. PePe
    PePe Guest
    WTYKS! (Well, Thank You Kind Sir!), for all hints and tips that is...
    PePe
    PePe, Oct 21, 2003
