Bar end removal.
Discussion in 'UK Motorcycles' started by Gavin, Apr 11, 2011.
  1. Gavin
    Gavin Guest
    Donks ago I dropped the GSXR, and scuffed up the bar end.
    I have got some new ones and got the left one swapped over with no
    issues. I cant however, get the right one off. The screw spins (as does
    the end) but it never undoes, it actually feels like the rubber bung bit
    is spinning round inside the bar.
    Any ideas how to get the thing off?
    Gavin.
    For the fast road: Suzuki GSXR600K1
    For the slow road: Moto Guzzi California Aquila Nera
    For the track: <gone>
    For everything else: Citroën Berlingo
    Twitter: http://twitter.com/gavin_wilby
    Blog: http://eekafreek.com
    Gavin, Apr 11, 2011
  2. Gavin
    ginge Guest
    Given you have new bar ends already you could try the destructive
    approach...
    Angle grinder the head off it, slide the bar end over the remaining
    thread.. attack with mole grips and gusto.
    ginge, Apr 11, 2011
  3. Gavin
    zymurgy Guest
    If it's scuffed up anyway, can you get some pipe or mole grips on it
    and put some lateral force on it (rather than twisting) whilst you
    turn the screw ?
    Paul.
    zymurgy, Apr 11, 2011
  4. Gavin
    Nige Guest
    Gav, pull it out as you turn the screw, use some force via molegrips.
    Nige, Apr 11, 2011
  5. Gavin
    Gavin Guest
    Cheers all, Ill man up and use a bit of force on it.
    Gavin.
    Gavin, Apr 11, 2011
  6. Gavin
    Nige Guest
    Pussyfart.
    Nige, Apr 11, 2011
  7. Gavin
    crn Guest
    BTDTGTTS.
    Angle grinder to make a slot to get a grip, then a slide hammer to
    pull it out.
    crn, Apr 11, 2011
  8. Gavin
    If you're turning the screw by hand, use a drill instead. The rubber
    will either get hot enough to grip the bar, or wear enough to pull out
    easily.
    Krusty, Apr 12, 2011
