Bandit parts prices
Discussion in 'UK Motorcycles' started by Eddie, Oct 15, 2004.
  1. Eddie
    Eddie Guest
    I had a look at a colleagues Bandit 1200S last night, with a view to
    buying it (unless ogden pulls his finger out and replies to my email...)
    Looks in very good nick, especially considering it's a P-reg.
    As a result of a very low speed drop, the front off-side indicator is
    slightly bent, there's a scratch on the engine casing and exhaust and
    the brake pedal could do with replacing, but I'm not too bothered about
    any of that.
    It's already got a front mudguard extender and rear hugger, and looks
    *very* tidy. Previously owned by a sergeant in Durham Police.
    One major bargaining point that I want to check out: the left hand side
    panel has a couple of 1-2" vertical cracks along the bottom edge,
    directly below the seat. The owner thinks they were caused after a heavy
    landing (he's a big lad, which probably doesn't help).
    So... how uncheap is a side panel for a P-reg Bandit 12? In black, of
    course.
    Any suggestions for what sort of offer I should make?
    Eddie, Oct 15, 2004
  2. Eddie
    Eddie Guest
    Nah, it's actually the bracket behind the fairing, so it'll bend
    straight if you can be arsed to take the fairing off.
    Black spray paint, ~£5
    Polishing kit, free.
    60 quid for a new one, apparently.
    Oh, absolutely.
    I had a quick look, couldn't see anything. He is a *big* lad, so I think
    it was just a rough landing.
    Cheapest he found on Autotrader was ~£1750 with 37000 miles - his only
    has 23000.
    Ummm... didn't look that close, to be honest. Not sure if I'd have
    noticed in underground car park lighting - need to see it in sunlight,
    really.
    Eddie, Oct 15, 2004
  3. Eddie
    "Heavy landing" ? Has he been going over motocross table-tops with
    it?
    Champ, Oct 15, 2004
  4. Eddie
    Eddie Guest
    This is what he told me:
    New Chain & Sprockets in May 04
    New Oil & Filter every year (min once a year)
    Just taxed last week
    MOT May 05
    Tyres looked like there was plenty of life in them.
    Yeah... I was thinking 2 grand, minus the cost of a new side panel.
    Eddie, Oct 15, 2004
  5. He could have done 20,000 miles in that time!
    Convenient for you not to have to buy some until next year but that's
    only worth £60 on the day.
    Whinging Courier, Oct 15, 2004
  6. Eddie
    Ben Guest
    45 quid for one for my GSXR750, which I'll put money on is the same
    one.
    From http://www.suzuki-spares.co.uk/ good next day service as well.
    Ben, Oct 15, 2004
  7. Eddie
    Heh, I'd bet that most bikes don't do that in a year. On the Bandits,
    the manual says that you should change the filter every other oil change.
    <snip>
    Muck, Oct 15, 2004
  8. Eddie
    Eddie Guest
    He hasn't. Chain and sprockets looked very healthy.
    I know - it was just in the list of things he told me.
    Eddie, Oct 15, 2004
  9. I used to change the filter with every oil change every 5,000 or so
    miles, still do.
    A genuine filter is only about £8 and I get a discount at the place down
    the road.
  10. Eddie
    5000? That's far too many miles in between oil changes for a Bandit.
    Muck, Oct 15, 2004
  11. Eddie
    DR Guest
    Really? I'd go with the 4000 mile service intervals myself, but I'm
    sure that 5000 isn't too bad; it's supposedly one of the most
    abuse-resistant engines ever made, isn't it?
    DR, Oct 18, 2004
  12. Eddie
    DR Guest
    If you want to go halfers on a proper Suzuki engine black touch-up
    paint, let me know.
    Oi! DNC! Magnesium alloy, on a Bandit? Since when?
    DR, Oct 18, 2004
  13. Eddie
    I'd think so, seeing that it was designed as a 750cc engine. I don't
    leave my Bandit for more that about 3000 miles in between oil changes /
    valve adjust, depending of what time of year it is, and how I've been
    using it.
    Muck, Oct 18, 2004
  14. Eddie
    Heh, that may be the last 20,000 miles the engine would do though.
    Muck, Oct 18, 2004
  15. Eddie
    Tell you what, why don't you try it with you bikes.
    Muck, Oct 18, 2004
  16. Eddie
    Salad Dodger Guest
    I tried it on the CBR1000 for over 20k miles.
    Sounded sweet as a nut when it did get changed.
    | ___ Salad Dodger
    |_\_____/_| ..73063../..16589.../..3180./.19406
    \|^|/ ANORAK#17 IbB#4
    Salad Dodger, Oct 18, 2004
  17. Eddie
    Ginge Guest
    Assuming a new filter went on and the oil was good semi-synth I can't
    see too much wear occuring on most bikes, sure the oil may be on it's
    last legs by 20K, but I'll bet it still lubricates effectively.
    Look at the fact with modern oil most a standard car has service
    intervals are now 20K apart, mechanically little about engines has
    changed in the past 10 or 15 years, but the oil technology has improved.
    Ginge, Oct 18, 2004
  18. Eddie
    Ginge says...
    My Golf needs servicing every 30K miles. I top the oil up in between
    services, but that's it.
    Lozzo, Oct 18, 2004
  19. Eddie
    I've alway understood that the problem with oil was not that it got beat to
    shit by the engine, but that it got dirty - filled with stuff ground off the
    engine, combustion products, black sludge etc.
    And filtration, presumably.
    platypus, Oct 18, 2004
  20. Eddie
    Ginge Guest
    Blimey, 30K does sound a bit far apart for the way I treat cars.
    I've not done a lot of mileage in the past 12 months having worked at
    home a lot. So, I was a little surprised when Vauxhall phoned me up a
    few weeks ago to say "Your car is due a service - it's 20K or every
    year"
    "Yeah, ok.. you can check if there's enough oil in it,[1] and the plugs
    probably need a fettle." I replied.. "the clutch might have seen better
    days too.."
    "Ok Sir, we'll book you in."
    Company cars, don't you just love them?
    [1] I don't think it'll have dropped after only 10K, there's no sign of
    a leak on the driveway..
    Ginge, Oct 18, 2004
