Bandit Owners (past or present)
Discussion in 'UK Motorcycles' started by David Thomas, Nov 22, 2003.
  1. David Thomas
    David Thomas Guest
    Wonder if this fountain of knowledge can help:
    On a Bandit N600, does the clampy thing and heatsheild wotsit (sorry about
    the technical jargon) drift off the the downpipes at the collector box or is
    it welded on?
    I wanted to take it off and clean it all up whilst fitting the new can
    Ta, D
  2. David Thomas
    jsp Guest
    Are you sure you mean down pipes? The heatshield hides the join between
    the end can and the collector box.
    It is a permanent fixture welded to the exhaust. I can't recall if it's
    welded to the end pipe or the collector box, though.
    It is also a prime candidate for rusting. I had to remove mine and
    replace with a stainless hose clip and replacement shield (banditmania
    supplied)
    John
    SV650
    Black it is
    and naked
    jsp, Nov 23, 2003
  3. David Thomas
    David Thomas Guest
    Thats the one I mean,
    hmmm I won't try and drift it off then, I just wasn't sure weather it was
    welded or stuck.
    Many thanks, David
    David Thomas, Nov 25, 2003
