Bandit Good news/Bad news
Discussion in 'UK Motorcycles' started by BGN, Sep 4, 2006.
  1. BGN
    BGN Guest
    Good
    I found the source of the annoying rattle fron the front end of the
    bike. The RHS bar-mirror is rotating but when I touch it with my
    finger it stops and so does the rattle.
    Bad
    The knuckle of my gear selector 'fell out' last week and yesterday
    started it full time and did it no less than three times on the six
    mile journey to work.
    Angle 1: <http://www.bgn.me.uk/bike/b6/gear1.jpg>
    The gear selector attached to the foot peg connects to that long rod
    so when you push the pedal down or up it changes gear.
    Angle 2: <http://www.bgn.me.uk/bike/b6/gear2.jpg>
    There's a knuckle on the back of the gear selector pedal that goes
    into the round rubbery bit on the rear end of the rod which now falls
    out.
    I took it apart at work today and can't see anything missing, but
    there is something that I assume was rubber in there at one point and
    a round washer (although it could equally be described as a circle
    wire) which isn't quite continuous anymore.
    I went to Alford Brothers during my lunch today and described what was
    happening and they informed me I'd need a new gear selector unit as
    the bit I need that goes on the knuckle isn't available separately and
    it would cost me about £39 new including VAT but excluding fitting.
    I haven't ordered it yet, but it's due for a service in a week or so
    anyway but do you have any suggestions as to what is missing from what
    knuckle joint thinger? Is it just a piece of rubber?
    BGN, Sep 4, 2006
  2. BGN
    ginge Guest
    No, pull the rubber back and you should see it's metal on metal.
    ginge, Sep 4, 2006
  3. BGN
    ginge Guest
    Oopps hit send too early....
    What you should see is one bit that is bowl shaped, and another bit that
    it ball shaped and sits inside the bowl, the 2 shouldn't pull apart.
    ginge, Sep 4, 2006
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, BGN
    What you need is a rose joint and IIRC the last one I bought was about
    three quid.
    Wicked Uncle Nigel - Podium Placed Ducati Race Engineer As featured in
    Performance Bikes
    Wicked Uncle Nigel, Sep 4, 2006
  5. BGN
    BGN Guest
    I pulled it apart yesterday at Rod's place and extracted a load of
    dirt which could have been perished rubber or just shit from 8 years
    on the road.
    It is metal on metal but the two pull apart and come apart of their
    own free will. Which begs the question, how did they get them
    together in the first place?
    BGN, Sep 4, 2006
  6. BGN
    BGN says...
    Sounds like you need a new gear lever and knuckle. They do wear out,
    mine's really sloppy now and I expect to have to replace it or repair it
    at some point in the near future.
    I'd be a bit concerned about how close your chain runs to the centre
    stand if I were you, it looks like it's touching it and picking up all
    the nasty gritty shite that's sitting round there. The chain looks
    awfully shiny and dry on the inside of the side-plates and rollers,
    considering the huge amount of gritty old chain lube kicking around
    everywhere else. Mine always looks dark and wet in those places, not
    clean and shiny like yours.
    Lozzo, Sep 4, 2006
  7. BGN
    ginge Guest
    Looks like the result of a scottoiler turned up way to high, if you ask
    me.
    ginge, Sep 4, 2006
  8. BGN
    BGN Guest
    I'll get a new one ordered shortly then.
    The centre stand sits higher up than normal due to the aftermarket
    exhaust. From inspecting SeanH's pipe there's a little bit on which
    the centre stand normally rests which is lacking on mine now.
    I do have to agree on the chain being gritty and horrid looking. I'm
    going to clean it this week (promise!) and get rid of some of the shit
    that surrounds it.
    I use chainsaw oil in the Scottoiler and when it ran out of oil that
    centre of the chain got all dark and dirty but as soon as I filled it
    up again the centre went all clean and shiny so the Scottoiler is at
    least providing enough lubrication to make a difference when it has
    oil in it. True, it's on the 'minimum' setting still from summer when
    the oil got so warm it started to drip out of its own accord.
    Infact, I think I'm going to clean it now.
    BGN, Sep 4, 2006
  9. BGN
    BGN Guest
    It's on the minimum setting. I'll get some 'proper' green stuff when
    it's serviced to see if that does any better. If not then perhaps a
    nozzle has fallen out sometime.
    BGN, Sep 4, 2006
  10. BGN
    Dan L Guest
    <snip>
    You need to get that stand to sit a bit lower in the up position. As Loz
    said, it's too close to the chain.
    I had the same problem when I changed the can on my old CB500, and had to
    change the bump stop on the new can for the original one off the old can.
    Dan L (Oldbloke)
    Space in shed where NSR125 used to be
    BOTAFOT #140 (KotL 2005/6), X-FOT#000, DIAABTCOD #26, BOMB#18 (slow), OMF#11
    Dan L, Sep 4, 2006
  11. BGN
    Pete Fisher Guest
    Just a long shot. A similar kind of ball and socket joint on the gear
    linkage is used on some Italian bikes and the Voxan. In this case there
    is a wire retaining clip that stops the ball coming out of the socket.
    Wondering if the 'circle wire' BGN describes is such a clip with the
    long bit broken off.
    Worth having a look at a parts schematic ?
    | Pete Fisher at Home: |
    | Voxan Roadster Moto Guzzi Mille GT/Squire RS3 Gilera Nordwest |
    Pete Fisher, Sep 4, 2006
  12. BGN
    BGN Guest
    BGN, Sep 4, 2006
  13. BGN
    BGN Guest
    I don't have the original can so I'll have to mention it to my local
    Suzuki dealer should I take it there for a service in the middle of
    t'month.
    BGN, Sep 4, 2006
  14. BGN
    BGN Guest
    Thank you and yes, I did decline it at the time.
    A few colleagues have bandits so I'll have a look at where the little
    thinger is on them. I assume any garage will be able to strap
    something to the exhaust in the right place for a minimal fee.
    BGN, Sep 4, 2006
  15. Strap? It's a bit of metal - it just needs welding on and having it's
    rubber blob re-attached. Ask anyone with a welder in exchange for a few
    pints.
    Dnc
    B12, ZZR11
    A6 2.5TDi V6 Quattro Sport
    DoetNietComputeren, Sep 4, 2006
  16. BGN
    Dan L Guest
    Get a rubber door stop and screw it to the fucker with a self tapper.
    Dan L (Oldbloke)
    Dan L, Sep 4, 2006
  17. BGN
    Beav Guest
    Easy, it's nothing more than a push together (with technique) ball joint,
    but when they start falling apart, it's time to change them, because they're
    fucked.
    It's entirely possible you could get a new gear lever from a cappers though,
    rather than spend 40+ quid.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Sep 4, 2006
  18. BGN
    catman Guest
    Are you Timo's alter ego, or something?
    www.cuore-sportivo.co.uk
    catman, Sep 4, 2006
  19. BGN
    BGN Guest
    He hasn't layed eyes on this one yet.
    BGN, Sep 4, 2006
