Bandit 600
Discussion in 'UK Motorcycles' started by Matt Horn, May 2, 2005.
  1. Matt Horn
    Matt Horn Guest
    Just got back in the saddle after about a year out with a bandit 600 S, a 96
    P reg, courtesy of the big Owen. I was made redundant last week so am
    looking to work in the city and hence the need for a bike again. Anyway
    along came the 600S which looks the ticket, only problem is there are a few
    bits to fix on her and was wondering if the collective knowledge knew a bit
    about bandits or was able to help out.
    1) Any ideas if the 1996 P Reg 600S has one of those model numbers like K1,
    K2 etc?
    2) Petrol tank appears to be leaking around the seem and has taken the paint
    off and doesn't look so good.. Anyone got a spare one or know where I can
    get a s/h or new one cheap? Colour not important (blue is the original)
    3) The joint in the exhaust has corroded away. I'm thinking about trying to
    weld in a piece of stainless pipe, but before I spend a day cursing and
    swearing has anyone got any spares/hints/tips or cheap sources?
    Any other bits and bobs going spare/cheap I'd be very grateful
  2. Matt Horn
    I got my joint welded up with a new bit of stainless steel. It's done a
    few years now, and is still as good as new.
    I may have a swing arm going for free, when I put my alloy one on.
    Muck, May 2, 2005
  3. Matt Horn
    Matt Horn Guest
    I think I'll have a go at that tomorrow if I can get some stainless wire. I
    wonder if the local exhaust fabricators ahve off cuts of stainless pipe I
    could knick.. I wonder if these is a local exhaust fabricator saying that!
  4. Matt Horn
    I went to a local welding bloke, coz I've not got welding skills or
    equipment, yet.
    Muck, May 2, 2005
  5. Matt Horn
    Arse, man. Best of luck with the search.
    No, you numpty. 2001 model was the K1 and then it follows in
    sequence.
    Petseal may be yer man here. You know - pour it in, swish it round,
    let it set.
    Those fuckers always go, Matt. Banditmania <spit> do a mail-order
    weld-by-return service but it isn't cheap. If you can weld stainless
    and have the kit to do it that would be your route, or get the lot off
    the bike and go talk to a local engineering/welding shop.
    I've got a few bits that might do (if I can find them) - what are you
    after?
    Pip, May 2, 2005
  6. Matt Horn
    Hooligan Guest
    But they did have model numbers: 1996 Bandit would be a GSF 600S T
    My '98 one was W
    Not sure it makes much difference, though.
    John (jsp)
    SV 650
    Black it is
    And Naked
    Hooligan, May 2, 2005
  7. Matt Horn
    Martin Guest
    Matt Horn wrote:
    [snip]
    I've welded a couple of these for family/friends, if you are going to
    weld it make sure and use Argon gas otherwise the welds are shit, also
    try and get the same grade of SS, IIRC its 304, I used an old
    intermediate pipe for a race can chopped up with an angle grinder. If
    not its about 80 ukp/section + postage from banditmania.
    And have fun making sparks ;->
    Martin:
    VTR1000 Firestorm
    Martin, May 3, 2005
  8. Matt Horn
    Matt Horn Guest
    Have used argo flow before rather than pure argon and it seems to be ok...
    we'll see! It may turn into the bean can and jubilee clip to get it through
    the MOT test!
    eeeek £80! plus of course I'd have to get it to them to do the job and I
    dont think I could turn it around inside a week.. Oh well, going to go and
    have a look in a mo... Why on earth did they put a section of mild stell in
    down there?
    Matt Horn, May 3, 2005
  9. Matt Horn
    Martin Guest
    The welding should only take an hour or so, after you have managed to
    get the headers off, get new bolts for them as the standard ones will be
    slightly corroded and are a PITA.
    Dunno.
    Before I tried welding them myself I send off a set of headers using
    parcel force IIRC it was 16ukp from Glasgow to banditmania and the pipes
    were returned within the week. Nonetheless they did a good job and
    return the pipes with the gaskets and other gubbins.
    Martin:
    VTR1000 Firestorm
    Martin, May 3, 2005
  10. Matt Horn
    Matt Horn Guest
    never heard of it before but just run a google and found it - is there
    anywhere you can buy this stuff on the high street, don't fancy trusting
    mail order as I want to get this done ASAP!
    no reason why I can't give it a go, my welding is ok, will go and get the
    stainless kit for the mig in a bit.
    I'm sure I'll find some bits whilst taking this one apart. Probably after a
    speedo if I can find one.
  11. Matt Horn
    Matt Horn Guest
    cheers for that, just when ordering stuff they seem to want to know which
    model it was for some reason although it looks like everything pre 2001 were
    the same from the sites I've seen so far.
  12. Matt Horn
    I've got a can I decided not to use - yours for what it cost (15.99) +
    postage if you get stuck. Or if you're within spitting distance of
    Swindon you can come & get it.
    Krusty, May 3, 2005
  13. Matt Horn
    Matt Horn Guest
    I was in swindon yesterday.. it's about an hours drive so a bit far really.
    Just caleld Motorcycle Parts Centre in Reading and they have some so I'll
    toodle off down there.
    Ta for the offer.
  14. Matt Horn
    The 'original model' bikes are all the same in the parts department,
    AFAIK. There was a big change for the 'K' model bikes and a few
    details since, but you're all right as far as that goes.
    Pip, May 3, 2005
  15. Matt Horn
    Told you it wasn't cheap. That's plus postage, too.
    As to the mild steel - **** only knows, unless it's there to act as a
    semi-flexible connector. Those that have been repaired with stainless
    sometimes suffer with cracking at that point. The cynical/realist
    (delete as appropriate) answer would be 'designed-in obsolescence', I
    guess - but that's cruel as that section doesn't rust out for ~10
    years, by which time the bike is generally worth little more than the
    cost of replacing the exhaust.
    It's an arse.
    Pip, May 3, 2005
  16. Matt Horn
    Most proper bike or car parts places should carry it - let your
    fingers do the walking.
    <genuflects>
    May the Farce be with you, my son.
    Sorry. No clocks in stock. I've got a screen for a faired Bandit ...
    but that won't be much use, will it?
    Pip, May 3, 2005
  17. The reg doc should tell you, mine is clearly listed as a 600 SV (also P
    reg)
    Mike Buckley
    RD350LC2
    GSF600S
    http://www.toastyhamster.org
    BONY#38
    mike. buckley, May 3, 2005
  18. Matt Horn
    You have my sympathy. At least you managed to escape you bastard.
    NP
    Krusty, May 3, 2005
  19. Matt Horn
    I may have a kmh speedo available when I put some different clocks on my
    Bandit. Right now, all I've got is a rev counter outer case at the mo.
    Muck, May 3, 2005
  20. Matt Horn
    zymurgy Guest
    Red Left hand fairing available via the underground railway....
    Cheers
    Paul.
    zymurgy, May 3, 2005
