Bandit 600: Notchy front brake travel
Discussion in 'UK Motorcycles' started by Kevin Stone, Sep 14, 2005.
  1. Kevin Stone
    Kevin Stone Guest
    Hi,
    I've noticed that the travel on the front brake is notchy. By this I mean it
    seems to stop at certain points until more pressure is applied. When stopped
    at lights earlier, I kept pulling it in and out and this seemed to make it a
    little better for a while.
    Sticking pistons? Calliper overhaul?
    This may or not be related to my previous post of front brake judder. At
    lower speeds the whole front end can judder under heavy braking, which is
    made worse now as it applies the brakes in discrete steps, which is very
    odd.
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, Kevin Stone
    Clean up the pistons and fit new seals would be my first port of call.
    and Ducati Race Engineer.
    Wicked Uncle Nigel, Sep 14, 2005
  3. Kevin Stone
    Kevin Stone Guest
    My thoughts as well, but as I'm about to move house in the next 2 weeks
    it'll have to wait for a little while.
  4. And if it's a sliding caliper jobbie, do the sliders too.
    Just done that on the GPz. Big difference.
    The Older Gentleman, Sep 14, 2005
  5. Kevin Stone
    Zanziba Guest
    Brakes on my CBR were like that, topped up the fluid and problem vanished.
    Sounds simple but it worked.
    Zanziba, Sep 14, 2005
  6. Kevin Stone
    Kevin Stone Guest
    Fluid levels are full to the brim. However, I did take the caliper off to
    have a closer look and it needs a good clean really, but it'll wait until
    Spring now.
    Kevin Stone, Sep 16, 2005
