Bandit 600 carb fiddling - ping Lozzo
Discussion in 'UK Motorcycles' started by Simon Wilson, Jul 27, 2009.
  1. Simon Wilson
    Simon Wilson Guest
    Mine has got a slight hesitation in the 4K-5K rev range on acceleration.
    A quick google reveals there to be a 'mod' by fitting a 020" shim in the
    carb needles. Various sites list Radio Shack as a supplier of the right
    size/thickness washers.
    Have you ever done this - know where to get some suitable shims/washers
    over here? I'd prefer to try and get the right bits before taking the
    carbs all apart.
    TIA
    ps - managed to get a fairing on e-blag, so I maybe fitting that this
    w/e if it arrives...
  2. Simon Wilson
    Dave Emerson Guest
    Try Maplins or your local R/C or Railway Model shop for the shims. They
    should have brass washers that are suitable.
    Dave Emerson, Jul 27, 2009
  3. Simon Wilson
    Simon Wilson Guest
    Almost certainly.
    Yep, but I don't/won't know those sizes until I take 'em apart.
    I think that's the case, yes, ta.
  4. Simon Wilson
    TMack Guest
    You could use a thickish hard plastic washer of the right diameter - it can
    then be easily adjusted by sanding it down a bit at a time until it seems to
    be in the "sweet spot".
    TMack, Jul 27, 2009
  5. Simon Wilson
    davethedave Guest
    Over here?
    My "over here" is Turkey, Some peoples "over here" is Switzerland others
    Portugal. For many it is the UK
    Are you one of our leftpondian cousins and which over here are you in?
    davethedave, Jul 27, 2009
  6. Simon Wilson
    Eiron Guest
    Why not just raise the needles by one notch?
    And while you do, check the diameter and notch spacing so you can get a supply of washers.
    Haven't got a Mikuni needle to hand but a Dynojet one is 3mm diameter and the notch spacing is 1mm.
    ISTR that the Mikuni needles were a touch smaller, perhaps 2.5mm but a 3mm washer would do.
    Eiron, Jul 27, 2009
  7. Simon Wilson
    Simon Wilson Guest
    Radio Shack is in the US - that's over there, whereas I'm over here.
    I know where I mean.
  8. Simon Wilson
    davethedave Guest
    Thats good. If you can remember your name as well you should be safe from
    the men in white coats.
    davethedave, Jul 28, 2009
  9. Simon Wilson
    Simon Wilson Guest
    Well, I only have to put it once in my sig.
    Simon Wilson, Jul 28, 2009
