Bandit 12 Oil Cooler Pressure.
Discussion in 'UK Motorcycles' started by toad_oftoadhall, Oct 12, 2006.
  1. What's the approx [1] pressure in a K1 Bandit 12 (SACS) oil cooler?
    I've always assumed it's quite low 'cos there's no reason to pressurize
    oil in the context and every reason not to.
    However someone's just told me it the same as the engine oil presure
    which simply cannot be right.
    [1] I dont need a specific number.
  2. toad_oftoadhall
    Steve Parry Guest
    Is it a shell bearing crank or roller bearing?
    Roller bearing cranks are lower pressure, shell bearing high pressure
    Steve Parry, Oct 12, 2006
  3. toad_oftoadhall
    Bod43 Guest
    Agreed.
    The cooler will most likely run at a similar pressure
    to the rest of the oil system.
    I don't know about this specific engine but in my experience coolers
    are
    usually installed on the high pressure side of the pump.
    Why you may - and have - asked?
    Well what alternatives are there?
    Own circuit and pump?
    Extra bits, more money, less reliability
    Suction side of main oil pump?
    Less pressure to drive oil through cooler (no more than 1 atmosphere)
    so cooler has to have a larger aperture.
    Possible increased priming issues if oil system
    is drained.
    On the other side, a cooler that is strong enough not to
    bend with normal handling is pretty much strong enough to
    deal with 50-100 psi oil pressure.
    Bod43, Oct 12, 2006
  4. Well yes for obvious reasons it needs to upstream of the oil pump, but
    a smaller apperture on the inlet or valve (if you wanted to be really
    high tech) could protect the cooler from the full oil pressure. ...and
    the advantages of doing so are immense.
    Anyone give me the definative answer?
  5. toad_oftoadhall
    Beav Guest
    But restricting the flow would make the cooler less efficient.
    It's in the middle of a pressurised system, so logic dictates that it'll be
    under roughly the same pressure as the rest of the oil, given that
    variations will exist within the system due to tight tolerances at one ond
    of the system (like main and big end bearings) and restriction free pipes
    that carry the oil around.
    Of course, someone will know for sure, I'm sure.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Oct 12, 2006
  6. True. - but then if you make the 'out of cooler' apperture bigger than
    the 'into cooler' apperture you can reduce pressure without restricting
    flow at all.
    I hope someone knows.
  7. toad_oftoadhall
    Eiron Guest
    It's basically the same engine as my old gixxer.
    The manual has a diagram of the oil flow - the oil cooler is at full pressure
    between the oil pump and the filter. The specific number is 7kg/cm^2.
    Eiron, Oct 12, 2006
