Backfiring
Discussion in 'Motorcycle Technical Discussion' started by Masospaghetti, Sep 11, 2005.
  1. The drill for compression testing is to do the test with the engine
    warmed up and both spark plugs out. Open the throttles wide open and
    maybe even block the vacuum slides up so the engine gets all the air it
    can to compress. Since a rubber hose connecting the gauge to a fitting
    in the spark plug hole has a lot of extra volume, one turn of the
    engine won't raise the compression pressure to what the engine does
    with the spark plug in the hole.
    Like, if you have 10:1 compression and you're at sea level, the engine
    would normally compress the air to 10 X 14.7 = 147 pounds, assuming
    that the valves and pistons are making a good seal.
    But, as I said above, the extra volume of the compression tester hose
    and the bourdon tube inside the tester make the pressure lower than
    what I calculated, so it takes several turns of the engine to build up
    the pressure inside the tester to what the engine normally does in one
    stroke.
    If the pressure doesn't come up to the manual's specifications in about
    five turns, the next thing to do is squirt a few drops of oil down the
    spark plug hole of the cylinder that tests low and turn the engine over
    a few turns to distribute the oil. If you put too much oil into the
    cylinder and don't distribute the oil, you can blow up your tester, the
    compression will be sky high.
    Then repeat the test. If the compression pressure increases, the rings
    are worn out or broken.
    Another way to check for whether it's burned valves or worn out rings
    is to turn the engine to top dead center on the cylinder you want to
    test and pressurize the cylinders with a source of compressed air and
    listen for leaks at the exhaust pipe, the carburetor inlets and the oil
    breather hose. If it's the gasket, you'll hear the hissing where the
    head and cylinder mate.
    You could use a small electric compressor like the emergency tire
    inflation compressors they sell at K-Mart or Wal*Mart. It would
    probably cost about $30.
    You would need to hook up your compression tester's hose to the
    compressor outlet hose.
    (I tried to do a leak down test on my pickup truck's cylinder head
    about a year ago, using a tire pump. I figured I could pump one
    cylinder full of air a lot faster than I could hand pump a tire. But I
    heard the air hissing out through the open spark plug hole on the
    adjacent cylinder and that's how I knew I had a blown head gasket. The
    tire pump trick would have worked for valve
    leaks or worn out piston rings, but the head gasket leak was just too
    much for my hand pump.)
    The piston is going to try to move when you pressurize the cylinder
    through the spark plug hole, it can throw the wrench you use to turn
    the crank across the room, so put the transmission in gear and block
    the rear wheel from turning before you pressurize the cylinder.
    If you're hearing air leaking out the exhaust pipe, the exhaust valves
    are leaking. Air out the carbs means the intake valves are leaking. Air
    out the breather means the rings are worn out.
    I'm glad to hear you are progressing little by little. I never even
    thought of ignition points because most Japanese engines didn't have
    ignition points after about 1980. If you have any spare change, you
    might even consider installing an aftermarket electronic ignition and
    get rid of those maintenance-intensive points.
    One thing about getting that deep into an engine that I should mention
    is to follow the repair manual's instructions for setting the pistons
    to top dead center before removing the camshafts. And, when you go to
    reinstall the camshaft bearing caps, for gawd's sake, clean all the oil
    out of the holes the cam bearing cap bolts go into and clean all the
    oil off the bolts themselves before you try to torque the bolts to the
    manual's specifications. You can RUIN the cylinder head by trying to
    torque OILY BOLTS!!!!
    krusty kritter, Sep 20, 2005
    #41
  2. Thanks for the tips, krusty.
    One more thing on the carbs - if the pilot screws are missing the
    o-rings or washers and air leaks past them, would that make the mixture
    too rich or too lean?
    I'm still concerned that the bike is running too rich, even on the right
    (strong) cylinder, because of the sooty plug and the occasional popping
    from the exhaust.
    Masospaghetti, Sep 21, 2005
    #42
  3. The pilot screws are actually adjusting a mixture of fuel and air, but
    when the pilot screws are located downstream of the throttle
    butterflies like they are on your CV carbs, we think of them as
    adjusting the flow of fuel. So if the o-rings are missing, the mixture
    will be too rich according to the thinking of professional tuners.
    The only way you'll really know whether the mixture is too rich is by
    the
    way the engine runs, whether the idle goes too high when the choke is
    on, or hangs up when the throttle is closed suddenly.
    krusty kritter, Sep 21, 2005
    #43
  4. Masospaghetti
    Matt Guest
    While cranking, either keep the ignition off (assumes you have a kick
    starter) or ground the spark plugs wires to the engine. That is to
    avoid damage to the ignition system.
    Matt, Sep 23, 2005
    #44
  5. Masospaghetti
    Matt Guest
    First thing is to resolve the compression problem.
    Matt, Sep 23, 2005
    #45
  6. Yeah, maybe it'll work things out. Valve cover and head gaskets on the way.
    I tried dripping some oil into the sick cylinder, bumped up compression
    5 psi to 95 psi...still way off from the other cylinder's 150.
    Masospaghetti, Sep 23, 2005
    #46
  7. Masospaghetti
    Matt Guest
    That sounds like good news.
    Hopefully you ordered a complete gasket set. It would be good to
    replace the valve-stem seals if you are getting any oil fouling.
    Matt, Sep 23, 2005
    #47
  8. Question about the CV piston - if I plug the air intake to the piston
    with my finger and try to move the piston, should it still move or kind
    of "get stuck"?
    One of the pistons on the carb "gets stuck" in position, while the other
    still moves pretty freely.
    Masospaghetti, Sep 27, 2005
    #48
  9. Masospaghetti
    Matt Guest
    .... when you plug the "air intakes", presumably.
    Each of my pistons (slides) has a couple of large (~1mm) holes in the
    bottom. There are also air jets in the carb body below the diaphragm.
    If your carbs are similar, which "air intakes" do you mean?
    If one carb behaves differently from the other, it should be pretty
    clear that something is wrong with at least one of them.
    If movement of one piston is impeded when you plug its bottom hole(s),
    and that doesn't happen for the other carb, maybe air jet(s) in one are
    plugged? Under different assumptions, maybe it means you have a hole in
    one diaphragm.
    You should have cleaned the sliding surfaces of the pistons and the carb
    bodies thoroughly with carb cleaner so that they feel smooth to your
    finger. Careful not to get carb cleaner on the rubber diaphragms unless
    you want to spend $130 and send them off to England for a rebuild.
    Matt, Sep 27, 2005
    #49
  10. There's an intake above the main carb barrel, an oval shaped one. This
    is the one I was referring to.
    Does this mean that the carb cleaner also wrecks havoc on rubber orings
    inside the carb?
    #50
  11. The oval hole is the source of atmospheric air pressure that actually
    lifts the piston when the engine is running and engine vacuum pumps the
    air away from on top of the diaphragm.
    But blocking that oval hole while the engine isn't running should not
    make the slide stick. The air on top of the diapragm should be able to
    escape through holes in the bottom of the vacuum slide. If you have the
    slide out, you'll probably see two holes about 1/8th of an inch in
    diameter. They are the "vacuum" holes that allow air to be pumped from
    on top of the slides while the engine is running.
    It's hard to imagine those hole getting crudded up so bad they get
    plugged, but you might check it out. Spray some aerosol carb cleaner
    through the holes. Maybe there's a dead bug in one of the holes?
    It might just be gum and varnish on the slide. You can clean it off
    with aerosol carb cleaner while the carbs are installed or just wash it
    off with clean gasoline if you have the slide out of the carburetor.
    Those are pilot air jets in some CV carbs. Other types of CV carbs have
    the pilot air jets in the intake bell mouth.
    It's actually a kind of bent oval...
    I've been cleaning my carbs with aerosol carb cleaner about once a year
    for 30 years and have never hurt a diaphragm with the stuff yet.
    Constant exposure to gasoline will eventually degrade rubber parts,
    especially when they are weeping gasoline just enough that they are
    always wet with it but a drop never forms. The little o-ring on float
    bowl drain plug will deteriorate for that reason, and will eventually
    come apart when the float bowl drain screw is opened. But right there,
    the softened rubber gets ripped and torn by the screwdriver turning the
    drain plug.
    If you are always tampering with your idle mixture, turning the screws
    back and forth, you could conceivably wear the tiny o-rings out. But,
    what the heck. Most shade tree mechanics tweak the idle mixture screws
    a few times, then they get tired of messing around under the shade tree
    and go for a ride and they quit messing with the idle mixture screws
    and the tiny o-rings can go back to sleep ;-)
    Some needle jets have an o-ring on them and the o-ring seals fuel air
    mixture for years and years and never deteriorates. But very few people
    even know they can push a needle jet out of their carb, so they never
    see that the o-ring looks just like brand new.
    krusty kritter, Sep 27, 2005
    #51
  12. No matter what the design of the carb, obviously they should both do the
    same thing.
    Is it resisting going up or failing to come back down? If you've sealed
    all of the vacuum intakes to the top of the piston, it should resist
    going up.
    As Matt wrote, there's often a small hole in the bottom of the piston
    too, which presumably would keep you from sealing the area at the top of
    the piston completely.
    Can you pull out the pistons without removing the carbs from the bike?
    If so, I'd do that and check for crud, tears in the diaphragms, etc. You
    might also try swapping pistons to see if the trouble follows the piston
    or the carb body.
    Michael J. Freeman, Sep 27, 2005
    #52
  13. Masospaghetti
    Matt Guest
    Maybe the OP's carb has some path other than a hole in the bottom of the
    slide for sucking air from above the diaphragm, and maybe that path is
    blocked.
    Anyway he should be able to use a wire to see that any bottom holes are
    clear.
    Matt, Sep 28, 2005
    #53
  14. Sorry for not specifying this - the carbs I was referring to in the last
    reply are another set of carbs that the seller threw in with the bike.
    They aren't in the best shape, all of the parts were tossed in a
    cardboard box, but I wanted to give it a try nonetheless.
    I figured that the slides would feel the same as the other. I'll have to
    make sure the passages are REALLY clean (although I did blast the whole
    thing down with carb cleaner).
    BTW, update - filled the tank up today, 3.7 gallons, 66 miles on the
    odometer. thats like...17 miles per gallon? I have the smallest SUV in
    the world!
    The strange thing is that the exhaust doesn't smell like raw fuel, and
    it sputters almost like its running lean, although its still sooting the
    plugs. Weird. Complete gasket set on the way, and i'll try the second
    set of carbs at the same time.
    Masospaghetti, Sep 28, 2005
    #54
