Backfiring on over run...
Discussion in 'UK Motorcycles' started by Dynamic, Feb 23, 2005.
  1. Dynamic
    Dynamic Guest
    We all know that intentional backfires, are big, clever and lots of fun, and
    those little pops on over run sounds wonderful but my FZR doesn't have the
    little pops :-(
    On over run, it will give one kill switch backfire type bang... Which hadn't
    bothered me until I rode it in the dark the other night, and realised that
    these things where lighting up the night sky behind me.
    How potentially damaging is this, as if it's just noise, I'm more than happy
    with it?
  2. Dynamic
    Cooool.. keeps the cars away I'd bet... well, all except the ones with
    blue flashing lights on.
    Sounds like a hole in the exhaust maybe?
    Muck, Feb 23, 2005
  3. Dynamic
    Dynamic Guest
    The exhaust all appears to be in good condition, so it hasn't rusted
    through, but I shall check for any leaks at joining points.
    I was presuming that the bike was just running a little rich, as the temp
    guage hasn't really left the cold section, though I have only been riding
    the bike since sunday, and it hasn't been very warm out...
  4. Dynamic
    Grimm Riffer Guest
    If it runs great from cold, and gets a little woolier once warm then it's
    running rich - though unless it's really way off it'll probably only be a
    bit iffy in a small part of the rev range. How does it run? How's it's
    fuel consumption? Bear in mind that old plugs and clogged filter and sloppy
    chain etc all exacerbate a fuelling problem as far as the ride goes.
    Without wishing to alarm ya, I've heard that burnt exhaust valves and bad
    clearances can cause this, as well as simple exhaust leaks.
    I have lots of pop-pops overunning down through 4k ish and I ain't worried.
    A real violent shut off at 6kish has twice made a big bang - that's in two
    years of use so I still ain't worried. And there *was* a plod following
    once when it did that, but that's a whole other story.
    For reference, my 7R is a little bit rich low down, but will still pull away
    from 30 in 5th on the flat. (And that's an engine that also does 60 in
    first).
    Grimm Riffer, Feb 23, 2005
  5. Dynamic
    Not usually dangerous except to the baffles - I've had the riveted end
    plate on a CX500 silencer blown off because of this.
    There may be another issue that needs looking at, though, if it's that
    loud.
    Pip Luscher, Feb 23, 2005
  6. Dynamic
    Monz Guest
    Check gaskets/unions air getting in is my guess
    Monz, Feb 24, 2005
  7. Dynamic
    Preston Kemp Guest
    How damaging do you think explosions in your exhaust could be? It may
    never cause a problem, or it may trash your can/valves/guides/engine.
    It's most likely caused by an air leak - when you shut the throttle the
    increased vacuum sucks air into the exhaust, igniting any unburnt
    mixture. Best to get it fixed imho.
    Preston Kemp, Feb 24, 2005
  8. Dynamic
    I've owned an FZR600 Genesis and once, in a moment of stupidity,
    replaced an exhaust valve bucket without placing the shim properly in
    its recess (it had stuck to the bucket), so the shim ended up wedged
    at an angle. This didn't pop or bang, but idling was rougher than
    usual and there was a persistent 'ticking' that appeared to have no
    clear source.
    Pip Luscher, Feb 24, 2005
