Back to armor
Discussion in 'Motorbike Technical Discussion' started by sndive, Dec 14, 2008.
  1. sndive
    sndive Guest
    How well does something like Bohn Body Guard Adventure Fully Armored
    Pants
    work while riding a bicycle?
  2. sndive
    carlfogel Guest
    Dear SN,
    It probably depends on whether you pedal.
    If you just sit still and coast, you might be comfortable wearing
    tight lycra pants with "armor" inserts designed to be worn by street
    motorcycle riders under their jeans.
    There's a reason why bicyclists don't wear leathers, much less plastic
    "armor".
    Cheers,
    Carl Fogel
    carlfogel, Dec 14, 2008
  3. Not that any of it is designed for an hour or two on the bike, but
    people seriously interested in both armor and cycling may want to look
    into what is worn by BMXers and Downhill/4X MTBers. They all wear armor
    while pedaling, in some cases furiously, but only for a few minutes at
    most.
    To a lesser extent, dirt motorcycling armor may be worth considering,
    since some enduros last hours, and the riders are quite active on their
    bikes. But even there, they're not trying to pedal for power or anything
    like that.
    Knee armor that works while pedaling is always going to be tricky.
    Ryan Cousineau, Dec 14, 2008
  4. sndive
    Chalo Guest
    http://en.wikipedia.org/wiki/Cuirass
    Pronounced "queer ass".
    It's best to ride your bike in such a way that you don't crash
    routinely. If you have a problem with that, perhaps you should try
    parkour-- it's a much less expensive way to crash routinely.
    Chalo
    Chalo, Dec 14, 2008
  5. sndive
    Peter Cole Guest
    Probably not very well. If you're going to wear protective gear, you
    might as well use that designed for biking rather than motorcycling as
    it's readily available.
    Next issue: is protective wear of any kind practical for road cycling? A
    quick perusal of the archives of this forum will reveal how contentious
    this issue is for even minimal head protection. In order of increasing
    importance, I'd put head/hand protection first, followed by face/jaw,
    followed by neck/spine. Buttocks, thighs and shins wouldn't even get on
    my screen. Sliding on pavement at highway speeds can remove flesh at an
    impressive rate -- much more than the "road rash" that is normally worst
    case for a cyclist.
    For off-road biking, I found knee, elbow and shin protection to be
    somewhat worthwhile, particularly in the learning curve period,
    particularly in rocky terrain. I did avoid injury once landing flat on
    my back on rock when my Camelbak took most of the impact (exploding the
    bladder in the process). I also broke my ribs a couple of times, but
    still wouldn't have worn torso armor just to prevent that. On the other
    hand, I have an annoying bone chip in my elbow that would have been
    avoided with simple basketball type pads. Pads on the joints are also
    nice in cold weather. I didn't find soft knee pads or soccer type shin
    pads to be too awkward for rocky off-road bicycling, but overkill for
    anything else.
    Peter Cole, Dec 14, 2008
  6. sndive
    Andre Jute Guest
    Colesy, I despair of you. What sort of an Irishman are you? Don't you
    know about the Leprechaun Wind that reaches out from behind a harmless-
    seeming hedge at the crossroads and blows you clean off your bike to
    bang on your hip and thigh. I found out about it after I'd been riding
    past this crossroads for 15 years (or so) and one day, as I whistled
    along, the next thing I knew I was on my side with a hundred buck
    worth of crank bent and more damage to my bike's saddle and paintwork.
    My physician measured the impressive bruise and abraded scab up my
    side at 19in (I trust only old-fashioned doctors who know they're in
    the trial and error business -- none of these kids who think they know
    everything). A trucky who stopped to pick me up said, "That corner is
    dangerous, man. Dinya know? All the panelsiders know about it."
    You ask me -- and I should add I never ride without a helmet (not
    because I believe one way or another but simply to keep the sun off my
    head -- and I would say hip and thigh and side protection comes right
    next to face and eye protection for a bicyclist. (Also for a
    motorcyclist. I've been on my face on the tarmac at high speed and the
    plastic surgery was painful even if it succeeded into turning me into
    a matinee idol.)
    Andre Jute
    Displaced Irishman
    Andre Jute, Dec 15, 2008
  7. sndive
    Peter Cole Guest
    We don't have hedges, but buildings provide a similar function. I have
    yet to be blown down despite my taller mast (so to speak). It must be
    reflexes. I play a lot of video games.
    Peter Cole, Dec 16, 2008
