Back protectors
Discussion in 'UK Motorcycles' started by TD, Jul 4, 2008.
  1. TD
    TD Guest
    Yes, I have searched the archives and read the many exciting discussions. I
    should really get a proper back protector as the foam in my jackets isn't
    going to do much.
    Is a dedicated back protector (Forcefield or Knox) much more protective than
    one that slips into my jacket like
    http://www.tprobodyarmour.co.uk/performance_upgrade_back.asp?
    I'm just weighing up the pros and cons, as I'm not sure that I will always be
    arsed to put on the strap-on one, whereas the in-jacket one is always there.
    TD
    1991 VFR400R NC30 (black and red)
    2001 ZX-9R (red and black)
    1999 M5 (neither black nor red)
    Missing: SOB, Unreliable Italian exotica, Lardy tourer
    TD, Jul 4, 2008
  2. TD
    antonye Guest
    Depends how much you like your spine the way it is I guess.
    At least with a dedicated protector you can pay for it once
    and then keep it no matter what jacket or leathers you wear.
    You could even (gasp!) wear a non-biking jacket with the
    back protector if you were feeling particularly rebellious.
    What happens when you get rid of your current jacket?
    I have a decent one built into my Dainese leathers, but I
    also have a seperate one for wearing with "paddock" jackets
    or other gear.
    antonye, Jul 4, 2008
  3. TD
    TD Guest
    Am I being whooshed? Just unzip the jacket, remove the insert, and put it
    into the new jacket.
    FWIW, I called Forcefield, and a lady told me that there's no difference in
    protection as such, it's just a matter of personal preference. Still not sure
    I believe it though. The jacket insert is half the price of the strap-on[1].
    [1] Oo-er.
    TD
    TD, Jul 4, 2008
  4. TD
    Geo Guest
    Not all protectors fit into all pockets methinks. Both me and a mate had
    some issues fitting (different) aftermarket back protectors into our
    (different) jackets. Mine was too long, his was too wide. Nothing a kitchen
    knife couldn't handle, mind.
    I would expect the strap-on to offer better protection on the grounds that
    it stays better where it was placed. A back protector would be moving around
    more, which might be an issue, particularly with regard to the lower spine
    and the neck.
    I'd still go for the jacket insert, as I think I'd soon tire of having to
    wear an extra item every time.
    Geo
    Geo, Jul 4, 2008
  5. TD
    Selective snip opportunity of the week...
    platypus, Jul 4, 2008
  6. TD
    How thick is it? The one that saved me (see other thread) is a good
    inch or more of very dense foam at its thinnest, and about three
    inches at the top of the spine.
    And usually they don't fit far enough down over the coccyx, although
    there are exceptions.
    _______
    Ace, Jul 4, 2008
  7. TD
    B 650 Guest
    My Knox back protector comes right down to the coccyx, which none of
    the jacket ones I've seen do. It's very comfortable to wear as well,
    so I don't have any problems putting it on every time. The sleeve in
    my HG jacket only covers the upper spine, and the built in protection
    was flimsy at best.
    It's sometimes tempting to go without it, but SWMBO gets most pissed
    off if she sees me without....
    B 650, Jul 4, 2008
  8. TD
    Nige Guest
    I got one of those KNOX multi link things featured in this months Bike
    mag, very comfy & well built. Not 'tested' it in action yet mind you.
    Nige, Jul 4, 2008
  9. TD
    Beav Guest
    Oo-er indeed:) Anyway, I know exactly what you mean about "can I be arsed to
    put on my strap-on" coz I felt the same way.
    Then I remember....."Somehow" I still know Christofire.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jul 4, 2008
  10. TD
    TD Guest
    I think I'm going to have to try both types on and make a random decision,
    which I will of course regret later and think I should have bought the other
    one.
    TD
    TD, Jul 5, 2008
  11. TD
    TD Guest
    Don't remember, although she did mention it. They have two versions of the
    strap-on, approved for CE Level 1 and Level 2 respectively. I think she told
    me that the inserts were thicker than the strap-ons.
    Hmm, I really don't see how an in-jacket one can get anywhere near my coccyx,
    which is the arse-bone, right?
    TD
    TD, Jul 5, 2008
  12. TD
    TD Guest
    My SO's HG jacket has a crap foam thing in, which I think I'll encourage her
    to replace.
    My HG Celtic leather jacket has a much more substantial CE insert, made by
    <squints> Eurobike. As this isn't available via retail, I can't find out
    anything about it. It's about 1.75cm thick. I'll be interested to compare it
    to the Forcefield inserts in the shop.
    My second-hand BMF HG Tricky textile jacket has a Hiprotec Backshock Air CE
    protector. This is a funny thing, made of several layers of foam glued
    together. Again I'll be interested to compare to the Forcefield.
    Although I'll probably finish up going for a "proper" one (i.e. not a jacket
    insert).
    TD
    TD, Jul 5, 2008
