Back brake problem
Discussion in 'UK Motorcycles' started by Lozzo, Jul 19, 2006.
  1. Lozzo
    Champ says...
    Thank you, darling ;-)
    Lozzo, Jul 19, 2006
  2. Lozzo formulated on Wednesday :
    Have you thought of applying the brake then clamping the flexible hose
    (assuming it can be clamped) with it still applied, then releasing the
    brake lever? Keep the clamp on for a while, then release slowly.
    It might just help prove whether it is the master cylinder pulling the
    slave back, it should settle its internal pressures with the clamp in
    place.
    Harry Bloomfield, Jul 19, 2006
  3. Lozzo
    Harry Bloomfield says...
    I fitted Goodridge to the rear to try and cure it. I'm not refitting the
    rubber hose.
    Lozzo, Jul 19, 2006
  4. Lozzo
    Beav Guest
    I was meaning that they coud be having a problem being pushed far enough to
    overcome any errant burr and the burr is "helping" them go back to thir
    original (and too far back) position, but if there aren't any obvious
    problems, it's not that.
    Everything is fine with the pad clearances, but the
    And the cheapest I'd guess. It's where I'd look after inspecting the caliper
    itself and finding nowt wrong.
    then maybe a used caliper if that doesn't
    'Kin brakes are becoming the bane of my fucking life this week too. I've
    just fitted new Brembo discs and pads to the boy's Evo coz they were
    squealing like a stuck pig every time he even looked at the pedal.
    They're *still* fucking squealing too, the cunts. Off with the new pads and
    a quick once over on the edges with 180 paper and a cunting splinter off the
    pads is now embedded in my thumb. Judicious use of copper slip on the
    anti-squeal shims did **** all for "light" braking, but they stopped hurting
    my ears with hard braking. They won't beat me either, but they're having a
    fucking good go.
    And my garage roof still isn't finished and it's threatening thunderstorms
    tonight. Fucking marvelous.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jul 19, 2006
  5. Did anyone else read this as "New motorcycle"? It's what I would do.
    Jeremy
    Jeremy Mortimer, Jul 20, 2006
  6. Lozzo
    TFFT. I had read 31 posts in this thread and was beginning to wonder
    if someone was ever going to state the obvious.
    CT, Jul 20, 2006
  7. Lozzo
    Jeremy Mortimer says...
    Nah, it's only got 60,000 miles on it. There's plenty of life left in
    the old dog yet.
    Lozzo, Jul 20, 2006
  8. Lozzo
    Big Dave Guest
    Dunno what's up with it, Loz, but my 23000 mile B12 (K1) is just the
    same...
    Big Dave, Jul 20, 2006
  9. Lozzo
    zymurgy Guest
    Isn't there a perfectly good spare on Pip's Bandit ? ;-)
    Paul
    zymurgy, Jul 20, 2006
  10. Lozzo
    There is, and it seems to be attached by locking wheel bolts now.
    Strange, that.
    There's a huge advantage to having a bunch of parts bin specials
    hanging about: the RF has an identical rear brake - and there's a
    spare RF master cylinder in a box in my garage. Hah!
    Pip, Jul 20, 2006
  11. Lozzo
    Matt Chapter Guest
    New brake pads... Sacrilege, I say!
    It's obvious you use the rear brake too much. [1]
    [1] My CB still has the original *front* brake pads at ~20,000 miles.
    Matt Chapter, Jul 20, 2006
  12. Lozzo
    Matt Chapter says...
    From this it is obvious that you, sir, ride like a girl.
    My Gixer gets through a set of front pads every 4000 miles max, at
    approx 95 quid a set. That's the trade price, by the way.
    Lozzo, Jul 20, 2006
  13. Matt Chapter wrote
    An odd thing to be proud of, do you only ride at one speed?
    and yer sg is broked
    steve auvache, Jul 20, 2006
  14. Lozzo
    Matt Chapter Guest
    While possible, it's more likely that my right hand is busy holding
    open the throttle so the f'kin thing doesn't stall every time I stop.
    Also bearing in mind it isn't terribly fast to start with.. and the
    pads are like rocks. From the 70's.
    One of many reasons I don't own anything nearly so new / powerful.[1] I
    just replaced the pads on the BMW with about 23,000 on the clock.
    [1] Another being that I'd probably bin it right quickly.
  15. Lozzo
    Matt Chapter Guest
    That's not what this pile of citations sez.
    Who says I'm proud of it? I'm waiting for those pads to die, die,
    die... I'm just too cheap to change 'em before they're cooked.
    Meh..google gropes sucks!
  16. Lozzo
    I've just clocked what CB it is that you own. I can go long with that,
    the pads on my old CB250RS were in that bike for at least 60,000 miles,
    and showed almost no signs of wear. The brakes didn't work very well
    when they were used, but you stopped eventually.
    You really are easy on the brakes, aren't you.
    Lozzo, Jul 20, 2006
  17. Lozzo
    Matt Chapter Guest
    Dear god I hope this set doesn't last that long.. They get the job
    done, but that's it. I've got SS lines on there now, but it didn't
    make nearly as much difference as I'd hoped / thought.
    I don't *think* so, but I'd never really considered it till now - I
    don't ride with others much so don't have direct comparisions. I'm not
    a big fan of slowing down, anyways.
  18. My 750SS still has them at 28k!
    The Older Gentleman, Jul 20, 2006
  19. Lozzo
    ChrisDC Guest
    My 750SS still has them at 28k![/QUOTE]
    Is it on the original spark plugs?
    ChrisDC, Jul 20, 2006
  20. Lozzo
    frag Guest
    Lozzo? He'z just ziz guy, you know?
    The pistons shouldn't retract a long way though, the rachet should
    "rach" and stop them from coming back any further.
    frag, Jul 22, 2006
