Back brake problem
Discussion in 'UK Motorcycles' started by Lozzo, Jul 19, 2006.
  1. Lozzo
    Not so much of a problem as a niggle.
    The Bindit rear brake has excessive travel before the pads engage the
    disc. I've tried adjusting the lever height, I've bled it right through
    with fresh fluid using both nipples on the caliper and even gone as far
    as fitting a Goodridge line I had kicking around that was the correct
    length. Still the pedal needs to be depressed quite a way before the
    brake works, but when it does eventally work there's no sponginess to it
    at all.
    I've stuck my head down and looked at the pads/pistons while pressing
    the lever, and they come back a hell of a long way when the lever is
    released, which means I have to press the pedal a long way to make the
    brake work.
    Come on, what's up with it?
    Lozzo, Jul 19, 2006
  2. Lozzo
    Mark Olson says...
    Bandit caliper seals are rectangular, you can't get them wrong.
    If the pistons retract a long way, then you'll need more lever movement
    to engage the pads next time round. Stands to reason, dunnit?
    Lozzo, Jul 19, 2006
  3. Lozzo
    Muck says...
    Already tried adjusting the pushrod, it makes no difference to the pedal
    travel, it just adjusts the pedal height. I'm wondering if one of the
    holes in the m/cylinder is blocked, maybe a clean out is in order.
    Lozzo, Jul 19, 2006
  4. Lozzo
    ginge Guest
    Mechanically, no idea, but you could get round the problem by having an
    inch thick spaz shoe made up for your right foot.
    ginge, Jul 19, 2006
  5. Lozzo
    ginge says...
    I want it sorting because it's difficult to use the rear brake when
    wearing MX boots. Lack of ankle flex in the boots means the rear brake
    is redundant at the moment, and I do use it round town and on slippery
    surfaces when it works.
    Lozzo, Jul 19, 2006
  6. Lozzo
    Muck says...
    I'd just go buy a used m/cylinder from a much later bike. They're cheap
    enough.
    Lozzo, Jul 19, 2006
  7. Lozzo wrote
    Dunno but I have just spent the afternoon catching rays and doing the
    deeds that need doing to be able say that my not quite as Bloo as it
    used to be Bloo GS does, as promised, now sport a braided steel front
    brake hose and the whole episode was entirely painless and issue free.
    except when I leaned back to admire my handiwork and forgot about the
    cactus.
    Maybe it is tired piston seals, they should only give a bit to allow the
    pad to just come off the disk and no more.
    steve auvache, Jul 19, 2006
  8. Lozzo
    Muck says...
    I just did an online search to see what models were fitted with that
    m/cylinder. Talk about parts bin specials - it fits 43 different Suzuki
    models from 1988 up to 2004. Well, that makes sourcing a recent one a
    whole lot easier.
    Lozzo, Jul 19, 2006
  9. Lozzo
    Beav Guest
    It does, but what could make the pistons retract? There isn't anything
    interfering with the last bit of movement when you operate the lever is
    there? I'm thinking along the lines of the anti-rattle "clip". Also, is the
    part of the caliper where the pad sits smooth? If there's a burr on the
    caliper or the pad edge, it could be just enough to stop the pad "sitting"
    and allowing it to slide back to a more comfortable position.
    That's all I can think of anyroad.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jul 19, 2006
  10. Lozzo
    Matt Chapter Guest
    Forgive my perhaps obvious suggestion:
    possibly the pads are worn?
    Matt Chapter, Jul 19, 2006
  11. Lozzo
    Matt Chapter says...
    New pads less than 2000 miles ago, and I've hardly touched the rear
    brake becauise it's awkward to operate. They are barely worn in.
    Lozzo, Jul 19, 2006
  12. Lozzo
    Muck says...
    Same as any early 6V C90 I'd have thought.
    Lozzo, Jul 19, 2006
  13. Lozzo
    Beav says...
    If the pads were sticking in the caliper then they wouldn't retract as
    far as they do. Everything is fine with the pad clearances, but the
    pistons retract a long way, and when the pedal is depressed it takes a
    lot of travel before the pistons push the pads into contact with the
    disc.
    New m/cyl is the first choice, then maybe a used caliper if that doesn't
    work. Either way, I won't let it beat me.
    Lozzo, Jul 19, 2006
  14. Lozzo
    Pip Luscher says...
    It does this when staionary.
    I've pumped the pistons almost right out to clean them, and they move
    freely within the seals.
    This sounds most likely. As I said, it'll be easier for me to source a
    newer used m/cyl than piss around trying to repair the 60K mile old one
    I have.
    Lozzo, Jul 19, 2006
  15. Lozzo
    If you're open to wild guesses:
    guess number one is that the disc is slightly warped or loose, causing
    the pads to get knocked back;
    guess number two is that the seals have stuck to the pistons, rather
    than letting them slide out to lake up wear;
    guess number three (very unlikely) is that there's some sort of
    blockage, and when the master piston returns under spring pressure it
    draws the pads back.
    Pip Luscher, Jul 19, 2006
  16. Lozzo
    FFS! "lake up wear"?
    It's not even as if the keys are adjacent!
  17. Loz, have you tried jamming the pedal in full-on position overnight?
    This may overcome such stickiness as Master Pip surmises.
    Dr Ivan D. Reid, Jul 19, 2006
  18. Mark Olson wrote
    That's the puppy.
  19. Lozzo
    Dr Ivan D. Reid says...
    I will try tonight. Anything free is worth a go.
    Thanks
    Lozzo, Jul 19, 2006
  20. Lozzo
    PDannyD Guest
    On Wednesday 19 July 2006 17:57, Lozzo [] wrote in message
    Check the reservoir breather isn't blocked, the diaphragm isn't fully
    stretched (and so sucking the pistons back) and if it aint them then maybe
    the master cylinder needs stripping and cleaning.
    PDannyD, Jul 19, 2006
