b*stard thing still does not run..
Discussion in 'UK Motorcycles' started by mr p, Nov 9, 2007.
  1. mr p
    mr p Guest
    Following on from my previous thread about the battery in my
    CBR1000F..
    I have now put the new battery in and that seems fine now, however the
    bike still did not tick over.
    I checked the spark plugs and they are clean, so I set the gaps and
    put them back. The air filter is a K&N one and seems to have been ok.
    So I adjusted the throttle stop with the intention of having an
    'Italian tune up' however the throttle was sticking open making it
    rather dangerous to ride !
    I checked the cables, and the lever seems to be actually closing ok..
    Does this mean I have to take the carbs. off and have them to bits or
    shall I try spraying some cleaner in first ? I put rather a lot of
    redx in the tank as well.. I wander if I put too much in ? I'm half
    tempted to take it to a shop and let them sort it, I just want to ride
    the fff'ing thing really !
    I took one of the carb covers off and can't get the spring back in
    now it's got dark ! ( the needle valve thingy did look a but mucky
    though.. ) bugger it !
    Simon
    mr p, Nov 9, 2007
  2. Has it been rejetted to match?
    This needs fixing as a priority. If you cannot achieve proper throttle
    control just how do you expect to perform well in front of the 6th form
    girls?
    steve auvache, Nov 9, 2007
