Awesome anchors.
Discussion in 'UK Motorcycles' started by Cane, Dec 18, 2003.
  1. Cane
  2. Cane
    Cane Guest
  3. Cane
    Cane Guest
    Which is reason enough for someone as shallow as me :)
    Cane, Dec 18, 2003
  4. Cane
    Alan.T.Gower Guest
    They will look different.
    Alan
    http://www.ads-training.co.uk
    "Kneesliders Sponsored by Cane"
    GSX-R1000 , Triumph Thunderbird, ZXR750L2 Racer(gone), GS500,
    GHPOTHUF#27
    TGF, UKRMFBC#7, Two#24, BOTAFOF#11, YTC#9, GYASB#1. SbS#23.
    DFWAG#2, DS#2, DIAABTCOD#20. remove "thisbit" in the reply
    http://sportsbike.org (our own endurance team) http://Team-ukrm.com
    "Nemo repente fuit turpissimus"
    Alan.T.Gower, Dec 18, 2003
  5. Cane
    http://www.bsr-aerotek.com/
    hth
    Champ, Dec 18, 2003
  6. Cane
    So, you've got better brakes which will generate more weight transfer
    to the front, and therefore make the rear more likely to lock, and you
    want to make the rear fiercer?
    Many racers bleed air ito their rear brake...
    Champ, Dec 18, 2003
  7. Cane
    Cane Guest
    I have no serious plans to alter the rear as I hardly ever use it other than
    when slow manouvering.
    Blimey! I can do one finger stoppies now.
    Cane, Dec 18, 2003
  8. Cane
    antonye Guest
    You should try a radially mounted, 4-pad setup. Now that is awesome!
    antonye, Dec 18, 2003
  9. Cane
    flashgorman Guest
    flashgorman, Dec 18, 2003
  10. Cane
    It's part of the regs, so it does have to be there. And I guess, from
    a safety perspective, if you had a front brake failure it would be
    good to have *some* rear brake, no matter how ineffectiev.
    The whole "thumb brake" thing is about using the back brake to control
    wheelspin on the way out of the corner. Bit out of my league, I
    reckon...
    Champ, Dec 18, 2003
  11. Cane
    flashgorman Guest
    Having brakes just slows you down. Pull in clutch, select first gear, hit
    kill switch and let clutch out.
  12. Achterly, having a mildly crap back brake is a goo thing.
    GS 850 x2 / SE 6a
    SbS#6 DIAABTCOD#16 APOSTLE#16? FUB#3
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Dec 18, 2003
  13. Look in YP and find Hydraulic Hose Stockist/Specialist.
    They'll make you up a set of braided hoses every bit as good as the
    biketrade ones for a part of the price.
    GS 850 x2 / SE 6a
  14. Cane
    flashgorman Guest
    Wouldn't that be standing it on it's tail rather than nose?
  15. Cane
    Now you're getting technical. You donkey.
    Pip, Dec 18, 2003
  16. Cane
    flashgorman Guest
    You started it. You hairy muppet.
    flashgorman, Dec 19, 2003
