Avons
Discussion in 'UK Motorcycles' started by SP, Mar 18, 2005.
  1. SP
    SP Guest
    After checking my tyre pressures this evening with my newly-bought
    fancy digital tyre gauge [1] I discovered that the rear now only
    contains 9 PSI, which is a tad low..
    After a lot of looking around, and on recommendation from a regular at
    the pub I've had a price from a place in Warrington to fit a pair of
    Avon AV49/50 to the bike tomorrow for £159 including fitting, which
    seems like a very reasonable price.
    Obviously the price is very appealing, and I've been told that they are
    comparative in performance and longevity to my favourite Bridgestones.
    Has anyone here used the AV's, and what was/is your opinion?
    Ta.
    [1] I seem to go through a lot of tyre gauges, the cheapo pencil type
    ones are what I normally use but I think I left one of them in the
    tool-box of the ZXR, one in the tool-box of the GSX-R, and gawd knows
    where the other two have disappeared to.
    Lesley
    CBR600FW
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    SP, Mar 18, 2005
  2. SP
    Salad Dodger Guest
    It was completely flat yesterday.
    If you leave it over the weekend, it'll be fine.
    Salad Dodger, Mar 18, 2005
  3. SP
    Paul - xxx Guest
    Salad Dodger composed the following;:
    Yeah, but leave it a week and it'll blow up ...
    Paul - xxx, Mar 18, 2005
  4. SP
    Dan L Guest
    I've just booked the Zephyr in for a pair of new Avons.
    Unortunately this means that I will only have a week to get them scrubbed in
    before BOSM.
    Fortunately this means I will *have* to commute to Chiswick for a few days.
    Dan L (Oldbloke)
    M'boy's bike 2003 Honda NSR125R
    Spare Bike 1990 Suzuki TS50X
    BOTAFOT #140 (KotL 2005), DIAABTCOD #26, BOMB#18 (slow)
    Dan L, Mar 18, 2005
  5. SP
    Salad Dodger Guest
    You live, what, 100 miles from the pub? They'll be scrubbed in before
    you get there.
  6. SP
    Dan L Guest
    Oi, my missus sometimes reads this y'know.
    <FX Taps nose>
    Dan L (Oldbloke)
    Dan L, Mar 18, 2005
  7. SP
    SP Guest
    No idea what Dan thinks, they now recommend 100 miles instead of the 50
    (for some reason). My planned route back means they will be scrubbed
    in before I get home, ready for my sojourn to N Wales on Sunday to see
    a mate do his first MX race.
    Lesley
    CBR600FW
    BONY#54P BOB#18
    SP, Mar 19, 2005
  8. SP
    Personally, I give it about twenty miles for them to get up to
    temperature (which is not much more than the Guzzi needs to properly warm
    up) then set "Devil May Care" to max.
    sweller, Mar 19, 2005
  9. SP
    Dan L Guest
    I reckon about 100.
    What do you reckon?
    Dan L (Oldbloke)
    Dan L, Mar 19, 2005
  10. SP
    Monz Guest
    I tend to go for about an hour of ever increasing bank angles and beans
    until I think "oh **** it" they must be scrubbed now. This approach seems to
    have worked up to now. :eek:)
    Monz, Mar 19, 2005
  11. SP
    Bear says...
    *ding*
    Lozzo, Mar 19, 2005
  12. SP
    wreckferret Guest
    <sulk> My washing machine hasn't got one of those.
    wreckferret, Mar 19, 2005
  13. 1. Have you replaced the fairing on the GSXR yet? or
    2. Is that with the tyre warmers switched on or off?
    It only took two laps of Cadwell Park to sort the Corsa's.
    eric the brave, Mar 19, 2005
  14. SP
    Dishwasher.
    Not at the same time as cooking the salmon, mind.
    Pip, Mar 19, 2005
  15. SP
    Ben Guest
    And avoid roundabouts until you have.
    Ben, Mar 19, 2005
  16. SP
    Preston Kemp Guest
    I think you were still on your sabbatical last time this was discussed
    in depth. When it was, I decided to ignore all the opinions & ask the
    people who should know, namely the tyre manufacturers. I spoke to a
    technical bod at Dunlop who said 'breaking in' a new road tyre was
    needed for the following reasons:
    1. Bedding in of fibres/belts. This is done through a combination of
    heat & flexing, & is needed to ensure the various parts of the carcass
    settle in nicely together.
    2. Bead seating/sealing. The bead pops into the right place when the
    tyre's inflated, but won't 'grip' the rim properly until it's had a bit
    of a cook. If it's not sealed properly, the tyre can slip round the rim
    throwing the balancing out, as seen occasionally in racing.
    3. Surface scuffing - what's usually meant by 'scrubbing in'. This is
    mainly just to clean any crap off the surface that may have accumulated
    during transport/storage, & give the surface a bit of a key. The common
    myth is you need to clean off the release agent - this isn't true.
    Release agent isn't used on modern tyres, with the exception of some
    compounds of race tyre.
    So, as Champ said, heat cycles are the important thing, but doing this
    on the road will take longer than the track as the tyres don't get
    anywhere near as hot. The actual length of time/number of miles depends
    on lots of obvious things, but 50 miles was considered plenty by the
    techie bloke.
    Preston Kemp, Mar 19, 2005
  17. So can you lean right over as long as you're not giving it welly?
    This isn't a trap or a trick question. I'm asking because generally it
    isn't possible to get right over without some degree of speed. I suppose
    I'm asking what the maximum speed might be before the tyre lets go. I've
    got some brand spankies on and unless I make an effort to go out and use
    them they're not going to be scrubbed in before I get to the BOSM, and
    even then that's a lot of miles in an upright position; chucking it up
    the road on the last bit isn't what I want to do.
    I've always done what others have said and gone a little bit further
    over each time but I'd like to get that out of the way and do it sooner.
    Roundabouts are ok but what about the left hand said of the tyre?
    Whinging Courier, Mar 19, 2005
  18. That's what I've always done. When it gets to the point of about half an
    inch of CS[1] I can be fairly confident there's enough "proper" rubber
    there to hold me up.
    Bless :)
    Taking it steady and building up gradually never was one of my fortes. I
    can think of at least one thing that tends to blow when I jump right in
    but to go into detail about that now would be far too much information
    ;o)
    I always knew about the tyres but reading this thread got me thinking
    there might've been a quicker way to do it.
  19. SP
    Ben Guest
    You missed my subtle (or not) dig at Champ for dropping his bike on a
    roundabout after having new tyres fitted.
    Ben, Mar 19, 2005
  20. It is actually possible to do a procedure called 're-inflating' they
    tyres you already have. You don't /have/ to replace them just because
    they are a bit flat.
    Simon Atkinson, Mar 19, 2005
