Automatic chain oilers
Discussion in 'UK Motorcycles' started by Harry Bloomfield, Nov 9, 2004.
  1. Harry Bloomfield, Nov 9, 2004
  2. Harry Bloomfield
    That appears to be deeply fucked insofar as even the inventor has no
    enthusiasm left - have a look at the forum section ...
    Think I'll pass, ta.
    Pip, Nov 10, 2004
  3. Harry Bloomfield
    Dazed Guest
    Dazed, Nov 10, 2004
  4. Harry Bloomfield
    Lozzo, Nov 10, 2004
  5. Lozzo used his keyboard to write :
    Expensive for a bit of plastic pipe, a plastic bottle and a valve.
    Harry Bloomfield, Nov 10, 2004
  6. Harry Bloomfield
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Harry Bloomfield
    Oh well, just make your own then. Easy.
    Nigel Eaton, Nov 10, 2004
  7. Harry Bloomfield
    Harry Bloomfield says...
    Cheaper than replacing chains at far too frequent intervals. I have had
    this one on 4 bikes now and saved a fortune in chain and sprocket sets.
    It cost me nowt to buy the original metering valve because I took it off
    the bike it came with when I sold the bike, and it cost me a tenner for
    a second hand touring resevoir which I top up with cheapo Husqvarna
    chainsaw oil. Bargain.
    Lozzo, Nov 10, 2004
  8. I did. Baby's bottle from Boots, bit of plastic piping, tap from Boots'
    home-made wine section....
    Gravity feed, and you had to remember to turn off the tap when parking
    the thing, but it did my XT600 proud, and the total cost was about three
    quid.
    The Older Gentleman, Nov 10, 2004
  9. Harry Bloomfield
    YTC#1 Guest
    Not so expensive when you work out how much it saves in chain adjustment
    time and chains.
    YTC#1, Nov 11, 2004
  10. Harry Bloomfield
    It's a myth, I tell you! I know we've done this all before, and many
    times, but I really don't understand why people think that a quick
    squirt of lube and a visual check every thousand miles or so, with an
    adjustment required perhaps[1] once per service interval (i.e. the
    shop does it) is such an onerous chore.
    [1] I have done the gixxer once myself, but TBH it didn't really need
    it - was more just for the practice.
    Ace, Nov 12, 2004
  11. Harry Bloomfield
    Preston Kemp Guest
    Think of a Scottoiler as a chain *cleaner* rather than an oiler, & you
    might understand why they're better. It's grit that kills an O/X ring
    chain prematurely; moreso than lack of oil. The grit & grime act as a
    grinding paste wearing away the rubber, & once it's worn enough to let
    water through, you're doomed.
    The constant drips of oil from a Scottoiler stop any grit from building
    up on the chain, literally cleaning it as you ride. The last chain on
    my Tiger lasted 30,000 miles of year round use and off-roading as a
    result. I only changed it then because I felt guilty - it certainly
    wasn't badly worn.
    Preston Kemp, Nov 12, 2004
