Australian Superbike School
Discussion in 'Australian Motorcycles' started by Fwoar, Oct 7, 2003.
  1. Fwoar
    Fwoar Guest
    I did Level 2 today ( after it was rained out in May ) at Eastern Creek.
    Most of this level in for the visual skills & once taken in with an open
    mind - all becomes apparent.
    - what they reckon
    * what I got out of it
    Reference Points
    - Find your reference points on the circuit for turning braking ( although
    we aren't using brakes yet)
    * I didn't make it too far into this as I had a flat battery ( doesn't help
    with a total loss system ) - but I been there lots so it I didn't miss out
    on too much there.
    Changing Lines
    - Riding around the track at the edges & the finally the centre, then using
    your own lines.
    * Discovered that the track is quite wide in places & lotsa rubbish from the
    w/e at the edge of the track. Makes you aware that there is quite alot of
    room for error *away* from your comfort zone.
    Vanishing Points
    - Looking forward through the corner for your reference points & riding
    without really looking at them
    * recognised points that I sometimes use to put myself in certain positions
    on the track
    Wide Screen
    - Solution to Target Fixation
    * dismiss unimportant information - I found you can tell a riders track
    position with this without really looking at them. Made it easy to overtake
    *really* slow riders.
    Pick up
    - Picking the bike up on the way out of turns to get more traction
    * I knew & used this one already but it's not a bad technique to learn. I
    found it hard to do all the Level 1 & 2 visual skills with this one.
    Of course I got a guy who was in his 2nd day as an instructor - made things
    interesting at times. Sometimes I'd show him something & then we'd get back
    on track. I was only using 3,4,5th gears for most of the day with minimal
    braking towards the end of the day. Still it was a good day to learn & I did
    get a few things out of it. One of them might be a job. never know
    daron
    Fwoar, Oct 7, 2003
  2. Yeah its riders like you that are always causing problems for us normal
    riders!
    Next you'll be telling us you race or something!!
    Hammo
    Hamish Alker-Jones, Oct 7, 2003
