Krusty, Thanks for all the good info on the charging system. I checked everything the best I could with an ohm meter and all seems to be in order. I have the second bike, so I ended up swaping the known good voltage recifier/regulator and re-starting the 81, and once again there should be 14.5 volts at anything above 2000rpm, but there is only 11 to 11.5 volts going in even at 5000 rpm. So it is looking like the alternator is the problem. Here is the ohm findings from the connector, no wires have continity to ground. The 3 yellow wires have full continuity to each other and according to the book should be between .041 to .051 ohms. There is no resistance on the 3 yellows, but they are all the same, so there does not seem to be an open winding. Would this be a brush problem considering that some of the juice is going to the battery? I have not removed the alternator yet, as do not have a fly wheel puller, but will have to get one soon. Wondering if you have any ideas or further tests that can narrow the stator / brush problem? Tim.C
